    BLTouch and Duet wifi - can't seem to let it work
    Accessories and Add-ons
    631
    • fcwiltundefined
      fcwilt @Cinny1988
      @Cinny1988 said in BLTouch and Duet wifi - can't seem to let it work:
      Changed the codes to
      M280 P0 S10
      M280 P0 S90
      Currently still get the error that the probe is already triggered at start of probing move.
      Try changing
      M558 P9 C"!zprobe.in" H5 F150 T2000 A10 R0.5 S0.3
      to
      M558 P9 C"zprobe.in" H5 F150 T2000 A10 R0.5 S0.3
      • David Greenundefined
        David Green
        This works for me on V3.2.2 Duet Wifi and BLTouch .
        M574 X1 Y2 S4
        :Z-Probe
        M558 P9 C"^zprobe.in" H5 F120 T3000 ; FW v3 BLTouch connected to Z probe IN pin
        M950 S0 C"exp.heater5"
        G31 P500 X-32 Y13 Z2.9 ; Set Z probe trigger value, offset and trigger height
        M557 X15:225 Y15:225 S20 ; Define mesh grid
        M915 X Y S5 R2
        ; Disable heaters H3-H7 to free up pins
        M950 H3 C"nil"
        M950 H4 C"nil"
        M950 H5 C"nil"
        M950 H6 C"nil"
        M950 H7 C"nil"
        • Cinny1988undefined
          Cinny1988
          Thanks everybody for helping me out with this.
          Unfortunately it's still not working. Good news is that all the errors are gone but the probe itself is not doing anything.
          When sending the G30 command it now raises the bed but the probe does nothing.
          David Greenundefined 1 Reply Last reply Reply Quote 0
            David Green @Cinny1988
            @Cinny1988 Are you on the correct pin? Your picture looks like you are not on H5. Mine is on pin 9 lower connector you look like you are on H3
            Cinny1988undefined 1 Reply Last reply Reply Quote 0
              Cinny1988 @David Green
              @David-Green mine is indeed on H3
                @Cinny1988 Change it over I guess either H3 or move pin
                  Cinny1988
                  Yes it finally works!
                  I changed the pin to H5 and adjusted the config information as shared.
                  Thank you all so much for the help.
                  fcwiltundefined 1 Reply Last reply Reply Quote 2
                  • fcwiltundefined
                    fcwilt @Cinny1988
                    Glad to hear you got it all sorted.
                      Phaedrux Moderator @David Green
                      @David-Green said in BLTouch and Duet wifi - can't seem to let it work:
                      M950 H3 C"nil"
                      M950 H4 C"nil"
                      M950 H5 C"nil"
                      M950 H6 C"nil"
                      M950 H7 C"nil"
                      Freeing up pins isn't needed by default in RRF 3.1 and beyond as the pins are free to begin with. You'd only need to free them if you wanted to reconfigure one on the fly.
                      Likewise this is no longer needed in RRF3 either. M307 H5 A-1 C-1 D-1 ; unbind heater pin
                        David Green @Phaedrux
                        @Phaedrux Thanks, I will amend my config.g, not that it seems to have any impact on operation.
