    Intermittent extruder loss and stutters. 6HC/toolboard/RRF3.2
    59
    3.0k
    • oliofundefined
      oliof @hamel
      @hamel said in Intermittent extruder loss and stutters. 6HC/toolboard/RRF3.2:
      I have connected a separate motor to it for testing, and it will not turn the motor, just jitters.
      Are you sure your separate motor has the same wiring as the one you use on the extruder? I.e., phase pairs neighboring. Different motors by different manufacturers may have a different order of wires (can be fixed by changing the order of crimps in the connector).
      hamelundefined 1 Reply Last reply Reply Quote 0
      • hamelundefined
        hamel @oliof
        @oliof Yes, the coil pairs are the same as the one that I tested with. Both act the same, and no wiring was changed since it was working properly.
        • hamelundefined
          hamel
          @dc42 SD imager is giving me trouble, so I will make the SD at home tonight and test it tomorrow.
          For a test I assigned the toolboard driver to the x axis, and I also get the same performance (lack of any torque to even move the motor alone).
            Thanks @hamel, it does sound that there is a problem either with the driver or the motor connection. When you tested it with a different motor, did you use the same connector to plug into the tool board motor connector as when using the original motor, or did you use a different connector?
            • hamelundefined
              hamel @dc42
              @dc42 Same connector. I have another I can test with. I was initially leading towards not being a wiring issue, as I was able to extrude with DWS earlier in a pause when it was not extruding in the print, but now with no function at all I agree that I should swap them out. I have a few here for my toolchanger that are known good. I'll report back tomorrow with a standalone SD test and a swap of the wires.
              • hamelundefined
                hamel
                All, I just wanted to give an update. Standalone changed nothing. New cable changed nothing. It seems that my motor was the curprit. It must have been going bad, and something about the speed of the commands sent by DWC allowed it to work a little until it finally failed. Dead coil. New one on the way. Thanks for all of the help looking into this.
                  dc42 administrators @hamel
                  Thanks for the update, I'm glad you solved it.
                  It's rare for a motor coil to burn out, unless you have run it above its rated current for an extended period. My guess is that if you take the motor apart, you will find a bad connection between one of the windings and the connector if it has one, or the leads if it doesn't.
                    deckingman @dc42
                    @dc42 Probably just a coincidence, but I mentioned in another thread that I've had 3 of my 6 extruder motors connected to expansion boards fail in the last 18 months. When the last one failed, I assumed that it was a bad batch so I replaced all 6 and I haven't had a failure since. Can you think of any reason other than I'm just unlucky and/or it was probably a bad batch of motors? (Motor currents always set to 85% of quoted rated current).
                    • hamelundefined
                      hamel
                      I did set to rated current during testing, but never over. I usually stick to 80% rated current, but I got desperate when troubleshooting and shot it up to 100% for a few tests. That might have done it in, as it isn't an especially nice stepper. I did tear it down, and one winding had a break about 5mm from the connection to the leads. I'll see if I can save it.
                      I have never had a motor burn up, so I didn't really focus on that. Thank you all for the prompt help in diagnosing this rather stupid problem.
                        Running at rated current should not cause a problem, because the rated current is normally quoted with both phases energised, whereas microstepping drivers only energise one phase at the full peak current at a time (and currents set by M906 in RRF are peak currents).
                        If the break was caused by excessive current, I would expect to see blackening of the wires.
                        • hamelundefined
                          hamel
                          Well, the issue has come back. Same symptoms. I get really bad motor movement with the gcode files while printing, but I can pause and extrude just fine with DWC. Any idea what I should be looking at next? I have swapped the motor to a much more powerful one that I just had lying around, and it can really crank out the extrudes in DWC, but when I go to print, it just stutters and skips steps. I have dropped the acceleration and jerk to 500, and I still have the issue. I do not think it is the settings, as I can extrude with those settings in DWC with no issue. When printing, I do not think the toolboard driver is giving good commands, but I have no idea why that would be.
                          M550 P"Duet 3" ; set printer name
                          M669 K1 ; select CoreXY mode
                          G4 S1 ;wait for expansion boards to start
                          M569 P121.0 S1 ; physical drive 121.0 goes forwards
                          M569 P0.3 S0 ; physical drive 0.2 goes forwards
                          M569 P0.4 S0 ; physical drive 0.2 goes forwards
                          M569 P0.5 S1 ; physical drive 0.2 goes forwards
                          M584 X0.1 Y0.0 Z0.2:0.3:0.5:0.4 E121.0 ; set drive mapping
                          M92 X98.00 Y98.00 Z400.00 E426.00 ; set steps per mm
                          M566 X2500.00 Y2500.00 Z200.00 E200.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X10000.00 Y10000.00 Z8000.00 E3000.00 ; set maximum speeds (mm/min)
                          M201 X3000.00 Y3000.00 Z200.00 E200.00 ; set accelerations (mm/s^2)
                          M906 X1100 Y1100 Z1000 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X-200 Y-200 Z-1 S1 ; set axis minima
                          M208 X200 Y200 Z400 S0 ; set axis maxima
                          ; Leadscrew Locations
                          M671 X-322.5:-322.5:262.5:262.5 Y-250:300:300:-250 S20 F1.2 ; Z leadscrew positions
                          M574 X2 S1 P"io0.in" ; X min active low endstop switch
                          M574 Y2 S1 P"io1.in" ; Y min active low endstop switch
                          M574 Z1 S2
                          M558 P8 C"^!121.io0.in" H5 F300 T16000 ; set Z probe type to unfiltered switch and the dive height + speeds
                          M558 H15 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                          G31 P500 X0 Y0 Z1 ; set Z probe trigger value, offset and trigger height
                          M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                          M557 X-200:200 Y-200:200 S100 ; define mesh grid
                          M308 S0 P"temp3" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
                          M307 H0 B0 S0.50 ; disable bang-bang mode for the bed heater and set PWM limit
                          M143 H0 S150 ; set temperature limit for heater 0 to 120C
                          M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0
                          M950 H1 C"nil"
                          M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
                          M307 H1 B0 S0.5 ; disable bang-bang mode for heater and set PWM limit
                          M143 H1 S350 ; set temperature limit for heater 1 to 350C
                          M950 F0 C"nil"
                          M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out1 and set its frequency
                          M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out2 and set its frequency
                          T0 ; select first tool
                          m122
                          RepRapFirmware for Duet 3 MB6HC version 3.3beta1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
                          Board ID: 08DJM-956L2-G43S8-6JTDL-3SD6J-1S3YF
                          Used output buffers: 1 of 40 (10 max)
                          Static ram: 148196
                          Dynamic ram: 61484 of which 500 recycled
                          Never used RAM 140492, free system stack 121 words
                          Tasks: Linux(ready,143) HEAT(delaying,302) CanReceiv(notifyWait,799) CanSender(notifyWait,359) CanClock(delaying,349) TMC(notifyWait,18) MAIN(running,616) IDLE(ready,20)
                          Owned mutexes: HTTP(MAIN)
                          Last reset 00:13:58 ago, cause: power up
                          Last software reset at 2021-03-05 23:49, reason: User, none spinning, available RAM 140492, slot 0
                          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          MCU temperature: min 28.9, current 51.2, max 51.3
                          Supply voltage: min 27.9, current 30.0, max 30.2, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
                          Driver 0: position 0, standstill, reads 48788, writes 31 timeouts 0, SG min/max 0/271
                          Driver 1: position 0, standstill, reads 48788, writes 31 timeouts 0, SG min/max 0/505
                          Driver 2: position 22080, standstill, reads 48784, writes 35 timeouts 0, SG min/max 0/263
                          Driver 3: position 0, standstill, reads 48784, writes 35 timeouts 0, SG min/max 0/277
                          Driver 4: position 0, standstill, reads 48785, writes 35 timeouts 0, SG min/max 0/259
                          Driver 5: position 0, standstill, reads 48785, writes 35 timeouts 0, SG min/max 0/201
                          Date/time: 2021-03-08 15:16:32
                          Slowest loop: 171.53ms; fastest: 0.03ms
                          === Storage ===
                          Free file entries: 10
                          DMs created 125, maxWait 180288ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 448, completed moves 448, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 15], CDDA state -1
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          Telnet is idle in state(s) 0
                          File* is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Queue* is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0 0, running macro
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === CAN ===
                          Messages queued 8761, send timeouts 26, received 9733, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 57602, free buffers 49 (min 47)
                          === SBC interface ===
                          State: 4, failed transfers: 0
                          Last transfer: 1ms ago
                          RX/TX seq numbers: 29686/29686
                          SPI underruns 0, overruns 0
                          Number of disconnects: 0, IAP RAM available 0x2d410
                          Buffer RX/TX: 0/0-0
                          === Duet Control Server ===
                          Duet Control Server v3.2.0
                          Code buffer space: 4096
                          Full transfers per second: 8.35
                          Maximum length of RX/TX data transfers: 2588/1520
                          m122 b121
                          Diagnostics for board 121:
                          Duet TOOL1LC firmware version 3.3beta1 (2021-02-14 16:34:04)
                          Bootloader ID: not available
                          Never used RAM 3976, free system stack 0 words
                          Tasks: Move(notifyWait,90) HEAT(delaying,91) CanAsync(notifyWait,67) CanRecv(notifyWait,75) CanClock(notifyWait,67) TMC(delaying,56) MAIN(running,252) AIN(delaying,63)
                          Last reset 00:14:41 ago, cause: power up
                          Last software reset data not available
                          Driver 0: position 34448, 426.0 steps/mm, standstill, SG min/max 0/282, read errors 0, write errors 0, ifcnt 20, reads 47135, writes 20, timeouts 0, DMA errors 0, steps req 81994 done 81994
                          Moves scheduled 1234, completed 1234, in progress 0, hiccups 0, step errors 0, maxPrep 532, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                          Peak sync jitter 9, peak Rx sync delay 610, resyncs 1, no step interrupt scheduled
                          VIN: 29.9V
                          MCU temperature: min 25.8C, current 37.0C, max 42.1C
                          Ticks since heat task active 249, ADC conversions started 878201, completed 878201, timed out 0
                          Last sensors broadcast 0x00000002 found 1 5 ticks ago, loop time 0
                          CAN messages queued 10272, send timeouts 0, received 9157, lost 0, free buffers 36, min 35, error reg 0
                          dup 0, oos 0, bm 0, wbm 0
                            If it's an intermittent issue, then the most likely causes are:
                            • Bad crimp connection in the motor cable. Are you using the same cable as before?
                            • Bad solder joint between the driver chip and the PCB. Axz the pads of the driver under underneath the chip, it's impossible to tell whether the soldering is good on all pads other than by X-ray; although if you can look at the edges of the chip using microscope, you might get a clue.
                            • Bad solder joint between the motor connector and the PCB. Unlikely, but not impossible.
                            • hamelundefined
                              hamel @dc42
                              @dc42 Thank you for the reply.
                              Just to recap, as I know I have been changing things around a bunch...and my symptoms changed for a bit due to the bad motor giving me a runaround:
                              New cable. Known good crimps. Known good pinout/coil pairs. New motor that is much larger running at 80% rated current (rated at 1.2A). Soldering on the board in general looks OK, slightly blobby, but nothing that looks like it would make me questions the soldering on the chip. Solder joints to the connector looks fine as well. Wire wiggles do not affect anything, and no driver faults reported.
                              When printing, it skips steps like it has a loss of torque. I can hear and see the motor try to move, but even with the motor off the extruder and no load, it skips when printing. If I pause the printer, it will extrude with DWC just fine. I can really crank the rate, and I can grab the motor gear and it will just rip past my hands. While printing and motor with no load on it, it has no torque and I can stall it easily with barely touching it, and it often skips steps with no load on the motor.
                              The weird intermittent side of things is that I can print, reboot, print, reboot, print, and after a totally random number of reboots and prints, it will extrude with full torque. The extruder working is definitely the exception, as it is almost always not working while printing. When it does work while printing, it only stops working again if I cancel the print and restart.
                              This really does not feel like wiring to me, but since I am at a loss here, I have checked it all over with back probes. All have good connections. I am at a total loss, and I am totally up for reworking all of the diagnosis that has been done, but I do not know what general area I should be going over again. Thoughts @dc42 ? Again, thank you for the help.
                              This is frustrating, as everything looks correct to the best of my (little) knowledge with RRF3. I am a research engineer, and can work any angle you think needs to be worked. I do have an x-ray in my building, and if you really think it is necessary, I can have someone scan it. I am hesitant, as the "intermittent"ness of this doesn't cry connection to me, but sounds more like the driver is not sending full power when reading the gcode. But I am at a loss right now, and other than removing the toolboard and going to an expansion, I am not sure what the next steps should be.
                              I have an 8 tool custom printer running toolboards and duet3, and it gave me no issues at all (sans the fun firmware learning curve). I am not sure how I am unable to get this simple Voron printer running with a toolboard and duet3.
                                jay_s_uk @hamel
                                @hamel sounds a lot like this thread
                                https://forum.duet3d.com/topic/21922/expansion-3hc-m906-not-working-properly
                                hamelundefined 2 Replies Last reply Reply Quote 0
                                • hamelundefined
                                  hamel @jay_s_uk
                                  @jay_s_uk Thank you for that. It does seem similar. I do have a G4 S1 to wait for boards to boot, but I will give it a try with an S5.
                                  • hamelundefined
                                    hamel @jay_s_uk
                                    @jay_s_uk No change. Still extrudes fine with DWC, but when I go to print, it has no torque and just skips. When the motor is loose, same issue with no torque when printing from gcode.
                                    • hamelundefined
                                      hamel
                                      Just as an additional note, the driver on the LC1 is loud as well. It is in idle hold now, and is singing like it was trying to hold position with great strain, but it is loose and not loaded.
                                      • hamelundefined
                                        hamel
                                        https://photos.app.goo.gl/6BLAn9YM2FAjzoWh6
                                          Very strange. Can you post your start gcode and pause and resume files?
                                          • hamelundefined
                                            hamel @Phaedrux
                                            @Phaedrux Yes, this is a first for me, and I use Duet for most things here, not just FFF printers. This was just a "let's build a printer with the spares that we have", and we chose Voron. Seems like this should be quite simple to get running, but this issue has been plaguing me for almost a month since the machine was built and wired. I don't know what else to try.
                                            Start:
                                            T0
                                            G28
                                            Pause:
                                            M83 ; relative extruder moves
                                            G1 E-2 F3600 ; retract 2mm of filament
                                            G91 ; relative positioning
                                            G1 Z20 F360 ; lift Z by 20mm
                                            G90 ; absolute positioning
                                            G1 X0 Y0 F6000 ; go to X=0 Y=0
                                            Resume:
                                            G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
                                            G1 R1 X0 Y0 ; go back to the last print move
                                            G1 E2 F3600 ; extrude 2mm of filament
