    Large all-metal Kossel Delta
    My Duet controlled machine
    5.6k
    • DjDemonDundefined
      DjDemonD
      I've always found that whenever I've made spool holders with bearings the filament comes off them much less well, more prone to slip a loop off the reel and spin back and forth, a little bit of friction with the spool holder helps.
      www.precisionpiezo.co.uk
      • Russ Griesundefined
        Russ Gries
        @Dougal1957:
        Looking good Can I ask what elastic your using for the Flying Extruder?
        Doug
        I recommend using this stuff:
        https://www.amazon.com/Stretch-Magic-Stretchy-Beading-Clear/dp/B0058E7WOA/ref=sr_1_2?ie=UTF8&qid=1474310375&sr=8-2&keywords=stretch+elastic+beading+cord
        been using it on mine for years, seems fine! its a type of TPU…
        good looking build by the way!!!!
        I think you would also enjoy my build...
        https://www.duet3d.com/forum/thread.php?id=187
        its about the same size 🙂
        ~Russ
        One Day At A Time…
        My Main Research Page:
        http://rwgresearch.com/open-projects/3d-printing-research/
        • DjDemonDundefined
          DjDemonD
          Looks good Russ. Wonderfully detailed build - and you really did build it and make almost everything. I just bought a bunch of stuff and bolted it together. When I get chance I will watch through your videos.
            Russ Gries
            Thanks, something about making all the parts, yeah it takes a lot of time but now i can say " i made that" lol there is always something tho like the electronics that are just much better to buy…
            also i have a question. my kids got a hold of my printer and ran the arms up and down, breaking some of course. but what ever lol it happens...
            my question is do your motors at a stand still at 100% power squeal ?
            I ran the Wifi Duet previously but only got about 2 use's out of it and i cant remember if the motor had that bad squeal.
            the reason i ask is i know the kids ran those rail's up and down and drove a lot of power in to the drivers... go figure. so i was wanting some one else to confirm that there motors don't make a squeal sound when parked at full power... they still run fine and quiet too but now i'm worried that the drivers may be damaged...
            Thanks!!
            ~Russ
            One Day At A Time…
            • DjDemonDundefined
              DjDemonD
              My motors make a high pitched noise when powered up and holding at 100% but its not particularly distressing either that or my ears are old enough that its barely audible to me. My understanding of the stepper drivers is that they have a lot of built in protection so they will shut down to protect themselves and the motors if they are repeatedly asked to perform movements at speeds that are dangerous.
              • DjDemonDundefined
                DjDemonD
                Well I never thought I'd see this:
                16:15:37Stopped at height -0.150 mm
                16:15:31G32
                Calibrated 8 factors using 10 points, deviation before 2.630 after 0.001
                16:15:00G28
                16:07:55G10 P0 S130
                16:07:52M140 S85
                16:07:49Connection established!
                16:07:45Page Load complete!
                That's only probing the central 100mm of my kossel XL bed, with my piezo probe using an experimental build surface on glass, but deviation 0.001 - happy with that would be one way of putting it.
                  T3P3Tony administrators
                  (thumbs up emoji)!
                  • roboduetundefined
                    roboduet
                    @DjDemonD Can you try 20-30 random points instead of 10?
                    • DjDemonDundefined
                      DjDemonD
                      I can but is there a quick way to do this? or are you defining the 30 random points manually? If so I really don't have the time.
                      • roboduetundefined
                        roboduet
                        I'm using simple PHP script to generate random points inside bed. If you are familiar with php I can post script, if not - I can post bed probe g-code file for your bed dimensions.
                        • DjDemonDundefined
                          DjDemonD
                          Sure Ill try it, if you can post a bed.g file. I am using a 100mm diameter (I have a 300mm diameter bed but I often only probe the inner 100mm for printing small objects. I can't quite get down to the 0.001 levels with the 300mm diameter.
                          • roboduetundefined
                            roboduet
                            Please add Sx (x = number of factors) to latest line you want to use:
                            For 100mm bed diameter
                            For 150mm bed diameter
                            For 200mm bed diameter
                            For 300mm bed diameter
                            • DjDemonDundefined
                              DjDemonD
                              Okay thanks I'll run some of these later. What sort of results have you seen so far?
                              • roboduetundefined
                                roboduet
                                You are using 10-point 8-factor calibration.
                                I just think that the smaller the number of points for calibration the easier it is to get perfect results. For example, using 3-point 8-factor calibration you will get perfect results with any sensor.
                                That's why I asked about 20-30 points.
                                • DjDemonDundefined
                                  DjDemonD
                                  100mm Run 1
                                  18:56:18 G32
                                  Calibrated 8 factors using 64 points, deviation before 0.089 after 0.011
                                  Run 2
                                  18:58:43 G32
                                  Calibrated 8 factors using 64 points, deviation before 0.026 after 0.007
                                  Run 3
                                  19:00:51 G32
                                  Calibrated 8 factors using 64 points, deviation before 0.010 after 0.009
                                  So its an order of magnitude less precise when probing 64 points rather than 10. However its still achieving at best 0.007mm deviation, so its still a very accurate machine (should be cost me enough money, and even more time) plus the piezo probe is very accurate and repeatable.
                                  Using AndOrNot experimental build surface, e3dv6 and Precision Piezo 27mm piezo sensor in Lykle/Zesty design assembly.
                                  • roboduetundefined
                                    roboduet
                                    Thank you, excellent results!
                                    It seems for me that with such accurate build M665/M666 command output is never changing between calibrations.
                                    • DjDemonDundefined
                                      DjDemonD
                                      Thank you. Yes it barely changes, I still run a calibration before each print and it usually trims the values slightly, but if this were my micro delta (https://www.thingiverse.com/thing:1874766) which I calibrate manually using Escher 3D least squares, I would calibrate it automatically once and then only return when I'd changed something, so I have never bothered to fit a z-probe to it. But on the 3 times larger kossel XL machine the effect of thermal expansion on the frame and bed might be marginal from one day to the next, but its just significant enough to be worth calibrating it frequently. Its also a good basic check if anything is amiss.
                                      It would be quite nice to be able to code into the bed.g file , if deviation >=0.03 then halt. Or something like that.
                                      This machine has been a nice test bed for the piezo sensor - I can rely on the printer to be accurate therefore I can evaluate one sensor design/type against another. I built a test rig but it was, as expected with printed parts and smooth rods, not terribly accurate. I was using it just to check a module I had built worked before shipping, but it broke down, and I'm so familiar with them now a few taps on the bench, and a shake to check its not too sensitive, is enough to see if they are working or not.
                                      I was thinking about raising the hot end on the kossel XL as it currently hangs down below the effector, which might push things even closer to perfect, but its working so well I might refuse this one, for fear of ruining it, just chasing those last few thousandths of a millimetre, the path to insanity (or physics).
                                      • DjDemonDundefined
                                        DjDemonD
                                        Here is this machine now with prototype enclosure, smart effector and filament monitor. Still to fit accessory chamber heater, and chamber cooling fan.
                                        The extra heater monitor channels provided on the expansion connector are great and I can monitor temperature at the bottom and top of the chamber, to control heaters/fans to maintain the ideal temperature. Water cooling for hot end being considered.
