    Independently leveled Z axis Issue
    6.8k
    • 3DPrintingWorldundefined
      3DPrintingWorld @Veti
      @Veti Holding torque is not required, detent torque and inefficiently of the gears will keep the axis from moving.
      Feel free to review this calculator I made in reference to these regards.
      https://github.com/3dprintingworld/MULDEX/blob/master/Resources/STEPPER HOLDING POWER CALCULATOR.xlsx
      • fcwiltundefined
        fcwilt
        Just out of curiosity what you are changing the motor assignment in your homeall routine?
        3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
          3DPrintingWorld @fcwilt
          @fcwilt Two motors for Y axis, one belt at each end of the gantry. I split the axis up so I can home to each endstop independently. This is so I can square the gantry up to the frame.
          My original plan was to run the y axis into the frame, then run it back to a single switch but I was having a hard time getting the senseless homing to work reliably. Another user has sensorless homing working good so I plan on switching to that.
          • fcwiltundefined
            fcwilt @3DPrintingWorld
            @3DPrintingWorld 3.2.2 will home both at same time stopping each at the end stop. There should be no need to do it as you are. At least it works for me.
              @fcwilt Ok, I'll look into it.
              Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 1
                Phaedrux Moderator @3DPrintingWorld
                @3DPrintingWorld It's the same as described here, except instead of Z, it's X or Y.
                https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
                • fcwiltundefined
                  @3DPrintingWorld said in Independently leveled Z axis Issue:
                  He is a quick and dirty video I made showing homing of my three Z steppers - I pushed them way out of level first to clearly show the independent axis homing.
                  My Three Z Steppers Homing Independently
                    3DPrintingWorld
                    @fcwilt & @Phaedrux, sorry I forgot that I already tried this but it did not work. Here was the explication from DC.
                    "On a CoreXY printer, if either the X or the Y endstop switch triggers, all motors must be stopped. Your printer isn't CoreXY, but it has a matrix for which some motors affect more than one axis. If I remember correctly, on MarkForged kinematics, movement of the Y motor causes X (and U) movement too. So when one Y endstop switch triggers, if the other Y motor were to continue moving, it's not clear whether the X and U motors should continue to move if the firmware moves just the other one. That's why the firmware stops all motors when an endstop switch is triggered."
                      @fcwilt said in Independently leveled Z axis Issue:
                      That is really slick looking! What are the sensors for, just to get it close before probing the bed?
                      • fcwiltundefined
                        Exactly.
                        The best probing speed is quite slow compared to the homing speed.
                        So I use the endstop sensors for homing to quickly get the bed close to level.
                        Then before printing I use G32 to level the bed using the probe.
                        • fcwiltundefined
                          That's good to know.
                          The fact that by splitting the motors you can achieve your goal suggests that the firmware should be able to do the same when homing using both steppers/endstops.
                          I may post a firmware request to make this possible.
                            @fcwilt Logically, you would think that it would be possible but when I ask DC this was the response.
                            "It's undefined whether the X and/or U motors should also be moved when moving just one of the Y motors.
                            The code that decides whether to stop all motors or just one in this instance is the same code that decides whether to stop all motors or just one when you are homing several axes simultaneously. If you were to home e.g. X, U and Y all at the same time, it would still be necessary to stop all motors when any endstop switch is triggered."
                            I you would like to see the entire thread, you can find it here.
                            https://forum.duet3d.com/topic/17408/dual-y-axis-endstop-homing/20?_=1614738863955
                            • fcwiltundefined
                              Thanks for that link.
                              When you split out each Y stepper and home again over that very short distance does the X axis continue to move?
                                @fcwilt
                                Yes! Since I'm homing Y+, both the X and the U move in the positive direction as well.
                                Thats why I home X and U first so I can move them away from the endstops so U does not crash.
                                • fcwiltundefined
                                  @fcwilt
                                  Thanks. That is what I needed to know.
                                  • martin7404undefined
                                    martin7404
                                    I am runinng the same design. I did recently rebuild my X rail with slight preload blocks from hiwin and during test I had strange observation:
                                    During print when Y changes direction U head that is parked performs very tiny small moves. I do not think there is mechanical issue here, and I do not remember that I have seen this month ago when I first comisioned the machine.prf 3.0
                                    Muldex IDEX Duet2+Duex5
                                    Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                    Sapphire Pro with Duet2, with closed-loop motors
                                    custom high temp E3D tool changer with Duet2+Duex
                                      3DPrintingWorld @martin7404
                                      @martin7404 I tested this, but it was a while back. Maybe still on RRF 2, but it was excellent.
                                      https://youtu.be/BjzmFBKh2jQ
                                      You wouldn’t think a preloaded bearing would have a impact since there is only one on the carriage so it shouldn’t be causing any type of bind.
                                      martin7404undefined 2 Replies Last reply Reply Quote 0
                                        martin7404 @3DPrintingWorld
                                        @3DPrintingWorld no I do not think it is because of new block, I just noticed it and do not remember it before disasembly. I might be have some binding in belt way where U and Y cross
                                          martin7404
                                          P.s. the only thing I did change in software was the matrix Y1,1,0,1 and the Y mototors direction switched. Still not sure if it was there before
                                            @3DPrintingWorld I made the same test. So The dial indicator play about 0.05 mm wen changing Y direction If you do not change Y direction it is dead on 0. When I print with the left cariage the U moves maybe 1 , maybe half a mm left to right and back, just like there is some delay in stepper reaction to counter Y movement
