    Motors working then chatter before and after homing...
    2.0k
    • wingtipundefined
      wingtip
      While im waiting for the video to render, the code for the z axis is irrelevant right now as i have them unplugged. As for the comment about the endstops. both end stops trigger and can be seen in the dwc changing states... also, why would the motor chatter before it even moves and gets anywhere near the endstop...? You will see in the video and maybe understand better.... just waiting for my slow computer to render this so i can upload it to youtube and wait for it to process it , then post the link here...
      Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
      • fcwiltundefined
        fcwilt @wingtip
        @wingtip said in Motors working then chatter before and after homing...:
        I only mentioned it because the configurator often inserts that M574 Z1 S2 command even though it is incorrect.
        It will certainly help to see the video. The only thing I have experienced like that affected all motor movements - not just homing.
        Could you post the relevant homing file?
        • wingtipundefined
          wingtip
          https://youtu.be/jRshkrsYCDEhomex.g
            That is indeed strange that movement after M564 S0 H0 works fine, but homing behaves strangely. One thing that occurs to me is that it could be resonance due to the speed of the homing moves compared to the normal travel moves.
            In the gcode console, can you send M122 and M98 P"config.g" and post the results here?
            • wingtipundefined
              wingtip
              M122
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-917NK-F2MS4-7JKD6-3SN6K-9GU4G
              Used output buffers: 3 of 24 (15 max)
              Static ram: 23460
              Dynamic ram: 73376 of which 76 recycled
              Never used RAM 15168, free system stack 115 words
              Tasks: NETWORK(ready,169) HEAT(blocked,200) MAIN(running,449) IDLE(ready,20)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:45:14 ago, cause: power up
              Last software reset at 2021-03-03 20:03, reason: User, GCodes spinning, available RAM 15168, slot 1
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 22.2, current 29.6, max 30.0
              Supply voltage: min 11.6, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 0, standstill, SG min/max 0/319
              Driver 1: position 1600, standstill, SG min/max 0/7
              Driver 2: position -2000, standstill, SG min/max not available
              Driver 3: position 0, standstill, SG min/max 0/320
              Driver 4: position 0, standstill, SG min/max not available
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2021-03-03 22:39:09
              Cache data hit count 3286832726
              Slowest loop: 25.80ms; fastest: 0.21ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 1.6ms, write time 79.8ms, max retries 0
              DMs created 83, maxWait 634476ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 51, completed moves 51, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 40], CDDA state -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 186.63ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.25
                WiFi MAC address bc:dd:c2:89:a2:58
                WiFi Vcc 3.43, reset reason Power up
                WiFi flash size 4194304, free heap 21168
                WiFi IP address 192.168.1.7
                WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
                Clock register 00002002
                Can you also post your homeall, homex, and config.g as they are right now so we're all looking at the same code?
                I notice in the video that when you are jogging it around it's with very short small moves. Have you tried longer distance moves yet?
                wingtipundefined 1 Reply Last reply Reply Quote 0
                • wingtipundefined
                  wingtip
                  @Phaedrux said in Motors working then chatter before and after homing...:
                  M98 P"config.g"
                  M98 P"config.g"
                  HTTP is enabled on port 80
                  FTP is disabled
                  TELNET is disabled
                  Error: Temperature reading fault on heater 1: sensor open circuit
                  homex.g
                  home x is the only one im using at the moment.
                    Phaedrux Moderator @wingtip
                    i up'd the current from 1amp (1000mah) to 1.2amp (1200mah) and no change
                    What is the max rated current for the motors?
                    wingtipundefined 2 Replies Last reply Reply Quote 0
                    • wingtipundefined
                      wingtip @Phaedrux
                      unfortunately at the moment i cant due to the huge mess lol... but months ago i was running it the full distance of 800mm no issues
                      • wingtipundefined
                        wingtip @Phaedrux
                        Ill have to check as they came from openbuilds.com but from the config file you gave me they are now down to 800 mah and still chatter before and after homing..
                        • fcwiltundefined
                          fcwilt
                          Re-posting of your homeX.g file
                          ; homex.g
                          ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500 (Eastern Standard Time)
                          G91                      ; relative positioning
                          G1 H2 Z5 F6000           ; lift Z relative to current position
                          G1 H1 X-805 F400         ; move quickly to X axis endstop and stop there (first pass) S1 checks for endstop hit
                          G91
                          G1 H2 X5 F1800           ; go back a few mm
                          G1 H1 X-10 F360          ; move slowly to X axis endstop once more (second pass) H1 checks for endstop hit
                          G92 X0
                          G90
                          G1 H2 Z-5 F2000          ; lower Z again
                          G90                      ; absolute positioning
                          • fcwiltundefined
                            fcwilt @fcwilt
                            @fcwilt said in Motors working then chatter before and after homing...:
                            Comment out the Z axis commands, move Z clear with the jog buttons, and try homing again.
                              I'm curious if longer moves would actually work jogging around because the short back off move in homex does seem to work ok as do the short jogging moves. If the motor current is too low there may be some back emf issues on long moves since the motors have to spin fairly fast due to being lead screw based.
                              Also, unrelated to the current problem, but will become a problem in the future when you try to use Z. The last Z move you have G90 setting it to absolute positioning and then telling it to go Z-5. Which is not what you want. You want to be using relative moves with G91 so that Z-5 lowers the z axis back down by 5mm.
                              G90
                              • wingtipundefined
                                wingtip @Phaedrux
                                checked, they are rated to 1.68 amps
                                • fcwiltundefined
                                  fcwilt @Phaedrux
                                  @Phaedrux
                                  Given that the chatter is at the beginning and the end perhaps we are hearing the Z axis?
                                  • wingtipundefined
                                    wingtip @fcwilt
                                    i can comment them out but cant jog it, as stated z motors arent plugged in right now.
                                      M92 X400.00 Y80.00 Z400.00 E420.00              ; set steps per mm
                                      M566 X900.00 Y900.00 Z60.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                                      M203 X6000.00 Y6000.00 Z180.00 E1200.00        ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                                      I'm assuming you're using the config.g I posted earlier, these values may not be perfect for your setup.
                                      For the motor currents lets set them to 1400ma which is 80% of the rated max and see if it makes any difference.
                                      M92 X400.00 Are we sure your X axis is 400 steps per mm?
                                      Let's reduce the max speed, jerk, and accel for X as well.
                                      Let's try these
                                      M203 X3000
                                      M201 X300
                                      M566 X300
                                      M906 X1400
                                      • wingtipundefined
                                        wingtip @Phaedrux
                                        Let's try these
                                        M203 X3000
                                        M201 X300
                                        M566 X300
                                        M906 X1400
                                        Will input these right now.....
                                        • fcwiltundefined
                                          fcwilt @wingtip
                                          Well since the chatter occurs at the beginning of the homing and the end but the homing itself works fine the only difference between you jogging X and the homing file is the Z axis commands and they appear at the beginning and end of the homing file.
                                          Thus my suggestion to see if they are the source.
                                            Also, just to eliminate the file, you can send the homing commands manually line by line in the console. The important ones being.
