Need help to connect Heated bed to Duet 3
316
    duetlover
    Hi everybody
    I don't find what I'm doing wrong...
    I'm trying to connect an heated bed to Duet 3, Thermistor on IO PIN4
    Here is the code :
    M308 S0 P"io4.in" Y"thermistor" A"Bed" T100000 B4138 C0 ; Set thermistor
    M950 H0 C"bedheat" T0 ; Bed heater
    M140 H0 ; Add heater to bed after RRF3.01 RC10
    I get -271°C on DWC
    I checked the thermistor (about 120k ohm at room temp).
    Thanks by advance
      jay_s_uk
      you can't use IO's for temperature measurement.
      you need to use a proper temperature input such as temp0
        duetlover
        Ok, thanks.
        Tried this without success after changing pin sensor to temp0 :
        M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B4725 C7.06e-8 ; Set thermistor
        M143 H0 S100
          jay_s_uk
          that code looks find to me. I assume you've moved the connection to the temp0 input?
            duetlover
            Yes I changed to temp0 on board...
              fcwilt
              Where's the M307 command?
                duetlover
                Fiannly it worked with :
                M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8
                M950 H0 C"out0" T0 ; create heater and map sensor 0
                M140 H0
                M143 H0 S100
                Thanks !
                undefined 1 Reply Last reply 18 Feb 2021, 17:21 Reply Quote 0
                  Rushmere3D @duetlover
                  @duetlover
                  Are you sure that's the correct thermistor for your bed? Also looking at my config.g set up via the online config tool it appears your missing a commands.
                  M308 S0 P"temp0" Y"thermistor" A"Keenovo Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
                  Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
                  8 out of 8
