Motors working then chatter before and after homing...
2.0k
    @wingtip said in Motors working then chatter before and after homing...:
    What should my home x and home all look like under this new version 3 stuff since i had it set to split the axis then rejoin them..?
    @Phaedrux said in Motors working then chatter before and after homing...:
    For the homing files you can then remove the references to U and V entirely.
    Since U and V don't exist anymore you only have to home them as if it was a single axis with a single motor. The main difference for RRF3 is that the endstops are defined to use 2 switches and it will continue to move the axis until both switches have been hit. It's much simpler than it was before.
      wingtip
      but do i still need to split the axis during homing, the M584 command?
      homeall.g
      homex.g
      Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
      undefined 1 Reply Last reply 4 Mar 2021, 02:28 Reply Quote 0
        Phaedrux Moderator @wingtip
        @wingtip no. You wouldn't need m584 in the homing files at all and you would only need movement for x y z.
          wingtip
          ok i tried to home x and immediately got an error something about a G1 S1 so i immediately shut down the power before it got to the end stops in case it wouldnt stop... here is my current home x settings
          homex.g
            G1 S2 Z5 F6000
            Change the S2 to H2 and any S1 to H1 in your homing files.
            That is another change between RRF2 and RRF3. The S is now used for laser power. So H is now used for homing moves.
              wingtip
              ok, its working using this new reprap 3 coding , HOWEVER, i still have the same issues. The motors move the gantry just fine. But the moment i hit home x, the motors chatter a few seconds, then move to home and after the second hit of the endstops it chatters again for a few seconds then stops... it only does it during homeing... any other time the motors move nice and quiet as they should.
              undefined 1 Reply Last reply 4 Mar 2021, 03:13 Reply Quote 0
                Video?
                How are you moving the motors when it works if it's not homed yet?
                Do the axis move ok by hand with the duet powered off? (do it slowly)
                In the gcode console, can you send M122 and M98 P"config.g" and post the results here?
                  wingtip @Phaedrux
                  Video?
                  M564 S0 H0 ; allows movement of non homed axis for testing, and yes the axis move fine with the duet powered off. let me take a short short video
                    fcwilt @wingtip
                    Sounds like your endstops may not be working.
                    The G1 H1 commands specify a max distance they will move trying to reach the endstop. When the endstop activates the movement stops otherwise the movement may continue to the limit of the axis.
                    Unrelated to that you have a command in your config.g file M574 Z1 S2 - that is invalid and not needed all at the same time.
                    From the docs:
                    Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
                      wingtip
                      While im waiting for the video to render, the code for the z axis is irrelevant right now as i have them unplugged. As for the comment about the endstops. both end stops trigger and can be seen in the dwc changing states... also, why would the motor chatter before it even moves and gets anywhere near the endstop...? You will see in the video and maybe understand better.... just waiting for my slow computer to render this so i can upload it to youtube and wait for it to process it , then post the link here...
                      undefined 1 Reply Last reply 4 Mar 2021, 03:35 Reply Quote 0
                        fcwilt @wingtip
                        I only mentioned it because the configurator often inserts that M574 Z1 S2 command even though it is incorrect.
                        It will certainly help to see the video. The only thing I have experienced like that affected all motor movements - not just homing.
                        Could you post the relevant homing file?
                          wingtip
                          https://youtu.be/jRshkrsYCDEhomex.g
                            That is indeed strange that movement after M564 S0 H0 works fine, but homing behaves strangely. One thing that occurs to me is that it could be resonance due to the speed of the homing moves compared to the normal travel moves.
                              wingtip
                              M122
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                              Board ID: 08DGM-917NK-F2MS4-7JKD6-3SN6K-9GU4G
                              Used output buffers: 3 of 24 (15 max)
                              Static ram: 23460
                              Dynamic ram: 73376 of which 76 recycled
                              Never used RAM 15168, free system stack 115 words
                              Tasks: NETWORK(ready,169) HEAT(blocked,200) MAIN(running,449) IDLE(ready,20)
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:45:14 ago, cause: power up
                              Last software reset at 2021-03-03 20:03, reason: User, GCodes spinning, available RAM 15168, slot 1
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU temperature: min 22.2, current 29.6, max 30.0
                              Supply voltage: min 11.6, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
                              Driver 0: position 0, standstill, SG min/max 0/319
                              Driver 1: position 1600, standstill, SG min/max 0/7
                              Driver 2: position -2000, standstill, SG min/max not available
                              Driver 3: position 0, standstill, SG min/max 0/320
                              Driver 4: position 0, standstill, SG min/max not available
                              Driver 5: position 0
                              Driver 6: position 0
                              Driver 7: position 0
                              Driver 8: position 0
                              Driver 9: position 0
                              Driver 10: position 0
                              Driver 11: position 0
                              Date/time: 2021-03-03 22:39:09
                              Cache data hit count 3286832726
                              Slowest loop: 25.80ms; fastest: 0.21ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 1.6ms, write time 79.8ms, max retries 0
                              DMs created 83, maxWait 634476ms, bed compensation in use: none, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 51, completed moves 51, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 40], CDDA state -1
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 186.63ms; fastest: 0.00ms
                              HTTP sessions: 1 of 8
                              • WiFi -
                                Network state is active
                                WiFi firmware version 1.25
                                WiFi MAC address bc:dd:c2:89:a2:58
                                WiFi Vcc 3.43, reset reason Power up
                                WiFi flash size 4194304, free heap 21168
                                WiFi IP address 192.168.1.7
                                WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
                                Clock register 00002002
                                Can you also post your homeall, homex, and config.g as they are right now so we're all looking at the same code?
                                I notice in the video that when you are jogging it around it's with very short small moves. Have you tried longer distance moves yet?
                                undefined 1 Reply Last reply 4 Mar 2021, 03:43 Reply Quote 0
                                  wingtip
                                  M98 P"config.g"
                                  M98 P"config.g"
                                  HTTP is enabled on port 80
                                  FTP is disabled
                                  TELNET is disabled
                                  Error: Temperature reading fault on heater 1: sensor open circuit
                                  homex.g
                                  home x is the only one im using at the moment.
                                    i up'd the current from 1amp (1000mah) to 1.2amp (1200mah) and no change
                                    What is the max rated current for the motors?
                                    undefined 2 Replies Last reply 4 Mar 2021, 03:44 Reply Quote 0
                                      wingtip @Phaedrux
                                      unfortunately at the moment i cant due to the huge mess lol... but months ago i was running it the full distance of 800mm no issues
                                        wingtip @Phaedrux
                                        Ill have to check as they came from openbuilds.com but from the config file you gave me they are now down to 800 mah and still chatter before and after homing..
                                          fcwilt
                                          Re-posting of your homeX.g file
                                          ; homex.g
                                          ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500 (Eastern Standard Time)
                                          G91 ; relative positioning
                                          G1 H1 X-805 F400 ; move quickly to X axis endstop and stop there (first pass) S1 checks for endstop hit
                                          G91
                                          G1 H2 X5 F1800 ; go back a few mm
                                          G1 H1 X-10 F360 ; move slowly to X axis endstop once more (second pass) H1 checks for endstop hit
                                          G92 X0
                                          G90
                                          G1 H2 Z-5 F2000 ; lower Z again
                                          G90 ; absolute positioning
                                          undefined 1 Reply Last reply 4 Mar 2021, 03:45 Reply Quote 0
                                          17 out of 42
