    issues connecting to wifi on duet 2 wifi
    Firmware installation
    771
    • djwarpundefined
      djwarp
      good evening I am having trouble getting connected to wifi. i have installed the new firmware but i cant seem to get the wifi to come on. When I install the IABe.BIN file it says the file is too large, i then switched to IAB.BIN and it doesnt want to work. here's what i got so far.
      WiFi reported error: no known networks found
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      WiFi module is idle
      M552 S0
      SENDING:M552 S0
      WiFi module is idle
      ok T0:2000.0 /0.0 B:2000.0 /0.0
      M587
      SENDING:M587
      Remembered networks:
      TNCAPF2FD81 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
      DJWARP IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
      M587
      SENDING:M587
      M115
      SENDING:M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
      any help will be greatly appreciated.
      • fcwiltundefined
        fcwilt
        Well the remembered networks must not be one of the WiFi "networks".
        What are the WiFi SSIDs available to you?
          Please post the results of M122.
          Then use M552 S1 to see if it will enable and connect.
          Use M587 to see a list of currently saved SSIDs
          use M588 S"*" to clear all curently saved SSIDs
          and then use M587 S"networkname" P"password" to readd your SSID
          Tron_Livesundefined 1 Reply Last reply Reply Quote 0
          • Tron_Livesundefined
            Tron_Lives @Phaedrux
            @Phaedrux I'm having the same issue as above and when I run the commands as you state, I get errors saying "failed to reset the wifi module to factory settings".
              Phaedrux Moderator @Tron_Lives
              @Tron_Lives Try reflashing the wifi module firmware by sending M997 S1.
                @Phaedrux Done, immediately after it said it failed to connect to my wifi. I'm fairly certain the network name and password are correct. The only thing that has changed is Cox made me upgrade my router to their panoramic one and it doesn't have a separate 2.4/5 GHz internet. It says it takes both, but I'm suspicious.
                  @Tron_Lives said in issues connecting to wifi on duet 2 wifi:
                  That could be very likely. There have been other reports of ISP issued wifi routers not playing nice, usually with combined SSIDs. If possible see if you can force it to split out a separate 2.4ghz network. Or get a cheap 2.4ghz router and set it up as an AP for the Duet.
                    @Phaedrux AP?
                    I'll look more into it and get back to you. Thanks for your help.
                      Sorry, AP = Access Point. What you call a wifi router that is just providing a wireless network access point but no actual routing.
                        @Phaedrux I got in touch with Cox and apparently, there's a hidden setting for enabling the 2.4 GHz wifi. I have that turned on and the password is right, but I still get an error saying "Failed while trying to connect" Is there anything else I can try?
                        • alankilianundefined
                          alankilian @Tron_Lives
                          @Tron_Lives Is there another device you can try to connect to your Cox 2.4 access point as a test?
                          Like a smartphone, thermostat, Roku or something?
                            Tron_Lives @alankilian
                            @alankilian I have recently reconnected a few smart devices like speakers and light bulbs. I also just made sure I can connect using my phone.
                              alankilian
                              OK, what does M587 say now?
                              It should show your 2.4 GHz WiFi access point SSID (name)
                              Going back to what @Phaedrux said in an earlier message, let's try again.
                              Try clearing out all the saved passwords with M588 S"*" and then use M587 S"networkname" P"password" to add your SSID
                              Tron_Livesundefined 1 Reply Last reply Reply Quote 1
                                @alankilian I must have done something because now YAT has issues recognizing my printer. When it does end up recognizing it, it remembers the correct wifi SSID. After I do what you have suggested above I get the same error.
                                Could it be a firmware issue? I haven't printed anything in awhile because of school (7 months)
                                  When and where did you purchase the Duet?
                                    @Phaedrux amazon about a year ago
                                      droftarts administrators @Tron_Lives
                                      Unfortunately, that makes it very likely it's a clone board, not produced by Duet3D; we don't sell through Amazon. Can you post a picture of both sides of the board?
                                        Tron_Lives @droftarts
                                        @droftarts Understood. I did however wipe my SD card and start from scratch and read that when using YAT you don't need to do anything special when typing the network SSID and password as opposed to pronterface where I had to put a apostrophe after each letter. So it works now. Thank you all for your help and I apologize if I was an idiot and wasted your time.
                                          Glad you got it sorted. We're happy to help.
