    Duet 2 Ethernet IP address keeps flashing on display.
    1.2k
      Try creating a fresh SD card with a basic config.
      • TheIndianDudeundefined
        TheIndianDude
        I just did that thinking it may be an issue. Wiped the SD card, reloaded a basic config after setting it up and in 3 minutes, same error.
        Also noticed that if I issue an M552 S0, wait a few seconds and then issue an M552 S1 P0.0.0.0, the lights on the ethernet port don't turn back on.
          Considering this is an ethernet conversion I am wondering if there's an issue either with the module or the installation.
            TheIndianDude
            I've tested the pin connections for shorts or accidental solder blobs and I haven't found any issues. I was also careful to not let the board soak up too much heat when de-soldering the Wi-Fi Module. I think the only other option is that the ethernet module itself is faulty, which would be a bummer since the Wi Fi in my basement sucks and that's where this printer is going to be.
            I've ordered a new Duet 2 Ethernet board, so I'll wait to see how that turns out. In the meantime, I'm going to wipe the main board's firmware and re-flash it using BOSSA, then rebuild RRF 3.2.2 and see what that does.
              TheIndianDude
              btw, here are the firmware settings I've configured"
              ![53e5fba2-4785-4931-b506-ee0179872d68-image.png]
              (/assets/uploads/files/1614450403946-53e5fba2-4785-4931-b506-ee0179872d68-image.png)
                Perhaps @dc42 has other ideas. My money is on the module. Let us know what you find.
                TheIndianDudeundefined 1 Reply Last reply Reply Quote 1
                  TheIndianDude @Phaedrux
                  @Phaedrux Will do. Thanks! Also, the Z-Bot printer looks badass. I'm programming this board for what will eventually become a Hypercube CoreXY. For now it's an upgrade for my CR-10S to which I've added linear rails and converting to a 24V system.
                    Thanks. It's served me well.
                      Try removing the Ethernet cable while it is in this loop, then send M122 from YAT and post the result.
                        TheIndianDude
                        And of course it's not happening anymore... I formatted the SD card instead of just deleting the folders and then reloaded RRF3.2.2. After plugging in through USB, the network issue hasn't popped up yet. Though I haven't put the config_override.g file in the sys folder yet. Let me try that and start up the board again.
                          TheIndianDude
                          Lol... it happened just as I submitted my previous post.... Here's the M122 log from YAT (scroll through the network address messages for a bit)
                          M122 log.txt
                          • alankilianundefined
                            alankilian
                            Your Ethernet state is: Interface state establishingLink, link down
                            Mine (Duet2/Ethernet) is: Interface state active, link 100Mbps full duplex
                            Do you see the connection-state (not traffic) light blinking on the Ethernet connector.
                            Do you have a different Ethernet cable you can try?
                              TheIndianDude
                              I tried multiple cables, as that was the first thing I thought of as well. The yellow light is solid on the port when this happened and the green (traffic) light is flickering
                                TheIndianDude
                                I do have an 8 port switch between my router and the board, so maybe I'll have to see what's going on there?
                                  TheIndianDude
                                  I changed to a third cable and this time, the board went into the loop and then restarted. Here's the M122 after restart:
                                  M122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet Ethernet 1.02 or later
                                  Board ID: 08DGM-917DA-G4MS8-6JKD2-3S06R-T9TRB
                                  Used output buffers: 1 of 24 (2 max)
                                  Static ram: 23460
                                  Dynamic ram: 68848 of which 40 recycled
                                  Never used RAM 19732, free system stack 195 words
                                  Tasks: NETWORK(ready,548) HEAT(blocked,337) MAIN(running,471) IDLE(ready,20)
                                  Owned mutexes: USB(MAIN)
                                  Last reset 00:00:14 ago, cause: software
                                  Last software reset at 2021-02-27 15:42, reason: StuckInSpinLoop, GCodes spinning, available RAM 19732, slot 0
                                  Software reset code 0x0083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20001fac Task NETW Freestk 467 ok
                                  Stack: 004073fb 004072c2 01010000 f8000000 40a556ff 418dfce4 b7154800 3331bb4c 40000000 3f317200 b5ddea0e 388aade3 bb360493 3bcb9c8b 00000000 418554cd 38533333 7f7fffff 00000000 60000010 000000f0 000000f0 0040705b 000021c8 000021c8 400e0e00 0040716f
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  MCU temperature: min 17.3, current 18.0, max 18.2
                                  Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
                                  Driver 0: position 0, ok, SG min/max not available
                                  Driver 1: position 0, ok, SG min/max not available
                                  Driver 2: position 0, ok, SG min/max not available
                                  Driver 3: position 0, ok, SG min/max not available
                                  Driver 4: position 0, ok, SG min/max not available
                                  Driver 5: position 0
                                  Driver 6: position 0
                                  Driver 7: position 0
                                  Driver 8: position 0
                                  Driver 9: position 0
                                  Driver 10: position 0
                                  Driver 11: position 0
                                  Cache data hit count 19863370
                                  Slowest loop: 2.37ms; fastest: 0.13ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Movement lock held by null
                                  HTTP is idle in state(s) 0
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is ready with "M122" in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Code queue is empty.
                                  === Network ===
                                  Slowest loop: 1.03ms; fastest: 0.01ms
                                  HTTP sessions: 0 of 8
                                  ok
                                    TheIndianDude
                                    And it's not connecting to the network anymore. When this happened last time, I had to keep the board turned off for about 10 minutes and then try again and it connected to the network.
                                      alankilian
                                      Do you have any "Cold spray"?
                                      Maybe it's your Ethernet interface chip getting too hot?
                                      TheIndianDudeundefined 1 Reply Last reply Reply Quote 0
                                        TheIndianDude @alankilian
                                        @alankilian I don't, but I have tiny heatsinks that came with my DRV8825 stepper drivers back when I was using RAMPS on my 3d printer. Let me try that.
                                          TheIndianDude
                                          The network isn't connecting right now and the yellow link status light on the ethernet port is blinking periodically.
                                            TheIndianDude
                                            I reconnected the board after putting on the heatsink on the ethernet interface chip and the network connected. Then it fritzed out 3 minutes later. I'm running out of options here....I've got a replacement Duet Ethernet board on the way. I think I'll test the new board once it arrives and use that if that works... This is beyond frustrating...
                                            Argoundefined 1 Reply Last reply Reply Quote 0
