    BLTouch and Duet wifi - can't seem to let it work
    Accessories and Add-ons
    631
    • fcwiltundefined
      fcwilt
      @Cinny1988 said in BLTouch and Duet wifi - can't seem to let it work:
      The following is for v2 firmware:
      M307 H5 A-1 C-1 D-1 ; unbind heater pin
      This is for v3, assuming you are using heater 5 on the expansion connector.
      M950 S0 C"exp.heater5" ; create servo 0 on heater 5 pin on expansion connector
      The M558 P parameter value was wrong, the A, R and S parameters were missing, the F and T parameters did not match the comment - see corrected M558 below:
      M558 P9 C"!zprobe.in" H5 F150 T2000 A10 R0.5 S0.3
      This looks OK:
      G31 P500 X25 Y0 Z2.5
      This looks OK:
      M557 X10:280 Y0:240 S20 ; Define mesh grid
      This looks OK:
      M376 H3 ; Taper off compensation over 3mm of height
      Normally you should load the height map at the start of printing - not here in config.g
      M375 ; Load heightmap.csv
      Do you have your deployprobe.g and retractprobe.g files with the correct contents?
      • Cinny1988undefined
        Cinny1988
        @fcwilt said in BLTouch and Duet wifi - can't seem to let it work:
        Dear Frederick,
        Thank you for your feedback.
        I changed the items in the config file but now I get the error z probe already triggered at start of probing move.
        Below are the contents of my deployprobe.g and retractprobe.g files
        M280 P7 S10 I1
        M280 P7 S90 I1
        • Vetiundefined
          Veti
          M280 P7 S10 I1
          M280 P7 S90 I1
          that is rrf2 syntax.
          change to
          M280 P0 S10
            Cinny1988
            Changed the codes to
            M280 P0 S10
            M280 P0 S90
            Currently still get the error that the probe is already triggered at start of probing move.
            • fcwiltundefined
              fcwilt @Cinny1988
              M280 P0 S10
              M280 P0 S90
              Try changing
              to
              M558 P9 C"zprobe.in" H5 F150 T2000 A10 R0.5 S0.3
              • David Greenundefined
                David Green
                This works for me on V3.2.2 Duet Wifi and BLTouch .
                M574 X1 Y2 S4
                :Z-Probe
                M558 P9 C"^zprobe.in" H5 F120 T3000 ; FW v3 BLTouch connected to Z probe IN pin
                G31 P500 X-32 Y13 Z2.9 ; Set Z probe trigger value, offset and trigger height
                M557 X15:225 Y15:225 S20 ; Define mesh grid
                M915 X Y S5 R2
                ; Disable heaters H3-H7 to free up pins
                M950 H3 C"nil"
                M950 H4 C"nil"
                M950 H5 C"nil"
                M950 H6 C"nil"
                M950 H7 C"nil"
                  Cinny1988
                  Thanks everybody for helping me out with this.
                  Unfortunately it's still not working. Good news is that all the errors are gone but the probe itself is not doing anything.
                  When sending the G30 command it now raises the bed but the probe does nothing.
                  David Greenundefined 1 Reply Last reply Reply Quote 0
                    David Green @Cinny1988
                    @Cinny1988 Are you on the correct pin? Your picture looks like you are not on H5. Mine is on pin 9 lower connector you look like you are on H3
                    Cinny1988undefined 1 Reply Last reply Reply Quote 0
                      Cinny1988 @David Green
                      @David-Green mine is indeed on H3
                        @Cinny1988 Change it over I guess either H3 or move pin
                          Cinny1988
                          Yes it finally works!
                          I changed the pin to H5 and adjusted the config information as shared.
                          Thank you all so much for the help.
                          fcwiltundefined 1 Reply Last reply Reply Quote 2
                          • fcwiltundefined
                            fcwilt @Cinny1988
                            Glad to hear you got it all sorted.
                              Phaedrux Moderator @David Green
                              @David-Green said in BLTouch and Duet wifi - can't seem to let it work:
                              M950 H3 C"nil"
                              M950 H4 C"nil"
                              M950 H5 C"nil"
                              M950 H6 C"nil"
                              M950 H7 C"nil"
                              Freeing up pins isn't needed by default in RRF 3.1 and beyond as the pins are free to begin with. You'd only need to free them if you wanted to reconfigure one on the fly.
                              Likewise this is no longer needed in RRF3 either. M307 H5 A-1 C-1 D-1 ; unbind heater pin
                                David Green @Phaedrux
                                @Phaedrux Thanks, I will amend my config.g, not that it seems to have any impact on operation.
