    Request Cartesian with cyclops system: 2 extruders and 1 hotend
    Example setups and prints
    1.9k
    • FelixHundefined
      FelixH
      Hi there,
      I will get to the point. Does somebody have and example of config.g file of a cartesian printer with two extruders on a single hotend? I've neved done multi-color and I'm quite confused...
      Thanks in advance!
        How's this?
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
        M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                            ; map heated bed to heater 0
        M143 H0 S150                                       ; set temperature limit for heater 0 to 150C
        M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
        M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S275                                       ; set temperature limit for heater 1 to 275C
        M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
        M563 P0 D0 H1 F0                                   ; define tool 0
        G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
        G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
        M563 P1 D1 H1 F0                                   ; define tool 1
        G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
        G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
        Two tools, separate extruders, but shared heater.
        • FelixHundefined
          FelixH
          Thanks a lot @Phaedrux . Actually today I had more time that I was anticipating and I was able to search a bit... I came up with a configuration much like you have posted. However it doesn't work for me somehow. The second extruder does not get recognized. When I boot up the console on the PanelDue reads something like this:
          Tool creation: Bad drive number
          I am on RRF3 on a Duet 2 WiFi
          Here is my whole config.g
          ; Configuration file for Duet WiFi (firmware version 3.11)
          ; generated by RepRapFirmware Configuration Tool on Mon Feb 04 2019 17:03:09 GMT+0100 (Central European Standard Time)
          G90                                                ; Send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          ;Panel Due Setup
          M575 P1 B57600 S1
          M550 P"FH-Dual"                                    ; Set machine name
          M552 S1                                            ; Enable network
          M586 P0 S1                                         ; Enable HTTP
          M586 P1 S0                                         ; Disable FTP
          M586 P2 S0                                         ; Disable Telnet
          M569 P0 S1                                         ; Drive 0 goes forwards
          M569 P1 S1                                         ; Drive 1 goes forwards
          M569 P2 S0                                         ; Drive 2 goes forwards
          M569 P3 S1                                         ; Drive 3 goes backwards
          M569 P4 S1                                         ; Drive 4 goes backwards
          M350 X16 Y16 Z16 E16 I1                       	  ; Configure microstepping with interpolation
          M92 X100.00 Y100.00 Z400.00 E408.3          	  ; Set steps per mm
          M566 X600.00 Y600.00 Z18.00 E300.00         	  ; Set maximum instantaneous speed changes (mm/min)
          M203 X10000.00 Y10000.00 Z1000.00 E3600.00 	  ; Set maximum speeds (mm/min)
          M201 X1500.00 Y1500.00 Z100.00 E10000.00 	  ; Set accelerations (mm/s^2)
          M906 X650.00 Y800.00 Z800.00 E800.00 I30  	  ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30
          M208 X0 Y-49.0 Z0 S1                               ; Set axis minima
          M208 X220 Y209 Z200 S0                             ; Set axis maxima
          M574 X1 S3                                         ; Motor Stall X Endstop
          M574 Y1 S3                                         ; Motor Stall Y Endstop
          M915 X Y S30 F0 R0				   ; Stall guard config when not homing
          M574 Z1 S2 	                                   ; Set endstops controlled by probe
          M558 P5 C"zprobe.in" I1 H5 F300 T6000   	   ; Set Z probe type to switch and the dive height + speeds
          G31 P500 X-23 Y7 Z0.35                             ; Set Z probe trigger value, offset and trigger height
                                                             ; The larger the number the closest it gets to the bed
                                                             ; i.e.  1.50 puts the nozzle closer to the bed than 1.20
          M557 X40:210 Y5:190 S20                            ; Define mesh grid
          ; Bed Heaters/Thermistors
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C0 R4700 	    ; Define thermistor
          M950 H0 C"bedheat" T0                                           ; Link pin name with heater
          M307 H0 B0 S1.00				                                ; Disable bang-bang mode for the bed heater and set PWM limit
          M140 H0								                            ; Links everything on the GUI
          M143 H0 S95                                              		; Set temperature limit for heater 0 to 95C
          ; HotEnd Heaters/Thermistors
          M308 S1 P"e0temp" Y"thermistor" T103944 B3943 C1.658e-7 R4700 	  ; Define thermistor
          M950 H1 C"e0heat" T1						                      ; Link pin name with heater
          M143 H1 S290							                          ; Set temperature limit for heater 1 to 290C
          ; Bed / HotEnd Autotunes
          M307 H1 A1048.7 C250.3 D10.3 V24.1 B0                ; Hotend Autotune  //Changed
          M307 H0 A112.6 C601.0 D1.0 V24.1                      ; Bed Autotune //Changed
          M106 P0 S0 H-1                        		   ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 H1 T45                         	   ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1                                      ; Define tool 0
          M563 P1 D1 H1                                      ; Define tool 1
          G10 P0 X0 Y0 Z0                                    ; Set tool 0 offsets
          G10 P0 S0 R0                                       ; Set tool 0 operating and standby temperatures
          G10 P1 X0 Y0 Z0                                    ; Set tool 1 offsets
          G10 P1 S0 R0                                       ; Set tool 1 operating and standby temperatures
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          T0
          If I add the settings for the second extruder to the lines 31 to 36, somehow the extruder 1 doesn't work when I try to extrude. It makes some sound and vibrates, but doesn't extrude. I read somewhere that if the settings are the same it can be skipped (?)
          Needles to say, the second extruder is plugged on Drive 4.
          I hope I can have this sorted out, it's a new printed build from scratch and my first attempt to double extrusion. I'm quite excited...
          Phaedruxundefined 2 Replies Last reply Reply Quote 0
            What firmware are you using on the PanelDue? Might wanna try 3.2.10 that just came out along with 3.2.2 on the Duet.
              Phaedrux Moderator @FelixH
              @FelixH said in Request Cartesian with cyclops system: 2 extruders and 1 hotend:
              I think the problem is that you have a second extruder drive defined in the tools, but you don't actually have a second extruder drive defined anywhere else.
              M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X100.00 Y100.00 Z400.00 E408.3 ; Set steps per mm M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min) M203 X10000.00 Y10000.00 Z1000.00 E3600.00 ; Set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2) M906 X650.00 Y800.00 Z800.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
              • FelixHundefined
                FelixH
                I've just added the additional settings for the second extruder and still doesn't seem to work. On the web interface I cannot use the second extruder either.
                I don't think the PanelDue is to blame, but just for the sake of being up to date, I will update everything tomorrow
                  Do you still get the same error message after adding the drive details?
                  The second drive would only be active when the second tool is selected. How are you trying to control it?
                  • FelixHundefined
                    FelixH
                    It is still not recognizing the additional tool. I was trying to select it by sending T1 to the console, which only greys-out the extrude/retract buttons on the web interface (even though I allowed cold extrusion).
                    I made a picture of the console on the panelDue:
                    • FelixHundefined
                      FelixH
                      UPDATE: just updated to 3.2.2 and nothing changed
                        Can you try copy and pasting the config sample I posted and trying that?
                        • FelixHundefined
                          FelixH
                          Just did, no change.
                          At this point I am wondering if it is at all possible a hardware error, like a bad crimped cable or something like that.
                            Is it still giving error messages like shown on the paneldue?
                            • FelixHundefined
                              FelixH
                              Yeah, but I have a new lead. Hold on
                              • FelixHundefined
                                FelixH
                                So, when I turn on the printer a whole lot of error codes flashed on the PanelDue screen. It was so fast, I had to recorded with my phone with the Slow-Mo option. The errors are as follows:
                                Error in the macro file line 32 column 32: M350 array too long, max length = 1
                                Error in the macro file line 33 column 34: M92 array too long, max length = 1
                                Error in the macro file line 34 column 34: M566 array too long, max length = 1
                                Error in the macro file line 35 column 41: M203 array too long, max length = 1
                                Error in the macro file line 36 column 35: M201 array too long, max length = 1
                                Error in the macro file line 37 column 35: M906 array too long, max length = 1
                                So I checked the documentation and I changed this snipped:
                                M350 X16 Y16 Z16 E16:16 I1                        ; Configure microstepping with interpolation
                                M92 X100.00 Y100.00 Z400.00 E408:408          	  ; Set steps per mm
                                M566 X600.00 Y600.00 Z18.00 E300:300         	  ; Set maximum instantaneous speed changes (mm/min)
                                M203 X10000.00 Y10000.00 Z1000.00 E3600:3600 	  ; Set maximum speeds (mm/min)
                                M201 X1500.00 Y1500.00 Z100.00 E10000:10000 	  ; Set accelerations (mm/s^2)
                                M906 X650.00 Y800.00 Z800.00 E800:800 I30  	  ; Set motor currents (mA) and motor idle factor in per cent
                                for this one:
                                M350 X16 Y16 Z16 I1                  		      ; Configure microstepping with interpolation
                                M350 E16:16                        				  ; Configure microstepping with interpolation
                                M92 X100.00 Y100.00 Z400.00                 	  ; Set steps per mm
                                M92 E408:408          	                          ; Set steps per mm
                                M566 X600.00 Y600.00 Z18.00         	          ; Set maximum instantaneous speed changes (mm/min)
                                M566 E300:300         	                          ; Set maximum instantaneous speed changes (mm/min)
                                M203 X10000.00 Y10000.00 Z1000.00 	              ; Set maximum speeds (mm/min)
                                M203 E3600:3600 	                              ; Set maximum speeds (mm/min)
                                M201 X1500.00 Y1500.00 Z100.00 	                  ; Set accelerations (mm/s^2)
                                M201 E10000:10000 	                              ; Set accelerations (mm/s^2)
                                M906 X650.00 Y800.00 Z800.00 I30  	              ; Set motor currents (mA) and motor idle factor in per cent
                                M906 E800:800 I30  	                              ; Set motor currents (mA) and motor idle factor in per cent
                                Unfortunatelly, however. Nothing changed.
                                • FelixHundefined
                                  FelixH
                                  I have no M584 command. I think that's it. Going to see the documentation.
                                  UPDATE: so, that was it. I had no M584 mapping command. I read it completely by chance while reviewing the M305 command... Anyway now it works as I expected on both the web interface and the PanelDue display.
                                  Thanks for sticking with me @Phaedrux
                                  • FelixHundefined
                                    FelixH
                                    If somebody lands on this thread looking for the same info as I was, here you have it. This is what did it after some headaches:
                                    ;Panel Due Setup
                                    M575 P1 B57600 S1
                                    M584 X0 Y1 Z2 E3:4                                 ; Driver 0 controls the X motor, 1 controls Y, 2 controls Z motors, 3 and 4 control E motors
                                    M84 S30
                                    T0
                                    T1
                                      M584 X0 Y1 Z2 E3:4
                                      • o_lampeundefined
                                        o_lampe @Phaedrux
                                        @Phaedrux
                                        Just out of curiosity, now that the drive mapping is added, would it still be necessary to have separate jerk-, acceleration-, etc- setting for the second extruder?
                                        Is it even possible to have different settings?
                                        [OT]
                                        Like different steps/mm for a geared direct drive mixed with a remote Bowden extruder?
                                        • FelixHundefined
                                          FelixH
                                          I will try to see if it still works if it has only half of the settings. I have no idea...
                                          Why wouldn‘t be possible to have different settings? What would be the point to have the possibility to set two settings if it wasn‘t?
                                          o_lampeundefined 2 Replies Last reply Reply Quote 0
                                          • o_lampeundefined
                                            o_lampe @FelixH
                                            @FelixH
                                            Right, it's just a bad gutt feeling.
                                            I remember, some settings had to be identical or be ignored if you set them different.
