    RepRapFirmware 3.3beta1 now available
    Beta Firmware
    12
    36
    2.7k
      We don't have the resources to do an LTS version, however we do patch releases to older firmware versions sometimes, for example 2.05.1 and 3.2.2.
      • tristanryerparkeundefined
        tristanryerparke
        This release has made sammyc21s not communicate with the main board. I couldn't find a sammy specific firmware file in the releases. I was previously running the 3.3 beta you shared on dropbox which had sammy specific files. Should I update them to a specific version other than where they are now?
        Thanks,
        T
          Users normally build the SAMMYC21 firmware themselves so they can modify it, however there is a prebuilt one for 3.3beta1 at https://www.dropbox.com/sh/mab3zs4h6bnwq3r/AABYyJanpjalGm2JA9WWUR3aa?dl=0.
            tristanryerparke
            @dc42 Thanks again,
            I am just using the SAMMYC21 for servo control, working now.
            • Nuramoriundefined
              Nuramori
              @dc42 For the toolboard v1.0, does the sam21 file need to be upgraded to 2.2? I haven't had luck with being able to update from 2.1 to 2.2
                dc42 administrators @Nuramori
                @Nuramori said in RepRapFirmware 3.3beta1 now available:
                If you mean the bootloader, it doesn't need to be updated.
                • oliofundefined
                  oliof
                  Has this been packaged for SBC builds? I am getting 3.2.2 still from the unstable feed.
                    dc42 administrators @oliof
                    @oliof said in RepRapFirmware 3.3beta1 now available:
                    No, because currently it it intended to be used with DWC and DSF 3.2.2. That will change when we release a beta that needs a new DSF.
                    Stephen6309undefined 1 Reply Last reply Reply Quote 1
                    • Stephen6309undefined
                      Stephen6309 @dc42
                      @dc42 On my 6HC with a PI 4, did a update/upgrade and 3.3beta1 didn't install.
                      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
                      pi@CXY-MSv1:~ $ sudo apt-get update
                      Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.8 kB]
                      Get:2 http://packages.microsoft.com/repos/code stable InRelease [10.4 kB]
                      Get:3 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
                      Get:4 http://packages.microsoft.com/repos/code stable/main arm64 Packages [14.2 kB]
                      Get:5 http://packages.microsoft.com/repos/code stable/main armhf Packages [14.2 kB]
                      Get:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [13.7 kB]
                      Hit:7 https://pkg.duet3d.com unstable InRelease
                      Get:8 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13.0 MB]
                      Get:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [364 kB]
                      Fetched 13.5 MB in 8s (1,661 kB/s)
                      Reading package lists... Done
                      pi@CXY-MSv1:~ $ sudo apt-get upgrade
                      Building dependency tree
                      Reading state information... Done
                      Calculating upgrade... Done
                      The following packages were automatically installed and are no longer required:
                      ffmpeg libjpeg8 rpi-eeprom-images
                      Use 'sudo apt autoremove' to remove them.
                      The following packages have been kept back:
                      libpulse-mainloop-glib0 libpulse0 libpulsedsp pulseaudio
                      pulseaudio-module-bluetooth pulseaudio-utils python-rpi.gpio
                      The following packages will be upgraded:
                      libssl1.1 openssl rpi-eeprom rpi-eeprom-images
                      4 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
                      Need to get 2,520 kB of archives.
                      After this operation, 488 kB of additional disk space will be used.
                      Do you want to continue? [Y/n] y
                      Get:1 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom armhf 11.7-1 [442 kB]
                      Get:2 http://mirror.us.leaseweb.net/raspbian/raspbian buster/main armhf libssl1.1 armhf 1.1.1d-0+deb10u5 [1,263 kB]
                      Get:4 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom-images armhf 11.7-1 [7,824 B]
                      Get:3 http://mirror.us.leaseweb.net/raspbian/raspbian buster/main armhf openssl armhf 1.1.1d-0+deb10u5 [807 kB]
                      Fetched 2,520 kB in 2s (1,650 kB/s)
                      Reading changelogs... Done
                      Preconfiguring packages ...
                      (Reading database ... 84232 files and directories currently installed.)
                      Preparing to unpack .../libssl1.1_1.1.1d-0+deb10u5_armhf.deb ...
                      Unpacking libssl1.1:armhf (1.1.1d-0+deb10u5) over (1.1.1d-0+deb10u4+rpt1) ...
                      Preparing to unpack .../openssl_1.1.1d-0+deb10u5_armhf.deb ...
                      Unpacking openssl (1.1.1d-0+deb10u5) over (1.1.1d-0+deb10u4+rpt1) ...
                      Preparing to unpack .../rpi-eeprom_11.7-1_armhf.deb ...
                      Unpacking rpi-eeprom (11.7-1) over (11.6-1) ...
                      Preparing to unpack .../rpi-eeprom-images_11.7-1_armhf.deb ...
                      Unpacking rpi-eeprom-images (11.7-1) over (11.6-1) ...
                      Setting up libssl1.1:armhf (1.1.1d-0+deb10u5) ...
                      Setting up rpi-eeprom (11.7-1) ...
                      Setting up rpi-eeprom-images (11.7-1) ...
                      Setting up openssl (1.1.1d-0+deb10u5) ...
                      Processing triggers for man-db (2.8.5-2) ...
                      Processing triggers for libc-bin (2.28-10+rpi1) ...
                      • oliofundefined
                        oliof
                        @Stephen6309 see just the two posts above yours. This is by design, you need to upgrade to 3.3b1 manually.
                        • oliofundefined
                          oliof
                          @dc42 during the update of the toolboard, the toolboard did not recover until I power cycled the printer. After that the tool temperature was reported to be at about 90C which seems to indicate the heater got fully powered either while the Duet3 board was already on 3.3b1 and the toolboard still on 3.2.2, or after getting the update before being power cycled ...
                            @oliof, this (output 0 turns on while up-loading firmware) is a known issue with the first production batch of tool boards using the original bootloader. It can be fixed by installing an updated bootloader. However, I have a report (yet to be investigated) that uploading the bootloader on a tool board doesn't work when running tool board firmware 3.3beta.
                            • oliofundefined
                              oliof @dc42
                              I have an early tool board (v0.6), but i did update the bootloader late last year:
                              M122 B10
                              Diagnostics for board 10:
                              Duet TOOL1LC firmware version 3.3beta1 (2021-02-14 16:34:04)
                              Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2)
                              • User3Dundefined
                                User3D @dc42
                                @dc42 is it any different from 3.3beta release available on dropbox? (released 10-15 days ago)
                                  dc42 administrators @User3D
                                  @User3D said in RepRapFirmware 3.3beta1 now available:
                                  Yes, it's more recent. There is an even more recent one at https://www.dropbox.com/sh/q5uqqkjbmhgvlhq/AACYqG0ynLME9ogoLd1zLB2Xa?dl=0 but it should only be used if you need the new features in it, described at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3_Beta.md.
                                  • oliofundefined
                                    oliof
                                    The deprecation of G10 for setting tool temperature is a bit awkward as PrusaSlicer only recently implemented support for using G10 for RepRapFirmware temperature control ...
                                    • chrishammundefined
                                      chrishamm administrators @oliof
                                      @oliof We'll undo the deprecation notice in the next beta, please ignore it for now.
                                      Duet software engineer
                                      • stewwyundefined
                                        stewwy
                                        Having a slight problem when I change from 3.2 to 3.3 beta 1 my z-probe does not work
                                        from my config.g file
                                        M558 P8 C"^!zprobe.in" H3 F500 T9000 ; set Z probe type to unfiltered(8) and the dive height + speeds (inductive probe via optocoupler)
                                        G31 P500 X-32 Y-26 Z3.020 ; set Z probe trigger value, offset and trigger height
                                        M557 X5:235 Y25:235 S15 ; define mesh grid
                                        Is my config a problem I checked the notes and could not see any indication of change
                                        The probe is a highly accurate industrial probe,
                                          dc42 administrators @stewwy
                                          @stewwy said in RepRapFirmware 3.3beta1 now available:
                                          Which Duet?
                                          • stewwyundefined
                                            stewwy
                                            Duet wifi 1.03
                                            Should also note that it was constantly triggered (.i.e. the triggered light was on constantly)
