    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
    • Serbitarundefined
      Serbitar @T3P3Tony
      @T3P3Tony Thanks. I look forward to being able to order
      • oc_geekundefined
        oc_geek
        For Europe this is an option for ordering the Mini 2+
        https://www.dold-mechatronik.de/Duet-3-Expansion-Mini-2_1
        oc_geekundefined 1 Reply Last reply Reply Quote 1
        • oc_geekundefined
          oc_geek @oc_geek
          @dc42 @T3P3Tony Hi guys, i finally received the Mini 2+ extension (took it from Dold), it was delivered to me this morning.
          I have to report back however that the Mini 2+ package DOES NOT include the two plastic standoffs that are needed to mechanically mount the card on top of the Mini 5+...
          • Vetiundefined
            Veti
            as a workaround you can use a 12mm m2 screw and nuts.
            oc_geekundefined 1 Reply Last reply Reply Quote 0
            • oc_geekundefined
              oc_geek @Veti
              @Veti yeah sure there are many WA(s) possible assuming you have material... that was NOT the point...
                We are looking into this.
                  T3P3Tony administrators @oc_geek
                  @oc_geek thanks for bringing this to our attention. We had planned on including these with the Mainboard connector packs but have now reassessed that plan.
                  We are sending connector packs for the mini 2+ to our resellers. Some will go today, some will go on Monday (to resellers who have already had mini 2+ sent to them). From when the resellers get these going forward will mini 2+ boards will be sent with connector packs.
                  • oc_geekundefined
                    oc_geek @T3P3Tony
                    @T3P3Tony sounds a good plan for who has yet to order the Mini 2+ ... but what about who (like me) have received it WITHOUT those ? ....
                      @oc_geek we will ask the resellers to send out to all customers that have already had one!
                      • Dafyddundefined
                        Dafydd
                        Is there a UK site which will allow me to pre-order a Duet 3 mini 5+?
                        The E3D site doesn't seem to allow pre-ordering, (or am I missing something)(else!)
                        Cheers,
                        Dafydd
                        • Vetiundefined
                          Veti @Dafydd
                          @Dafydd said in Duet 3 Mini 5+ : Initial announcement:
                          Is there a UK site which will allow me to pre-order one of these?
                          the mini has already been released, just sold out in the uk.
                          other reseller still have them.
                          Dafyddundefined 1 Reply Last reply Reply Quote 1
                          • Dafyddundefined
                            Dafydd @Veti
                            @Veti
                            Thanks. I'll keep looking through other UK resellers.
                            • fpeopleundefined
                              fpeople
                              @dc42 @T3P3Tony Hi guys, there is any plan for releasing the schematic and cad files for this board in github?
                              • peter247undefined
                                peter247
                                it looks like the only place you can't get them is the UK ?
                                Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                                  T3P3Tony administrators @peter247
                                  @peter247 AFAIK we have now sent stock to both e3d and ooznest so hopefully they will restock soon!
                                  • DocTruckerundefined
                                    DocTrucker @T3P3Tony
                                    Out of stock at both E3D and Ooznest. The latter said they weren't stocking them at the moment? Perhaps I missread their message: "This is not an item we carry at the moment I am afraid, we don't currently have an eta."
                                    With the CAN bus and Raspberry Pi features weighing on the same class of processor as the Duet 2 is this likely to be a slightly lower ultimate performance - aside from the lower motor current?
                                    Edit: Noticed that RAM and flash for the mini has doubled. Will this have any appreciable effect when it is running the same firmware?
                                      T3P3Tony administrators @DocTrucker
                                      @DocTrucker I checked our end and we are definitely supplying both E3D and Ooznest, just give us a chance to get them out the door!
                                      The mini use a SAME5x processor which as you note has more flash and RAM than the SAM4E processor on the Duet2. They both feature floating point and a ARM4 core running at 120Mhz. Performance, where comparable, will be very similar. The mini has more headroom for future firmware features.
                                        @T3P3Tony Thanks, I've been looking at the specs on the duet family page. Just seemed odd stock was sent on the 11th and out already on the 16th when they didn't appear to operate a queue or expression of interest system.
                                          @DocTrucker yeah - my 11th post was overly optimistic!
                                            @T3P3Tony 😄 Fair enough!
