    Duet 2 wifi not connecting to Paneldue 7i
    1.1k
    • 3dpnutundefined
      3dpnut
      A screw fell onto the motherboard and blew the fuses. I purchased a replacement board and Paneldue from CapstoneCADEM. After installing both boards the paneldue says "connecting" and doesn't control anything. It also will not connect to wifi. I tried everything I could find on the forum, M552 S1 finds the network, then says " no known networks found", then continues in the same order to loop. I've reflashed the firmware, replaced the cable, no luck. The bad part is I have work mounding up - please somebody help!!
        Can you connect via USB terminal and get some information from the new board?
        M115 to get the currently installed firmware version.
        M122 to get a diagnostic report and wifi server version.
        Before you can connect it to wifi you'll need to add your wifi network SSID and password.
        Is the Paneldue working to communicate with the Duet at all? What firmware is on the PanelDue? Check on the setup page.
        https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        • 3dpnutundefined
          3dpnut
          @Phaedrux thanks for the reply.
          M115: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
          ok
          M122:
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S4-6J9F6-3SD6J-1U1GL
          Used output buffers: 1 of 24 (2 max)
          Static ram: 27980
          Dynamic ram: 93916 of which 44 recycled
          Exception stack ram used: 308
          Never used ram: 8824
          Tasks: NETWORK(ready,1892) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
          Owned mutexes:
          Last reset 00:01:24 ago, cause: power up
          Last software reset details not available
          Error status: 0
          MCU temperature: min -72.1, current -67.6, max -65.6
          Supply voltage: min 16.3, current 16.3, max 16.7, under voltage events: 0, over voltage events: 0, power good: yes
          Cache data hit count 140654521
          Slowest loop: 5.06ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.1ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is ready with "m122" in state(s) 0
          Aux is assembling a command in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 0.25ms; fastest: 0.00ms
          HTTP sessions: 0 of 8
          • WiFi -
            Network state is starting2
            WiFi module is disabled
            ok
          • 3dpnutundefined
            3dpnut
            I put the M552 S"Network" P"Password" in, and it says "ok", but doesn't give me the IP address...
              Send M552 by itself. It should respond with an IP address
              If not, send M552 S1.
              @3dpnut said in Duet 2 wifi not connecting to Paneldue 7i:
              Seems like an off temperature for the MCU and odd voltage?
              • 3dpnutundefined
                3dpnut
                The MCU temp should read close to room temp, which is 69 deg F, any ideas why this reading? Also, I'm feeding in 24v (which I've checked and is correct), so no idea why it's reading 16v.
                  Did M552 work?
                  3dpnutundefined 1 Reply Last reply Reply Quote 0
                    droftarts administrators @3dpnut
                    VIN is measured by feeding it through a voltage divider into an ADC input. So either the ADC in the microcontroller is faulty, or the ADC reference voltage (ADCVREF) is much higher than the intended 3.3V. You can measure ADCVREF, it's pin 41 on the expansion connector.
                    Is this a new board? Do you still get the same readings with the PanelDue disconnected?
                      The VIN reading reads low if you connect the PanelDue to the wrong connector. When using the ribbon cable it must be connected to CONN_SD, not CONN_LCD.
                      • 3dpnutundefined
                        3dpnut @Phaedrux
                        @Phaedrux This is what I'm getting:
                        M552
                        WiFi module is being started
                        ok
                        M552 s1
                        Turn off the current WiFi mode before selecting a new one
                        ok
                        M552 S0
                        ok
                        M552 S1
                        ok
                        M552 S0
                        ok
                        M552
                        ok
                        M552 S1
                        ok
                        • 3dpnutundefined
                          3dpnut @dc42
                          @dc42 Thank you! I made the change and now it's speaking to the Paneldue. Still no luck with the wifi tho
                            dc42 administrators @3dpnut
                            Please send M997 S1 from either USB or PanelDue to re-install the WiFi firmware. The message "WiFi module is being started" persisting usually means that the WiFi firmware is not running.
                            3dpnutundefined 2 Replies Last reply Reply Quote 0
                            • 3dpnutundefined
                              3dpnut @dc42
                              @dc42 I'm trying to load the results of M997 S1 and the subsequent M552's, but it blocking me as spam by Askimet.com
                              • 3dpnutundefined
                                3dpnut @dc42
                                @dc42 I'll try again:
                                This is what I get after successfully running M997 S1:
                                95% complete
                                Upload successful
                                ok
                                M552 s1
                                ok
                                WiFi module started
                                WiFi reported error: no known networks found
                                WiFi module is idle
                                WiFi module is idle
                                WiFi module is idle
                                WiFi module is idle
                                M552 s0
                                ok
                                WiFi module is idle
                                M552 S1
                                ok
                                WiFi module is idle
                                WiFi module is idle
                                WiFi module is idle
                                  Ok, the no networks found means that you now need to give it a SSID and password for your wifi network using the M587 command.
                                  https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                                  You should now be able to complete the getting connected guide
                                  https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
                                  • 3dpnutundefined
                                    3dpnut
                                    Thanks all!! Everything is now working with the exception of a Z homing issue, which I think I can (hopefully :)) figure out. Have a great weekend!
                                    • 3dpnutundefined
                                      3dpnut
                                      I turned the machine on today, and it seems like I turned back the clock 2 weeks. The same thing is happening, not connecting to Wifi. I've run through the same cycles which fixed it last time, no luck. I ran M997 S1, and it re-installed the firmware fine. Then ran M552 S0, OK. Then M552 S1, OK. Then M587 S"xx" P"xx", and it says OK, then times out and says wifi module is idle. My computer is connected to the same network and is connected no problem. I double-checked the password and it's correct.
                                      What am I doing wrong?
                                        If you send M587 by itself does it list back your network details?
                                        • 3dpnutundefined
                                          3dpnut
                                          Sends back:
                                          6Dh 35h 38h 37h
                                            Are those SSIDs?
