    PT100 sensor on Duet2 sporadically hunting for target temp
    1.3k
    • Vetiundefined
      Veti
      post a picture of the graph when you are getting a heater fault
      • mitchundefined
        mitch
        Right now I am just trying to get the printer to sit on 210C so I can do a manual bed level. The system just keeps going over and below the target temp and not stabilizing. (see video link above at the bottom of the post).
        It is almost as if the additional accuracy of this sensor is causing me all the problems. The fidelity of the sensor keeps my macros from running since it is constantly trying to hit the exact target temp.
        • Vetiundefined
          Veti
          that fluctuation of +/- .5 degree is normal
          • mitchundefined
            mitch
            My macros don't seem to progress. They are stuck waiting for target temp to be reached. Do I need to specify a tolerance somewhere?
            I am also still getting heater faults when printing. I will try to capture that data if I can ever get my bed leveling macro to run.
            • Vetiundefined
              Veti
              post the macro
              • mitchundefined
                mitch
                It isn't any one macro. It is all of them.
                As an example:
                M291 P"Preheating the bed to 60 and nozzle to 210 for accurate probing" T0
                M104 S210		; Set nozzle to 210 and release
                M190 S60		; Set bed to 60 and wait
                M109 S210		; Set nozzle to 210 and wait
                As just one example, the macro I am running now can never get past the M109 command as it doesn't seem to think that hotend has landed on 210C event though it is +/1 one degree.
                • Vetiundefined
                  Veti @mitch
                  @mitch
                  that should finish.
                  whats the next command?
                  • mitchundefined
                    mitch
                    It doesn't get past it in any of my macros. It just sits and hunts for temp there.
                    I have print statements, tones, you name it. It never gets past setting temp in the macros.
                    example from the video:
                    ; Preheat to probing temps
                    ; Tone to get user attention
                    M400			; Clear movement buffer so tones play reliably
                    M300 S666 P500
                    G4 P501
                    M300 S1111 P300
                    G4 P301
                    ; Move nozzle to center of bed at Z10 and drop to Z1
                    M291 P"Nozzle will now move to center of bed and move close to the bed" T0
                    M98 P/macros/general/1_Center_Nozzle ;P move to bed center
                    ; Reset z to 8 to allow jogging up to touch bed to nozzle
                    G92 Z8
                    ; Dialog to allow user to job z to touch nozzle to bed gently and then move Z down 10
                    M291 P"Carefully Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
                    G92 Z0      		; set z = 0
                    • Vetiundefined
                      Veti
                      @mitch said in PT100 sensor on Duet2 sporadically hunting for target temp:
                      I am also getting heater faults during prints because it is not staying on temp.
                      please post the exact message you are getting.
                      did you use a special M570 command?
                      • mitchundefined
                        mitch
                        I apologize. Let me be more clear.
                        I believe I have two heater related issues.
                        1. It seems to not progress in my macros because it is hunting to hit target temp even thought it is within 2.5C
                        2. I have sporadic heater faults during prints. I need to capture more data on this to troubleshoot it. I have just returned to prints to find the print paused and a heater fault.
                        Special M570 command?
                        • Vetiundefined
                          Veti
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M570_Configure_heater_fault_detection
                          mitchundefined 1 Reply Last reply Reply Quote 0
                          • mitchundefined
                            mitch @Veti
                            @Veti Thanks,
                            Nope, no M570 defined in config.g or config_override.g files.
                            • Vetiundefined
                              Veti
                              but it does get past the M109 when you print something?
                              • mitchundefined
                                mitch
                                Yes it does.
                                I commented out the Tone generation and I saw this particular macro get to about line 79 and then it just drops out. Again, I think I have a few issues going on here so the troubleshooting is a bit confusing. I am trying to rule some variables out.
                                ; Helps guide leveling the bed mechanically, and calibrate the ZProbe trigger height before running a grid bed compensation routine..
                                ; Preamble to tell the user to prepare the printer before continuing
                                ;M291 P"Before proceeding make sure the printer is mechanically sound and properly functioning." R"Prepare printer for leveling routine" S3 ; User must click OK
                                ;M291 P"ZProbe should be configured and working. Clear the print bed of any obstacles or debris." R"Prepare printer for leveling routine" S3 ; User must click OK
                                ;M291 P"This routine will take about 10-20 minutes and heat both the bed and nozzle." R"Prepare printer for leveling routine" S3 ; User must click OK
                                ;M291 P"You will need a piece of paper. Filament will be unloaded." R"Prepare printer for leveling routine" S3 ; User must click OK
                                ;M291 P"Make sure you have successful Gcodes logged to the console before proceeding." R"WARNING" S3 ; User must click OK or cancel
                                ;M291 P"Make a note of your M558 Z value and backup current heightmap before proceeding." R"WARNING" S3 ; User must click OK or cancel
                                M929 S1 ; start logging
                                ; Clear compensation map and Zprobe trigger height
                                M291 P"Grid bed compensation map will be disabled. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel.
                                M561			; Disable any current bed compensation
                                G29 S2			; Clear mesh bed compensation perameters
                                G31 Z0			; Reset zprobe trigger height
                                ; Heat up bed and nozzle to PLA temps in prep for filament removal and probing
                                M291 P"Bed and nozzle will preheat and home all axis." R"Preheat and Home" S3 T0 ; User must click OK or cancel
                                M104 S130		; Set nozzle to 130 and release
                                M140 S55		; Set bed to 55 and release
                                ; home all axis
                                G28 XY
                                G28 Z       ; Home all axis
                                G90			; Absolute positioning
                                T0			; Activate first tool
                                ; Set lower speeds for Z homing and lower Z motor current
                                M566 Z10			; Set maximum instantaneous speed changes (mm/min) (Jerk)
                                M203 Z400			; Set maximum speeds (mm/min)
                                M201 Z100	 		; Set maximum accelerations (mm/s^2)
                                M913 Z40			; Drop motor current to prevent damage in case of head crash
                                ; Move nozzle forward for filament removal
                                ;M291 P"Moving nozzle to the front for filament removal and cleaning." T0
                                ;G1 X50 Y5 Z100		; Moves print head to front left and drops the bed down for easy access
                                ;M109 S130		; Set nozzle to 130 and wait
                                ;M400			; Clear movement buffer so tones play reliably
                                ;M300 S666 P500
                                ;G4 P501
                                ;M300 S1111 P300
                                ;G4 P301
                                ; Unload filament and clean nozzle
                                ;M291 P"Unload filament if loaded and clean nozzle, then press OK to continue" R"Unload Filament" S3 T0 ; User must click OK or cancel
                                M702			; Unload Filament
                                ;M300 S666 P500
                                ;G4 P501
                                ;M300 S1111 P300
                                ;G4 P301
                                G92 Z8
                                G92 Z0      		; set z = 0
                                ; Move nozzle to leveling points and prompt user to level bed at each
                                M291 P"Nozzle will now move to the 4 leveling points twice." S1 T2
                                ; Move to leveling point 1
                                G1 Z2      		; move to z2 for travel
                                G1 X26 Y25 F6000	; Move to front left corner
                                M400
                                M291 P"Adjust point 1 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension." R"Adjustment Point 1" S2 Z1
                                ; Move to leveling point 2
                                G1 Z2			; Move to Z2 for clearance
                                G1 X195 Y195 F6000	; Move to rear right corner
                                M400
                                M291 P"Adjust point 2 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension." R"Adjustment Point 2" S2 Z1
                                ; Move to leveling point 3
                                G1 X195 Y25 F6000	; Move front right corner
                                M400
                                M291 P"Adjust point 3 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension." R"Adjustment Point 3" S2 Z1
                                ; Move to leveling point 4
                                G1 X26 Y195 F6000	; Move rear left corner
                                M400
                                M291 P"Adjust point 4 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension." R"Adjustment Point 4" S2 Z1
                                ; Repeat to verify
                                M291 P"The adjustment sequence will now repeat for fine adjustment." S1 T2
                                M400
                                M400
                                M400
                                M400
                                ; Move nozzle to center of bed at z10
                                M291 P"Nozzle will now move to center of bed to reset Z0" S3
                                G1 Z1			; Drop bed for nozzle clearance
                                ;G1 X112.5 Y112.5 Z2 F4000	; Move to bed center
                                M98 P/macros/general/1_Center_Nozzle ;P define the parameter and is not part of the name
                                ; Reset z to 5 to allow jogging up to touch bed to nozzle
                                G92 Z5
                                ; Dialog to allow user to jog z to touch nozzle to bed gently and then move Z down 10
                                M564 S0         ; To allow movement lower than where the firmware thinks Z=0 is.
                                M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3
                                G92 Z0			; Set z = 0
                                M291 P"The bed has been mechanically leveled and Z0 set." S2
                                M300 S666 P600
                                G4 P601
                                M300 S1511 P300
                                G4 P301
                                M291 P"Probing complete. Turning off heaters and homing axis."
                                ; Turn off heaters
                                M104 S0		; Set nozzle to 0 and release
                                M140 S0		; Set bed to 0 and release
                                G28 XY		; Home XY
                                ; Set normal settings after stall detection probing
                                M98 P/macros/general/Normal_Settings ;P define the parameter and is not part of the name
                                M300 S666 P600
                                G4 P601
                                M300 S1511 P300
                                G4 P301
                                M291 P"Run Trigger Height Macro to determine trigger height"
                                M929 S0 ; stop logging
                                • mitchundefined
                                  mitch
                                  This is just acting really strange. I can put the lines into the console one by one starting at line 79 and it all works fine. But when I run the macro it just seems to get to around Line 79 and then just exit. No errors or warnings.
                                    jay_s_uk
                                    you don't have your macro in line 80 in ""
                                    M98 P/macros/general/1_Center_Nozzle 😜 move to bed center
                                    M98 P"/macros/general/1_Center_Nozzle"
                                    • mitchundefined
                                      mitch
                                      After trying numerous times the macro just started running. Part way through I got the heater fault.
                                      Log:
                                      2021-02-28 10:59:51 [info] Event logging started at level debug
                                      2021-02-28 10:59:51 [info] Running: Duet Ethernet 1.02 or later: 3.2 (2021-01-05)
                                      2021-02-28 10:59:51 [info] M291: - WARNING - Grid bed compensation map will be disabled. Ok or Cancel?
                                      2021-02-28 10:59:53 [info] M292: cancelled: false
                                      2021-02-28 10:59:53 [info] M291: - Preheat and Home - Bed and nozzle will preheat and home all axis.
                                      2021-02-28 10:59:54 [info] M292: cancelled: false
                                      2021-02-28 11:00:15 [debug] {"beep_freq":666,"beep_length":500}
                                      2021-02-28 11:00:16 [debug] {"beep_freq":1111,"beep_length":300}
                                      2021-02-28 11:00:16 [info] M291: - [no title] - Preheating the bed to 60 and nozzle to 210 for accurate probing
                                      2021-02-28 11:00:35 [info] M291: - [no title] - Nozzle will now move to center of bed and move close to the bed
                                      2021-02-28 11:00:36 [info] M291: - Setting Z=0 - Carefully Jog the Z Axis until the bed and nozzle are touching and click OK
                                      2021-02-28 11:01:16 [info] M292: cancelled: false
                                      2021-02-28 11:01:16 [info] M291: - [no title] - Nozzle will now move to the 4 leveling points twice.
                                      2021-02-28 11:01:18 [info] M291: - Adjustment Point 1 - Adjust point 1 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:03:00 [info] M292: cancelled: false
                                      2021-02-28 11:03:03 [info] M291: - Adjustment Point 2 - Adjust point 2 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:04:05 [info] M292: cancelled: false
                                      2021-02-28 11:04:07 [info] M291: - Adjustment Point 3 - Adjust point 3 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:04:45 [info] M292: cancelled: false
                                      2021-02-28 11:04:48 [info] M291: - Adjustment Point 4 - Adjust point 4 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:05:36 [info] M292: cancelled: false
                                      2021-02-28 11:05:36 [info] M291: - [no title] - The adjustment sequence will now repeat for fine adjustment.
                                      2021-02-28 11:05:38 [info] M291: - Adjustment Point 1 - Adjust point 1 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:06:21 [info] M292: cancelled: false
                                      2021-02-28 11:06:24 [info] M291: - Adjustment Point 2 - Adjust point 2 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:06:38 [info] M292: cancelled: false
                                      2021-02-28 11:06:40 [info] M291: - Adjustment Point 3 - Adjust point 3 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:07:13 [info] M292: cancelled: false
                                      2021-02-28 11:07:16 [info] M291: - Adjustment Point 4 - Adjust point 4 by using jog to lower nozzle to 0, then use the bed height knobs and a piece of paper to tweak tension.
                                      2021-02-28 11:07:21 [warn] Error: Heater 1 fault: temperature excursion exceeded 15.0°C (target 210.0°C, actual 225.8°C)
                                      2021-02-28 11:07:23 [info] M292: cancelled: false
                                      2021-02-28 11:07:23 [info] M291: - [no title] - Nozzle will now move to center of bed to reset Z0
                                      2021-02-28 11:07:30 [info] M292: cancelled: false
                                      2021-02-28 11:07:32 [info] M291: - Setting Z=0 - Jog the Z Axis until the bed and nozzle are touching and click OK
                                      2021-02-28 11:10:40 [info] M292: cancelled: false
                                      2021-02-28 11:10:40 [info] M291: - [no title] - The bed has been mechanically leveled and Z0 set.
                                      2021-02-28 11:11:01 [info] M292: cancelled: false
                                      2021-02-28 11:11:01 [debug] {"beep_freq":666,"beep_length":600}
                                      2021-02-28 11:11:02 [debug] {"beep_freq":1511,"beep_length":300}
                                      2021-02-28 11:11:02 [info] M291: - [no title] - Probing complete. Turning off heaters and homing axis.
                                      2021-02-28 11:11:17 [debug] {"beep_freq":666,"beep_length":600}
                                      2021-02-28 11:11:17 [debug] {"beep_freq":1511,"beep_length":300}
                                      2021-02-28 11:11:18 [info] M291: - [no title] - Run Trigger Height Macro to determine trigger height
                                      2021-02-28 11:11:18 [info] Event logging stopped
                                      • mitchundefined
                                        mitch @jay_s_uk
                                        @jay_s_uk Thanks,
                                        I updated the file. Seems to still run the same. But I will make sure to find all the macros that have this command and add the quotes.
                                        Just seems like sporadic behavior.
                                        • mitchundefined
                                          mitch
                                          This may be a combination of some macro issues due to recent firmware updates as well as an intermittent connection near the hotend probe.
                                          Thanks for the help. I am going to try to nail down the probe issue first to start to rule out some variables and make this easier to figure out.
                                          • Vetiundefined
                                            Veti
                                            post a picture of the temperature graph
