    Upgrading Firmware.
    Firmware installation
    1.0k
      Post your config.g file instead of the config.json file so we can read it.
      To use an extruder you must have it assigned to a tool, the tool must be selected with T0, and the hotend must be at temp (or have cold extrusion enable).
      mendeleviumundefined 2 Replies Last reply Reply Quote 0
      • mendeleviumundefined
        mendelevium @Phaedrux
        @Phaedrux
        Here you are... Tried to post it entirely but was too big.. but I have the config on its own..config.g
        thanks for any help.
        If you can also assist me...
        I have two extruders, two separate hot ends, and two separate fans.
        the fans run on 12 V and I am controlling them via the negative...
        I hope I am clear...
        When I had the ver 2 firmware the system has a test and when I tested the motors, it went on to test the Z, X and Y together with the 2 extruder motors. The new ver 3 software simply tests X Y and Z..
        Many thanks
        Tonio
          @Phaedrux
          the fans are part cooling fans, both of them. I have a water cooling system for the hot ends
          thanks
          • fcwiltundefined
            fcwilt
            I re-posted your config.g file using the </> tag:
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Feb 25 2021 21:07:52 GMT+0100 (Central European Standard Time)
            G90                                                ; send absolute coordinates...
            M83                                                ; ...but relative extruder moves
            M550 P"MENDELEVIUM 3D HULK TWIN TOOLS"             ; set printer name
            M552 S1                                            ; enable network
            M586 P0 S1                                         ; enable HTTP
            M586 P1 S0                                         ; disable FTP
            M586 P2 S0                                         ; disable Telnet
            M569 P0 S1                                         ; physical drive 0 goes forwards
            M569 P1 S1                                         ; physical drive 1 goes forwards
            M569 P2 S1                                         ; physical drive 2 goes forwards
            M569 P3 S1                                         ; physical drive 3 goes forwards
            M569 P4 S1                                         ; physical drive 4 goes forwards
            M584 X0 Y1 Z2 E3:4                                 ; set drive mapping
            M350 X16 Y16 Z16 E16:16 I1                         ; configure microstepping with interpolation
            M92 X80.00 Y80.00 Z400.00 E420.00:420.00           ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00:120.00         ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00    ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00:250.00         ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800:800 I30                   ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                            ; Set idle timeout
            M208 X0 Y0 Z0 S1                                   ; set axis minima
            M208 X325 Y300 Z280 S0                             ; set axis maxima
            M574 X2 S1 P"xstop"                                ; configure active-high endstop for high end on X via pin xstop
            M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
            M574 Z2 S1 P"zstop"                                ; configure active-high endstop for high end on Z via pin zstop
            M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
            M557 X15:215 Y15:195 S20                           ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                            ; map heated bed to heater 0
            M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
            M308 S2 P"e1temp" Y"thermistor" T100000 B4138      ; configure sensor 2 as thermistor on pin e1temp
            M950 H2 C"e1heat" T2                               ; create nozzle heater output on e1heat and map it to sensor 2
            M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
            M143 H2 S280                                       ; set temperature limit for heater 2 to 280C
            M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
            M563 P0 S"EXTRUDER 0" D0 H1 F0                     ; define tool 0
            G10 P0 X-16.5 Y0 Z0                                ; set tool 0 axis offsets
            G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
            M563 P1 S"EXTRUDER 1" D1 H2 F0                     ; define tool 1
            G10 P1 X16.5 Y0 Z0                                 ; set tool 1 axis offsets
            G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
            M575 P1 S1 B57600                                  ; enable support for PanelDue
            • fcwiltundefined
              fcwilt @mendelevium
              @mendelevium said in Upgrading Firmware.:
              What exactly do you mean by "the system has a test" - was this something you coded?
              mendeleviumundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti
                your thermistor setting is incorrect. b4138 is the default. look up the correct beta value in your thermistor documentation.
                  mendelevium @fcwilt
                  @fcwilt
                  when the duet is switched on the panel due has a test motors button...
                  Dougal1957undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                  • Dougal1957undefined
                    Dougal1957 @mendelevium
                    @mendelevium and what does that button look like as I have never ever seen a test motors button before and I have been using it from the very early days of the Duet WiFi and the panel from before then.
                      mendelevium @Dougal1957
                        droftarts administrators @mendelevium
                        @mendelevium DON'T use the test macros; they're for factory testing, and change the motor settings. Reset your Duet and follow the documentation for testing.
                        Longer explanation: Did you run '04-Test_motors' macro? The macros on the SD card are for testing the Duet at the factory, not for testing your machine. It sets the motor to 2A, as well as trying to move the axes at high speed, and for 2 metres! In the test rig at the factory, it is just a motor, not connected. So please DO NOT USE the macros on the SD card for testing your machine. Follow the commissioning advice here: https://duet3d.dozuki.com/Wiki/Step_by_step_guide#Section_Commissioning_tests
                        If you have these macros on the SD card, this also means you have an older board, as we changed the SD card contents to remove these macros quite a while ago.
                        mendeleviumundefined 1 Reply Last reply Reply Quote 1
                          mendelevium
                          To be honest, I am still testing this printer as I have migrated from ramps.. still my extruder is not running. The extruder buttons on the web console are mot highlighted and unresponsive.
                            mendelevium @droftarts
                            @droftarts thanks for this I will go through it...
                              Phaedrux Moderator @fcwilt
                              @fcwilt said in Upgrading Firmware.:
                              If you have a separate fan for each tool, then your second tool should probably be using fan1. Change the F0 to F1.
                              I'm not a multi tool printer users, but I think it's usually the case that the first tool is set as a zero offset and the other tools are then offset from there. Just keeps things easier.
                              • fcwiltundefined
                                fcwilt @Phaedrux
                                @Phaedrux
                                You replied to me because I reposted his config.g using the </> tag.
                                I don't know if he will be notified of your post or not.
                                  mendelevium
                                  I will go through the tests and see. This is my first twin extruder machine I built. I had very little experience. This printer I have installed Mechaduinos on X & Y. I have soldered STEP AND DIR POINTS on the test points on the board. The mechaduinos I have set the PID settings when it ran Ramps, so I am assuming the PID`s are ok with the duet in use. I have arranged for a dedicated 5V supply to power the Vin points on the mechaduino. I have yet to test in printing...
                                    I think as the thread creator he would get a notification on all replies. Unless he's turned that off entirely.
                                      mendelevium
                                      One other thing I notice is that on the dashboard- Job status says NO EXTRUDERS 😞
                                        Screen shot of what you're seeing?
                                        Can you also send M122 and M98 P"config.g" in the console and copy and paste the results here?
                                          mendelevium
                                          managed to run the extruders now. Apparently, I edited the config as per suggestion on a forum.. don not know if it was this or any other honestly since I had found it days ago and screen shot it out, But the extruders are running nicely by command..
                                            mendelevium
                                            many thanks all who put an imput. Its appreciated a lot. Have a nice weekend.
