    Smart Effector including toolboard-capabilities?
    Smart effector for delta printers
    smart effector future development hardware delta
    19
    113
    12.0k
    • mrac1undefined
      mrac1 @o_lampe
      @o_lampe
      I have tested various types of mounting and could not find any difference. As it is in the current version, the mounting is the easiest.
      • garyd9undefined
        garyd9 @mrac1
        @mrac1 said in Smart Effector including toolboard-capabilities?:
        @garyd9
        One more thought, how strong is the effect of the magnets when they come closer together?
        While using the smart effector, the "b" mentioned above is only 12mm. The magnets don't seem to have any effect on anything else on the effector.
        I do tend to keep the polarity of adjacent magnets opposite of each other. That's supposed to somehow cancel or mitigate the impact of any magnetic fields (if the things I've read are true.)
        @o_lampe said in Smart Effector including toolboard-capabilities?:
        @garyd9 and @mrac1
        I was wondering if the bracket that bolts the extruder down to the smart effector PCB influences the strain gauge touch sensor? The PCB get's much stiffer IMHO and reduces the reading. Is a higher impact force needed to trigger the touch probe?
        On the zesty nimble, the adapter mounts using the same screw holes as mrac1's adapter: the three surrounding the heatsink hole. (see: https://www.thingiverse.com/thing:2453322) I can't say if that impacted the trigger strength needed, as I've never used the smart effector without a similar type of adapter.
        I will mention that, due to vibrations on my builds linear rails, I've had to reduce the sensitivity of my smart effector using "m672 s105:90:165". With that in effect, my smart effector's trigger height is currently at -0.09. Without adjusting the sensitivity, the trigger height was around -0.06.
        One more disclaimer is that my Smart Effector might be dying. I can't say if this is due to the nimble adapter or something else. There's no noticeable damage or scratches, but the SE does the "6 flashes" on boot up for about 2 1/2 minutes every power up and then suddenly decides that everything is okay. (That's a topic for another thread, however. The effector is well outside of warranty, and I won't be upset if I have to replace it. I just hope it lasts long enough for duet3d's combined tool board and smart effector to be released.)
        • garyd9undefined
          garyd9
          If it's useful to anyone, here is the fusion360 sketch I used for calculating effector spacing. Rename the file extension to "f3d" (because the duet forum won't allow .f3d file attachments) and pull it into fusion360.
          There's nothing in this project except a single sketch. There are three editable parameters (Modify->"Change Parameters"):
          ArmSpacing: this is obvious. 55mm is the spacing on the current smart effector
          DesiredTES: This is the "TES" value from the article I linked above. The smart effector has a value of ~252.08. Larger values theoretically result in a more tilt resistant effector.
          MagBallHoleSize: (This is just the size of the circles used to indicate magball locations)
          Hole Spacing v1.f3d.g
          • o_lampeundefined
            o_lampe @garyd9
            @garyd9 said in Smart Effector including toolboard-capabilities?:
            Well, IIRC they can make your fans stop if mounted too close to the magnets. But that's another story.
            Good to hear the SE is not affected by the current mounting method.
            I've seen BMG hardware kits for sale without housing. Are they complete or do I have to print gears to use your version? (Yuck)
            BTW: it deserves a name! How about Smart-Orbiter?
            garyd9undefined 1 Reply Last reply Reply Quote 0
            • garyd9undefined
              garyd9 @o_lampe
              I couldn't find any such kits. I ended up going on filastruder and ordering: 1 LDO 36STH17-1004AHG, 1 Bondtech drivegear kit (1.75/5mm), 1 bondtech thumbscrew assembly (that I likely won't use), and 1 Bondtech shaft/gear assembly.
              Then I had to order the MR85ZZ bearings from amazon (because filastruder didn't have the correct size available.)
              The "bondtech" drivegear kit is supposed to contain: "Gear set for filament size 1.75 mm, primary gear with inner diameter 5 mm, secondary gear with two needle bearings,M3x2 setscrew and one 3 x 20 mm shaft"
              The LDO stepper motor has a gear in place of a shaft.
              From what I can tell of the diagram, you shouldn't need to print any gears. Only 4 housing pieces. I'm guessing that they can be printed with PETG, but I'm not sure how hot the LDO stepper might get. (I doubt it'd get over 70C, but if it does, I can reprint the plastic with a hybrid PC+.)
              In my files, I'm calling it "mrac1 mini extruder", so I agree that it needs a name. To me, the orbiter is a completely different extruder.
              mrac1undefined 2 Replies Last reply Reply Quote 0
              • o_lampeundefined
                o_lampe
                I was on the wrong path and thought it was a reused Orbiter. But it's the orbiter motor w/o the planetary gears? I think, I have to read the whole thread again...
                • garyd9undefined
                  garyd9 @o_lampe
                  There have been 4 different extruders discussed in this thread (that I noticed):
                  You posted something that references an extruder from a thread on the reprap forums. (Cycloidal direct drive.)
                  The actual "orbiter" extruder (as found on thingiverse and for sale via LDO distributers along with aliexpress clones already.) This one uses 3 planetary gears around the LDO motor's stepper gear for a ~7:1 ratio.
                  apak posted some pictures and a video, and mentioned it was based on the orbiter design, but allows pivoting (so it might work fine with 55mm arm spacing.) As far as I'm aware, no more information was posted about this extruder.
                  mrac1's extruder (that I think might predate the orbiter.) It's closer to a rebuilt BMG, but uses the LDO motor's built in gear instead of the BMG motor gear attached to a stepper's 5mm shaft. (The smaller LDO gear results in a 5:1 ratio instead of a 3:1 ratio from the BMG.)
                  o_lampeundefined 1 Reply Last reply Reply Quote 1
                  • mrac1undefined
                    mrac1 @garyd9
                    Yes, there are no extra gears to print. The LDO motor remains under 40° (motor current to 370 mAh) Except the fan duct, my hole effector and extruder ist printed in PLA.
                    • mrac1undefined
                      mrac1 @garyd9
                      Sounds good 😉
                      In my files I call it D3E (DeltaDirectDriveExtruder)
                      • o_lampeundefined
                        o_lampe
                        It deserves a smart before the D3E, now that it's re-tailored for the Smart effector.
                        5:1 ratio is enough torque for a fast Delta or are there speed limits?
                        The magballs in your effector are different from Haydn original ballstuds, what ball-diameter do they need?
                        I'm asking, because I've once designed a Delrin ball effector, which is much lighter, because no steelballs or magnets are needed. I might try to glue in 10mm Delrin balls...(one for each rod this time)
                        mrac1undefined 1 Reply Last reply Reply Quote 0
                        • o_lampeundefined
                          o_lampe @garyd9
                          I'm beginning to see the light!
                          @apak showed two different designs, but only one is working now.
                          The other -with the split motor/planetary gearbox- is also quite interesting, since the BMG gears are available with 8mm ID.
                          Enough room to bypass the extended shaft for the star-wheel.
                          //edit there would be three parts needed to guide the motion back and forth: stepper shaft and starwheel-shaft both have to share the room inside the BMG wheel...pretty tight 😞
                          • mrac1undefined
                            mrac1 @o_lampe
                            It's tested up to 100 mm/s (normally I do not print faster than 80 mm/s).
                            • garyd9undefined
                              garyd9 @mrac1
                              @mrac1
                              I've been playing with the plastic parts for your extruder and last night I tried a test fit of everything. One issue I noticed was that with the extruder mounted on the effector, I wasn't able to attach the smart effector's 2x3 microfit connector. The extruder's plastic was in the way of the little latch on the connector. (Below are images of the area I'm referring to.)
                              While I can easily make adjustments to the model to make this work, I'm wondering if you encountered the same issue and if so, how you might have handled it.
                              As a side note for @dc42, on the next iteration of the smart effector, would it be possible to rearrange things so that the inner three mounting holes have a good amount of clearance away from other parts that might interfere with mounting? (This might be easier to accomplish on a combined smart effector/toolboard with larger arm spacing.)
                              Dougal1957undefined mrac1undefined 2 Replies Last reply Reply Quote 2
                              • Dougal1957undefined
                                Dougal1957 @garyd9
                                @mrac1
                                I encountered the same issue on my effectors which also uses those mounting holes (For a Zesty Nimble in my Case) the fix for me was to remove the housing on the effector and rotate it by 180 degrees and to wire the lead that connects to it appropriately.
                                Doug
                                garyd9undefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                                • garyd9undefined
                                  garyd9 @Dougal1957
                                  @Dougal1957 said in Smart Effector including toolboard-capabilities?:
                                  That wouldn't help for this particular model. The same interference would be encountered for all three mounting holes (and would actually be worse on the other two.) The nimble adapter works because one of the three mounting holes is only about 3mm high and so sits under the clip for the micro-fit connector.
                                  • o_lampeundefined
                                    o_lampe @Dougal1957
                                    Do you say, the connector was on the bottom side of the SE after the rotation? Or the nose of the housing pointed the other way?
                                    • mrac1undefined
                                      mrac1 @garyd9
                                      You are right, it's to tight there. On my Deltas I'm using my first version without brass inserts.
                                      At this point you could take away some material without getting problems with the inserts, I think. Otherwise - it also works if the screws are simply screwed into the plastic. Then there is enough space at that point.
                                        Dougal1957 @o_lampe
                                        i turned the nose out on the connector @garyd9 the first nimble adaptors (I was the guinea pig there) was just as high as the others that's how my solution helped it just moved the locking Tab to the outer edge of the connector.
                                        Doug
                                        • garyd9undefined
                                          garyd9
                                          @mrac1
                                          Still untested, but thought you might appreciate seeing your work:
                                          Everything printed with a 0.2mm layer height using SnoLabs "atrovirens" PETG. Only 112g including the stepper! (If you take into account all the dust on that scale, the extruder is probably only 111 grams.)
                                          If you ever decide to publish this on thingiverse or something, feel free to use my photo (and I'd be happy to provide some more.) As well, the following might help anyone else that decides to try this out:
                                          You need to really press the BMG 3x20 shaft into the idler lever. Pliers help. If the shaft falls out easily, or if the idler lever doesn't easily close, it's likely not in there properly.
                                          On the motor mount piece and the 3 holes for mounting to the smart effector: I'm able to use just a M3 screw and nut for the front hole, but I couldn't find a good method for securing the rear two holes. I ended up using my "less than 100% reliable" M3x3 brass inserts. They seem to be secure, but only time will tell.
                                          Manually lining up the BMG gear that mounts on the wheel/gear shaft is annoying. It's made much easier by sticking something all the way through the filament path and lining up the gear based on that.
                                          Buying a BMG thumbscrew was a waste for an extruder this tiny. The "thumb" part of the screw rubs against the extruder, and there's just not enough space for the spring. An M3x25 with nylon washer appears to work well enough, but I might try to find a short spring I can use there. I've found that they're useful for irregular filament. (Edit: I found a long M3x40 screw I can use with the thumbscrew spring!)
                                          It might still be a day or so before I'm able to properly test this. I need to verify that 74mm arm spacing will work on my particular printer, and then design/print new carriages.
                                          Take care
                                          Gary
                                          mrac1undefined 1 Reply Last reply Reply Quote 1
                                          • mrac1undefined
                                            mrac1 @garyd9
                                            Yes, a M3 screw is provided here
                                            Looks good, looking forward to seeing pictures of your first prints. Set the retract to 0.6 mm (PLA) and 1.0 mm (PETG) at 50 mm/s.
