Auto tune failed due to bad curve fit
1.3k
    Frederik
    i got the following message when i try to PID Tune Tool0 with the slice engineering PT1000 Sensor on on a Toolboard LC1.
    Auto tune failed due to bad curve fit (R=1.946, 1/C=0.0048:0.0036, D=11.6)
    Warning: heater behaviour was not consistent during tuning
    i defined the pt1000 with
    M308 S1 P"121.temp0" Y"pt1000"
    M950 H1 C"121.out0" T1
    M307 H1 B0 S1.00
    M143 H1 S500
    RRF3.3beta1
    Duet3 Mainbord + sbc + Toolboard
    The Tuning works optical perfect, every time the same curve, even when the fan tuning starts , the temp is cycling without any big difference in the same range
    and after around one hour i got this error message
    what could that be ?
    Regards Frederik
    undefined undefined 2 Replies Last reply 4 Mar 2021, 04:01 Reply Quote 0
      fcwilt
      Could you, as a test, connect those parts to the 6HC and see if it works there?
      I suggest that only because there are some indications, as yet unconfirmed, that there may be CAN bus issues in the firmware.
      undefined 1 Reply Last reply 4 Mar 2021, 04:09 Reply Quote 0
        Phaedrux Moderator @Frederik
        @Frederik said in Auto tune failed due to bad curve fit:
        It means that the heating and cooling rates didn't settle down to consistent values after several cycles. One possible reason is noise in the temperature sensor readings, which would be apparent in temperature graph.
        Possibly noise or poor connection in the sensor wiring as well.
        undefined 1 Reply Last reply 4 Mar 2021, 04:03 Reply Quote 0
          fcwilt @Phaedrux
          @Phaedrux said in Auto tune failed due to bad curve fit:
          Understood.
          undefined 1 Reply Last reply 4 Mar 2021, 04:08 Reply Quote 0
            Phaedrux Moderator @fcwilt
            @fcwilt said in Auto tune failed due to bad curve fit:
            Understood.
            That's what DC42 tells me anyway. I barely understand it myself. 🙂
              This would be an interesting test.
              undefined 1 Reply Last reply 4 Mar 2021, 08:53 Reply Quote 0
                Frederik @Phaedrux
                @Phaedrux @fcwilt
                good morning,
                Yes, I can test that
                The wiring is complete new from sensor and heater + the sensors itself.
                It shows the correct room temperature.
                Its a 65W heater and the slice engineering rtd pt1000 sensor. Perhaps with 8cm of cable lenght from sensor to toolboard
                This Pic is shit from the transition tool fan off to on
                  dc42 administrators @Frederik
                  RRF3.3beta1
                  The reason it's failing is that the measured cooling rate with the fan on is actually lower than with the fan off:
                   1/C=0.0048:0.0036
                  The second figure should be higher than the first one, unless there is a mechanism I haven't thought of whereby turning on the print cooling fan actually reduces the cooling of the hot end. Assuming that the print cooling fan is configured correctly, it seems that turning on the print cooling fan has negligible cooling effect on your hot end, and there is sufficient variability in the measurements that the second cooling rate measurement is lower than the first one.
                  I suggest you tune that hot end using M303 with H parameter instead of with T parameter, so that it doesn't tune it with fan off and then with fan on.
                  What type of hot end is it?
                  EDIT: you published your temperature graph as I was composing that message. That graph does show that turning on the fan has an effect.
                  undefined 1 Reply Last reply 4 Mar 2021, 09:14 Reply Quote 0
                    Frederik @dc42
                    @dc42 it's a original mosquito magnum with a 65W heater and the white thermal insulation ring installed. Nozzle is nickel plated copper.
                    But I am running it with a 40mm fan instead of the 25mm one at around 25%
                    The picture above was a pid tune at 300°C with all fans at 100%
                    Another pid tu e I tried was 400°C with the tool fan at 40% and the part cooling fan at 35% with the same results.
                    This is my Printhead with cabling and fan duct out of PC
                      Thanks. I will check how the cooling rate with fan on is calculated from the data. In your temperature graph, it looks like the cooling segments have much the same lengths with fan on as with fan off, however the heating segments are much longer with fan on.
                      undefined 1 Reply Last reply 4 Mar 2021, 09:21 Reply Quote 0
                        Frederik @dc42
                        @dc42 I will try a tune with a lower temperature and a tune with the heater and sensor connected to the mainboard
                        undefined 1 Reply Last reply 4 Mar 2021, 09:24 Reply Quote 0
                          When you tune it with it connected to the main board, please use the same temperature as you did before, so that I can compare the results directly.
                          undefined 2 Replies Last reply 4 Mar 2021, 10:00 Reply Quote 0
                            Frederik @dc42
                            @dc42 ok, I will test it as soon as I am back from work
                              Frederik @dc42
                              Today i had time to test the PID Tuning with the sensors connected to the duet 3 Mainboard.
                              The Tuning completed succesfully wih the following message:
                              Auto tuning heater 1 completed after 4 idle and 21 tuning cycles in
                              1540 seconds. This heater needs the following M307 command:
                              M307 H1 R2.420 C186.9:181.7 D9.54 S1.00 V24.0
                              I made a new photo at the moment from tuning with fan off, to fan on
                              All other parameters where the same
                              M303 T0 300
                                Thanks! I can see that this time it measured a slightly higher cooling rate with the fan on (which is why tuning worked), however the temperature graph shows that the temperature rises much more slowly with the fan on, indicating that the fan has a substantial effect. I will review how RRF measures the cooling rate.
                                undefined 1 Reply Last reply 8 Mar 2021, 11:56 Reply Quote 0
                                  Frederik @dc42
                                  @dc42 Ok, Thank you
                                  The Part Fan is one 5015 Blower and the Hotend cooling Fan a 40mm Sunon that is running for testing between 40 and 100 %
                                  10 out of 16
