    CNC Screw Mapping
    Firmware developers
    1.1k
    • markzundefined
      markz
      Here's a doc file describing the current implementation of screw mapping.
      Screw Mapping in RRF.docx
      • markzundefined
        markz
        I've posted a video showing a calibration run (in X). It took about 1/2 hour to gather X and Y error terms and improved the CNC accuracy from .033" to .002".
        here: https://youtu.be/wpUOaYwDrvI
        • botundefined
          bot
          Nicely done!
          I just had a thought, though. Make sure your yard-stick is straight. You could be compensating for an error in the yard stick.
          *not actually a robot
          • markzundefined
            markz
            Sorry, I should have posted that. You're absolutely right.
            The yardstick is one of the most expensive hand tools I own since it's so important.
            https://www.mscdirect.com/product/details/58700246
            • botundefined
              bot @markz
              @markz Oh!!!! That's a nice "yard stick" lol!!!
              markzundefined 1 Reply Last reply Reply Quote 0
              • markzundefined
                markz @bot
                @bot Yeah, Starrett would probably not be happy me calling it that.
                  I also spit coffee on my laptop when I saw that price. 😳
                  botundefined 1 Reply Last reply Reply Quote 2
                  • botundefined
                    bot @Phaedrux
                    I suddenly want a yard stick like that... but I couldn't even use such a large one! My print bed is only ~11" x 11". I'll look for it's younger sibling. And possibly metric, too.
                    • markzundefined
                      markz @bot
                      @bot Yeah, I wish I had a metric one - if you watch the video I spend a lot of time converting inches. Kinda dumb.
                      backstory - when I first realized about 10 years ago my CNC had so much error I did this measurement with a normal yardstick, couldn't believe the results (especially the Y error), so in order to root-cause I had no choice.
                      • markzundefined
                        markz
                        I've cleaned up the code so setting a screw map entry changes the DRO readout in real-time.
                        Here are a couple of plots of my CNC error curves with increment=25.4mm (1 inch). Note the 2d-ishness of the whole thing.
                        To put this in a worst case if I were just drilling holes the largest X error pre-compensation would be about 1.5mm (or 1/16th of an inch for US). Post-compensation error is 2*repeatability + test measurement error (~.03mm).
