    Easier to use Software
    65
    4.7k
    • DanS79undefined
      DanS79 @deckingman
      @deckingman said in Easier to use Software:
      @DanS79 said in Easier to use Software:
      ............. The ones that complain the loudest are usually the ones that want to be on the bleeding edge.
      Yes this accusation keeps getting levelled at me - basically it's all my fault for having a complex machine.
      If I was referencing to you specifically, I would just call you out by name.
      • fcwiltundefined
        fcwilt @deckingman
        The last 18 months have destroyed any confidence I had in the firmware. I just can't trust it any more............
        I have three printers of different designs. Two are using Duet 2 WiFi/Duex5 combos, one is using a Duet 3 Mini 5 WiFi.
        I have a Duet 3 MB6HC/3HC combo on the bench for testing but it's going to be a long while before I will be able to try them in an actual printer.
        I'm using firmware 3.2.2 on all of the boards.
        All three of my machines turn out good prints.
        You are using the MB6HC correct? So does that suggest your problems are related to that family of boards?
        JayJayundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        • JayJayundefined
          JayJay @fcwilt
          @fcwilt said in Easier to use Software:
          Since the advent of RRF3 and the Duet-3 ecosystem things have IMHOP gone so far south they are being asked for ID McMurdo Station.
          Whereas a Duet-2 on RRF2 "just works"
          • fcwiltundefined
            fcwilt @JayJay
            @JayJay said in Easier to use Software:
            I was thinking that since 3.2.2 works fine on the Duet 2 family and the Mini 5 - none of which are using the CAN bus could the problems be related to things unique to the MB6HC/3HC family which rely on the CAN bus or the parts of the firmware the handle the CAN bus.
            JayJayundefined 1 Reply Last reply Reply Quote 0
              deckingman @fcwilt
              ...................You are using the MB6HC correct? So does that suggest your problems are related to that family of boards?
              Let's just say that in 2017 using Duet 2, at the TCT show, I was producing multi-colour vases (different colour on every layer). Two of those vases were requested by, and given to, employees of E3D on an adjacent stand. (E3D did not have the abilty to reproduce them). A third vase was requested by, and given to, a guy who owned museum of printing somewhere in Switzerland. As far as I know, it's still there on display.
              In 2019, I converted to Duet3 hardware (MB6HC plus three MB3HC expansion boards) and I've had nothing but problems since. I've never been able to get replicate those vases. I once came close but the quality was far below show stand or museum display status.
              My gut feel is that it's all related to the way expansion boards communicate with the main board. But that's just a gut feel.
              I've made a conscious decision to ditch gen 3 hardware. I'm just considering whether to resort back to the Ethernet plus Duex5, or ditch all Duet products completely. Or maybe even ditch everything and settle for a cheap desktop all in one.
              Anyone fancy making an offer on a part working CoreXYUVAB with 6 extruders?
              On the other hand, there is enough extrusion, motors, belts etc to build a farm of small, single input machines - I might just do that..........
              • JayJayundefined
                JayJay @fcwilt
                I have (and continue to have) issues if I install RRF3 on my Duet-2 board (but not with RRF2) and have niggly issues on my Duet-3 mini 5+ with RRF3, there is no point in opening new threads on those issues because the fan boys will roll out the stock "post your config.g" etc when its not a config issue. and i just stopped using my 6HC board as its a complete waste of time.
                fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 2
                • fcwiltundefined
                  fcwilt @JayJay
                  That's curious.
                  I have hundreds of print hours on my Duet 2 based printers and my Mini 5 based printer, both running 3.2.2.
                  No issues at all.
                  If you are interested to share your problems perhaps I might have some insight.
                  • fcwiltundefined
                    fcwilt @deckingman
                    Well that would be reasonable as the boards I have are running 3.2.2, without issue but none of them use the CAN bus.
                    It may well be that the CAN bus implementation has timing issues that introduce tiny motion errors leading to reduced print quality.
                    I wish I had the time to setup a printer using my MB6HC/3HC and see if print quality issues arise.
                    My two printers using the Duet 2 WiFi/Duex5 combo are working fine and I have no plans to replace those boards.
                    Perhaps reverting to the Duet 2 is your best option.
                    Good luck and thanks.
                    zaptaundefined 1 Reply Last reply Reply Quote 1
                    • zaptaundefined
                      zapta @fcwilt
                      That's an interesting proposition.
                      Using signal busses has the potential of significantly reducing the writing in 3D printers.
                      • fcwiltundefined
                        fcwilt @zapta
                        @zapta said in Easier to use Software:
                        I don't think the concept is flawed - just, perhaps, the current firmware which handles the CAN bus.
                        While my speculation is just that, speculation, it would help to explain why the current firmware (3.2.2) works fine on non-CAN based systems but seems to have problems, as reported by @deckingman, with regards to print quality on CAN based systems.
                        • zaptaundefined
                          zapta @fcwilt
                          @fcwilt, it may be tricky to control steppers that need to coordinated but sit on different bus nodes. Would be interesting to hear from dc42@ what the challenges are and if the introduction of a bus degrades degrades significantly the time shift and jitter between the steppers.
                          The good news is that the movement control is done in open loop and can be planned ahead such that each node just need to perform the plan assigned to it with perfect timing relative to the system's time ticks.
                          Wireless earplugs have a similar challenge, they need to provide perfect phase matching through two different wireless nodes.
                          • DaBitundefined
                            DaBit
                            The CAN bus was made for stuff like this. There is only a delay in the transmission, and unlike many other serial physical layers that delay is fixed and known. So it is fairly trivial to synchronise a clock over all the CAN-connected boards, down to microsecond level. Once we have a synchronised clock, we have synchronised motion.
                            I cannot look in the head of the developers, but I am fairly certain that clock synchronisation was the first thing implemented and thoroughly tested since it is so vital.
                              dc42 administrators @deckingman
                              Here are some of pics of a little case I just printed using a simple single input hot end and with pressure advance disabled. It's bloody awful - like the first print ever produced on a crap machine by a rank amateur.
                              You've declined my suggestion of starting a new thread about this, so I don't know whether you are serious about wanting us to help resolve this. But if you are, then this is what I suggest:
                              • You haven't told us what the perimeter print speed was, or the filament, or the hot end temperature; but the bad corners look to me like the filament taking shortcuts due to printing over-temperature or with poor print cooling, and possibly too fast. Maybe worth printing a temperature tower?
                              • If you install firmware 3.3beta1 then the improved diagnostics in that release will tell us precisely whether the synchronisation of moves over the CAN bus has contributed to the poor print quality.
                              • Leave pressure advance and DAA disabled until we have yout machine printing reasonably without them. Then we can look at the effect of enabling them.
                                droftarts administrators @JayJay
                                I have (and continue to have) issues if I install RRF3 on my Duet-2 board (but not with RRF2) and have niggly issues on my Duet-3 mini 5+ with RRF3, ... and i just stopped using my 6HC board as its a complete waste of time.
                                I can’t see any obvious threads from you reporting problems. If there are, please link them, or please start a thread and we’ll try and get any issues sorted out. This may involve posting your config files for each firmware version, though, so we have at least a baseline to work from.
