Need help to connect Heated bed to Duet 3
Hi everybody
I don't find what I'm doing wrong...
I'm trying to connect an heated bed to Duet 3, Thermistor on IO PIN4
Here is the code :
M308 S0 P"io4.in" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor M950 H0 C"bedheat" T0 ; Bed heater M140 H0 ; Add heater to bed after RRF3.01 RC10 M143 H0 S120 ; Set temperature limit for heater 0 to 120C
I get -271°C on DWC
I checked the thermistor (about 120k ohm at room temp).
Thanks by advance
you can't use IO's for temperature measurement.
you need to use a proper temperature input such as temp0 -
Ok, thanks.
Tried this without success after changing pin sensor to temp0 :
M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4725 C7.06e-8 ; Set thermistor M950 H0 C"bedheat" T0 ; Bed heater M140 H0 ; Add heater to bed after RRF3.01 RC10 M143 H0 S100
that code looks find to me. I assume you've moved the connection to the temp0 input?
Yes I changed to temp0 on board...
Where's the M307 command?
Fiannly it worked with :
M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 M950 H0 C"out0" T0 ; create heater and map sensor 0 M140 H0 M143 H0 S100
Thanks !
Are you sure that's the correct thermistor for your bed? Also looking at my config.g set up via the online config tool it appears your missing a commands.
M308 S0 P"temp0" Y"thermistor" A"Keenovo Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C
