    Designing a PWM to Analog mini board for fans
    139
    12.4k
    • ZipZapundefined
      ZipZap @Egon.Net
      @Egon-Net said in Designing a PWM to Analog mini board for fans:
      milliseconds, not seconds! ๐Ÿ˜„
      yeah, thats more logical ๐Ÿ‘
      Most important guide -> Triffid Hunter's Calibration Guide
      HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
      • Egon.Netundefined
        Egon.Net @zapta
        @zapta said in Designing a PWM to Analog mini board for fans:
        Real max Vmax then should be Voutmax from opamp - Vbe from transistor
        May be worth adding a few components to achieve a more ideal requirement set. For example,
        1. No significant voltage drop at max voltage (as it is with the existing PWM).
        2. Decoupling pwm input voltage from output voltage. E.g. 12V in, 24V out or vice versa, or 3.3 or 5V PWM input and 12V outout.
        3. Preserving the common (+) of existing PWM driven fans. (your design seems to change it to common (-)).
        Other stretch goals are high efficiency (no heat when running at let's say 50%) or galvanic input isolation (opto coupler?).
        Just a thought.
        Overall, your idea for a PWM -> Voltage fan control is very good and much needed.
        Hi @zapta! I'll try to answer in order:
        1. The voltage drop issue is hard to resolve. I can only think in two ways for achieving it: some kind of step-up voltage converter, or going full signal filtering. The step-up will add quite a bit of complexity and would force the output voltage to be fixed (12V? 24V?), and I want to avoid a full signal filter, because it would use quite big inductors, that end up being big, heavy and expensive. I've been looking at opamps/BJT combos that allow me to stay within 0.5V of VCC, and I think I can live with it. I will have a look at existing integrated PWM to Analog too (I think analog devices makes such an IC), because yes, it would be nice to go up to the supply rail.
        2. Decoupling is more or less done already. I can further add a voltage divisor and add later gain in the filter so you could use any voltage combo, even things like 3.3v -> 24V
        3. I think I haven't understand you correctly. You use the PWM+ wire from Duet. In the base design you use both PWM+ and PWM- (they are called Fan+ and Fan-). Duet's do the PWM on the ground side (PWM-), so you can use any voltage for the fan.
        Regarding the other comments, heat is unavoidable once you give up filtering in full signal, because there must be some analog component that does the regulation (we are not switching voltages) but since we are dealing with currents <100mA, it should stay well under 1W. And IMHO adding galvanic isolation is out of the question for the complexity it would add when we are just dealing with fans...
        Thanks for your comments, that's really what I need to help me think out of the box! You never know what one's maybe missing!
        • Egon.Netundefined
          Egon.Net @achrn
          @achrn said in Designing a PWM to Analog mini board for fans:
          @achrn you schematic is ok because you are supplying 24V for a 12V fan. Mosfets have quite a high gate voltage that will substract from supply voltage, so voltage applied to the fan will not be able to reach near 24V (final voltage will depend on the mosfet used).
          Exactly, which is why I caveated with the observation that I was using what I had to hand. The opamp output swing limits it further too - it doesn't get the gate to 24V either (even if teh PWM was coming in at 24V). Sorry, I should possibly have been more explicit that I wasn't advocating it as a great circuit (which, again, is why I might be interested in a better implementation).
          There's a moderate heatsink on teh mosfet.
          I've just tested TLV9352 as the opamp and TIP41A as the BJT, and it leaves me at 0.5V from supply voltage. It might be quite difficult to get better than that with this kind of schematic...
          • taconiteundefined
            taconite
            Ill get a hand full if Brexit is not going to make shipment to Germany crazy expensive. Are you heading for SMD or through hole components?
            This is not only super convenient for Fans but i will use this analog voltage to control some LEDs with an Arduino Nano
            Custom ANET A8
            Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
            All I do here is under this license: CC BY-NC-SA
            Egon.Netundefined 2 Replies Last reply Reply Quote 0
            • Egon.Netundefined
              Egon.Net @taconite
              Thanks @taconite! I'm going for smd, but not crazy difficult to solder (just 0805, soic8...) Depending on how many people want some boards and their ability to solder smd, I can offer sending boards already populated with smd components.
              Regarding controlling leds, why don't you directly feed PWM to the leds? If your PWM frequency is high enough, you can't see the flicker at all...
              • Egon.Netundefined
                Egon.Net @taconite
                @taconite also remember the current limits... I don't think this kind of circuit is good for more than ...200mA? The BJT will dissipate quite a bit of power by itself at moderate currents, but it depends too on supply voltage (5V would draw much less power).
                • Egon.Netundefined
                  Egon.Net
                  I thing I'll leave and option to feed the opamp/transistor with an external power, using something like that:
                  https://es.aliexpress.com/item/32991262761.html?spm=a2g0o.productlist.0.0.c6d348aeYWNiwE&algo_pvid=c960f66a-a365-467c-86d4-8d056bf41f04&algo_expid=c960f66a-a365-467c-86d4-8d056bf41f04-10&btsid=0b0a119a16138225307124650e5472&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                  so you can jumper select the power supply.
                  Thoughts?
                  • Egon.Netundefined
                    Egon.Net
                    Ok, I had a spin at the schematic. That would the plan:
                    INPUTS:
                    PWM+
                    PWM-
                    GND
                    Optional V_EXT
                    JUMPERS:
                    V_ANALOG (PMW+ or V_EXT)
                    HALVE_IN (shorted=yes)
                    SCALE_OUT (shorted = no)
                    OUTPUT
                    Analog V_OUT
                    EXPLAINING
                    Duets use PWM+ as V_FAN, PWM- as pwm'd ground.
                    With HALVE_IN open, SCALE_OUT closed, VOUT follows PWM input up to V_FAN-0.6V. Rise time is about 140ms.
                    You can use a external step up converted (1โ‚ฌ in Aliexpress for a 28V 2A max) connected to V_EXT and then select jumper V_ANALOG to V_EXT and get max fan voltage. With just one step up you can feed many fans.
                    You can also connect an external (arduino?) PWM voltage to PWM+ with any voltage and any power supply to V_EXT, and output would follow (3.3V, 5V, 12V...) You cannot use a PWM+ voltage greater than V_EXT. If you set HALVE_IN short, input is automatically halved, so you can use a 24V PWM+ with a 12V V_EXT, for example.
                    And last, if you short jumper SCALE_OUT, PWM+ voltage will be ignored and V_OUT will be PWM % of V_ANALOG.
                    This is the schematic for reference:schematic2.png
                    It would use a dual smd opamp (TLV9352, 0.7-1โ‚ฌ ) some resistors/capacitors (smd 0805, ~cents), a through-hole mid-power BJT (like BD139, ~0.5โ‚ฌ) and some jumper pins, plus board (less than 1โ‚ฌ) and shipping costs for everything. The transistor must be heatsinked for any significant current.
                    Does it sound interesting? Would you get some of this boards?
                    • zaptaundefined
                      zapta @Egon.Net
                      What I mean is that the duet uses a low side transistor and common (+) connection, with this design, the transistor is on the high side and the fans have common (-) connection.
                      • zaptaundefined
                        zapta @Egon.Net
                        How did you calculate this? Supply voltage - 0.6V VBE for Q505?
                        Do you assume that the U2B output can go all the way to the V_ANALOG voltage? This is not the case with most op amps. Did you verify that this is indeed the case?
                        Changing the design to use a non emitter follower configuration may eliminate the need for the OPAMP to go all they way to the rail voltage. Can be a PNP on the high side or NPN on the low side (or P or N channel respectively if you prefer mosfets).
                        (I am not an EE so please take it with a grain of salt).
                        • hackinistratorundefined
                          hackinistrator
                          is this all necessary ?
                          did you try just adding capacitor in parallel with the fan to reduce whining ?
                          duet also allows changing pwm freq . i think with a bit of freq tuning , adjusting min/max duty cycle and simple capacitor should solve all those issues without extra circuits .
                          Egon.Netundefined 1 Reply Last reply Reply Quote 0
                          • zaptaundefined
                            zapta
                            @hackinistrator said in Designing a PWM to Analog mini board for fans:
                            I think it's necessary since nothing prevents the capacitor from always getting charged to max voltage.
                            Here is a design idea, it's incomplete but demonstrates the principle. It uses low side transistor (a NCHAN mosfet would be a better choice IMO), to keep the common fan control model, is not penalized by VBE dropout, and relaxes the rail to rail requirements of the opamp. It can work with split vin/vout supplies or can be simplified to support a single supply.
                            This is just an idea, not a complete design and may require some capacitors and other stuff for stabilization, a led or two for diagnostics, a fuse (?), and so on.
                            (I am not an EE so please take this with a grain of salt).
                            • Egon.Netundefined
                              Egon.Net @zapta
                              Now I get what you mean about the common(+), you meant the output side! I thought it was about the input side, that's why I didn't get it. Now, entering your circuit:
                              I can see two stages, first one is a rail to rail comparator, resistive halver, and a single pole low pass filter. It's a valid one, but I'd prefer to use an opamp (from the dual opamp IC) so I don't have another IC. I also prefer a second order lowpass (it has better ripple/settle time), but I see no problem in your approach (other than that you loose PWM magnitude/active high compatibility).
                              It is the second stage that worries me: you have used a positive-feedback opamp configuration, relying in the BJT inversion, instead of using negative feedback. I'm afraid it could be unestable because of the delay in the feedback though the inverting BJT. And you would need a diode between the opamp and the BJT, since the opamp would not be able to reach GND flat, but that's no problem.
                              Let me have a look at your circuit and do some simulations. All in all, I like your feedback because this is a topology I didn't think about, and it's interesting (I'm so biased to analog audio circuits!)
                              I'll return one I have done some test!
                              • Egon.Netundefined
                                Egon.Net
                                I just simulated the second stage of your circuit, and it's quite prone to oscillating, even with an ideal opamp... I should test the real thing to be sure, maybe we run out of phase margin with the BJT capacitance in the feedback loop. Besides that, I don't really belive my simulation results, it tells me I get full 24V into the load when at least a Vce-sat (~0.2V) should be lost in the BJT.
                                Also, it's only valid for a rail to rail signals, since it inverts the input and any less of rail to rail would float from +VCC... So we lose the capability of tracking PWM magnitude... Do we really need it?
                                I'll post again when I build a protoboard with the circuit.
                                • Egon.Netundefined
                                  Egon.Net @hackinistrator
                                  It's not just whining, lots of fan don't even work, or lose all speed in 99% PWM already.
                                  Also you can change frequency in the Duet's, but not in de Duex.
                                  A capacitor does nothing by itself, because the charge/discharge would not be controlled, so it would range from not doing anything at all, to override PWM an making the fan work at 100%. Believe me, I've tinkered a lot before I decided to go this route.
                                  • zaptaundefined
                                    zapta @Egon.Net
                                    @Egon-Net, your analysis of the circuit is correct. A couple of notes:
                                    1. The only rail to rail requirement in this design is the output of the first amplifier. It's easy to achieve that with a comparator since they don't need to be linear and can just saturate the output transistor.
                                    2. For the off condition of the power transistor, instead of a diode you can use a resistor between base and emitter such that VBE is below the cutoff voltage when the op amp is at its lowest output value.
                                    3. Stability and dynamic behavior is above my pay grade. When something oscillates I just stick capacitors. ๐Ÿ˜‰ (I am not an EE).
                                    4. I don't think we can about the magnitude of the input signal, just about its duty cycle and the comparator preserves that.
                                    5. I would also add a resistor in parallel to the fan such that the circuit provides the correct output voltage also without load.
                                    6. What simulation software do you use? Looks nicer than the freebies I could find.
                                    • Egon.Netundefined
                                      Egon.Net @zapta
                                      My notes to your notes ๐Ÿ™‚
                                      1. The opamp I was going to use (TLV9352) is even more rail to rail (50mv from rail at 10K IIRC) than that comparator, so I can go with the comparator 1st stage without adding a second IC ๐Ÿ™‚
                                      2. I don't think so. I will simulate it, but I think it will only force the opamp to source more current, and not improve the off state of the BJT, but I may be wrong. A diode forces 0.6V voltage drop irregardless of the current. Any suggested resistor value to try?
                                      3. I am myself an EE, but not working as it, so I'm quite rusty. But I've been doing a lot of DIY audio stuff design, and I'm very used to opamps oscillating because of the feedback loop/load capacitance/whatever. Analog electronics is "fun" XD
                                      4. Yes, I agree losing magnitude is a good deal for going rail to rail. U can always chose a external supply to scale to your heart's desire.
                                      5. I agree. I already thought of that, and it will be present in the final version.
                                      6. I use National Instruments' Multisim since my early years as a Comm/EE student ๐Ÿ™‚
                                      As soon as I can check stability is not a problem, I will design the final schematic and go to the PCB phase ๐Ÿ™‚
                                      • marceloriderundefined
                                        marcelorider
                                        I'm also in, I've used a small normal rectifier I've found on the internet with a capacitor and whatnot, but I'm still interested.
                                        Portugal based here btw.
                                        Also one note on the fans, they work from 8v to 24v most of them so, would be nice to develop the board to have that range?
                                        Regards!
                                        • zaptaundefined
                                          zapta @Egon.Net
                                          @Egon-Net,
                                          1 The TLV9352 looks good indeed.
                                          2 Since the TLV9352 can go to 50mv, a VBE resistor may not be needed. If needed, you can make it, let's say, 1/2 of the output resistor, this way once the op amp output gets to 3x0.7V, the current through the VBE resistor will be fixed and any current increase will go to the base.
                                          3 My formal EE education is from a vocational high school so not that deep. I watched though some stability videos on youtube recently and start to grasp the concept. https://www.youtube.com/watch?v=-CS5th2zKWY
                                          6 I tried multisim two days ago, it was very easy to use but I didn't see much of a part library, maybe because I used the free version. I then installed LTSPICE which is more rough but very popular.
                                          • Egon.Netundefined
                                            Egon.Net
                                            Hi again!
                                            I got the Tina-TI model of TLV9352 opamp and simulated the circuit as faithfully as I could. Depending on the input, I can get it to oscillate, but a capacitor in the feedback loop seems to get rid of the oscillation. Now, worst case just rings (when I apply a fast rising clock direct to opamp input, not real use), so I'll put the capacitor in the PCB and test with and without the capacitor.
                                            Using the opamp model, there's no need for a VBE resistor (you where right @zapta) and max voltage is 23.82V (which is a beliebable output). Tina seems to simulate better than Multisim.
                                            I just ordered the components for a 10 boards test batch (since I needed to order some components for other project). I'll order a PCB batch too, and report, but will take 15 day the less for the PCB to arrive.
                                            I think is time to count how many board you all will need:
                                            PWM signal support:
                                            • Open drain active low (Duet), 20k impedance
                                            • VCC level PWM (0.05ยทVCC to VCC with 10k impedance or 0.1ยทVCC to VCC 20k impedance)
                                            Output
                                            • Scaled %PWM from VCC
                                            • VCC range: 4.5V - 40V
                                            • Current depends on power transistor, planned BD139
                                            Are you interested in single PWM board or dual(more?) PWM board?
                                            ZipZapundefined zaptaundefined 2 Replies Last reply Reply Quote 0
