Solved Duet 2 Ethernet IP address keeps flashing on display.
I tried multiple cables, as that was the first thing I thought of as well. The yellow light is solid on the port when this happened and the green (traffic) light is flickering
I do have an 8 port switch between my router and the board, so maybe I'll have to see what's going on there?
I changed to a third cable and this time, the board went into the loop and then restarted. Here's the M122 after restart:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917DA-G4MS8-6JKD2-3S06R-T9TRB
Used output buffers: 1 of 24 (2 max)
Static ram: 23460
Dynamic ram: 68848 of which 40 recycled
Never used RAM 19732, free system stack 195 words
Tasks: NETWORK(ready,548) HEAT(blocked,337) MAIN(running,471) IDLE(ready,20)
Owned mutexes: USB(MAIN)
Last reset 00:00:14 ago, cause: software
Last software reset at 2021-02-27 15:42, reason: StuckInSpinLoop, GCodes spinning, available RAM 19732, slot 0
Software reset code 0x0083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0040080f BFAR 0xe000ed38 SP 0x20001fac Task NETW Freestk 467 ok
Stack: 004073fb 004072c2 01010000 f8000000 40a556ff 418dfce4 b7154800 3331bb4c 40000000 3f317200 b5ddea0e 388aade3 bb360493 3bcb9c8b 00000000 418554cd 38533333 7f7fffff 00000000 60000010 000000f0 000000f0 0040705b 000021c8 000021c8 400e0e00 0040716f
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 17.3, current 18.0, max 18.2
Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available
Driver 1: position 0, ok, SG min/max not available
Driver 2: position 0, ok, SG min/max not available
Driver 3: position 0, ok, SG min/max not available
Driver 4: position 0, ok, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Cache data hit count 19863370
Slowest loop: 2.37ms; fastest: 0.13ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.8ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1.03ms; fastest: 0.01ms
HTTP sessions: 0 of 8
Interface state establishingLink, link down
ok -
And it's not connecting to the network anymore. When this happened last time, I had to keep the board turned off for about 10 minutes and then try again and it connected to the network.
Do you have any "Cold spray"?
Maybe it's your Ethernet interface chip getting too hot? -
@alankilian I don't, but I have tiny heatsinks that came with my DRV8825 stepper drivers back when I was using RAMPS on my 3d printer. Let me try that.
The network isn't connecting right now and the yellow link status light on the ethernet port is blinking periodically.
I reconnected the board after putting on the heatsink on the ethernet interface chip and the network connected. Then it fritzed out 3 minutes later. I'm running out of options here....I've got a replacement Duet Ethernet board on the way. I think I'll test the new board once it arrives and use that if that works... This is beyond frustrating...
When the network isn’t reachable have you already hooked it up with a usb connection and send M552 to check the status of the network module?
@Argo said in Duet 2 Ethernet IP address keeps flashing on display.:
Yes, and M552 shows Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
This is despite the link status light on the port lit up steadily (amber) and the traffic light (green) flickering.
If then M552 S0 to disable the network and M552 S1 P<ipadress> doesn’t change anything my bet would also be a defective ethernet module.
That's what I think as well. I just downgraded to firmware 2.05.1 and am having the same issue. I'll get a replacement ethernet module for this board and try it out. I do have a Duet Ethernet board in the mail, so that will be for my second printer
Ok, so I received my new Duet 2 Ethernet board today and the first thing I did was flashed firmware 3.2.2 on it. It is working without a glitch so far (fingers crossed). I guess the ethernet module on the other board was bad. I have ordered a replacement for it, so hopefully that fixes my problem.
