    Duet 2 wifi not connecting to Paneldue 7i
    1.1k
    • 3dpnutundefined
      3dpnut
      @Phaedrux thanks for the reply.
      M115: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      ok
      M122:
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6B2-NJ4S4-6J9F6-3SD6J-1U1GL
      Used output buffers: 1 of 24 (2 max)
      Static ram: 27980
      Dynamic ram: 93916 of which 44 recycled
      Exception stack ram used: 308
      Never used ram: 8824
      Tasks: NETWORK(ready,1892) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
      Owned mutexes:
      Last reset 00:01:24 ago, cause: power up
      Last software reset details not available
      Error status: 0
      MCU temperature: min -72.1, current -67.6, max -65.6
      Supply voltage: min 16.3, current 16.3, max 16.7, under voltage events: 0, over voltage events: 0, power good: yes
      Cache data hit count 140654521
      Slowest loop: 5.06ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.1ms, write time 0.0ms, max retries 0
      Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
      === MainDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "m122" in state(s) 0
      Aux is assembling a command in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.25ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is starting2
        WiFi module is disabled
        ok
      • 3dpnutundefined
        3dpnut
        I put the M552 S"Network" P"Password" in, and it says "ok", but doesn't give me the IP address...
          Send M552 by itself. It should respond with an IP address
          If not, send M552 S1.
          @3dpnut said in Duet 2 wifi not connecting to Paneldue 7i:
          Seems like an off temperature for the MCU and odd voltage?
          • 3dpnutundefined
            3dpnut
            The MCU temp should read close to room temp, which is 69 deg F, any ideas why this reading? Also, I'm feeding in 24v (which I've checked and is correct), so no idea why it's reading 16v.
              Did M552 work?
              3dpnutundefined 1 Reply Last reply Reply Quote 0
                droftarts administrators @3dpnut
                VIN is measured by feeding it through a voltage divider into an ADC input. So either the ADC in the microcontroller is faulty, or the ADC reference voltage (ADCVREF) is much higher than the intended 3.3V. You can measure ADCVREF, it's pin 41 on the expansion connector.
                Is this a new board? Do you still get the same readings with the PanelDue disconnected?
                  The VIN reading reads low if you connect the PanelDue to the wrong connector. When using the ribbon cable it must be connected to CONN_SD, not CONN_LCD.
                  • 3dpnutundefined
                    3dpnut @Phaedrux
                    @Phaedrux This is what I'm getting:
                    M552
                    WiFi module is being started
                    ok
                    M552 s1
                    Turn off the current WiFi mode before selecting a new one
                    ok
                    M552 S0
                    ok
                    M552 S1
                    ok
                    M552 S0
                    ok
                    M552
                    ok
                    M552 S1
                    ok
                    • 3dpnutundefined
                      3dpnut @dc42
                      @dc42 Thank you! I made the change and now it's speaking to the Paneldue. Still no luck with the wifi tho
                        dc42 administrators @3dpnut
                        Please send M997 S1 from either USB or PanelDue to re-install the WiFi firmware. The message "WiFi module is being started" persisting usually means that the WiFi firmware is not running.
                        3dpnutundefined 2 Replies Last reply Reply Quote 0
                        • 3dpnutundefined
                          3dpnut @dc42
                          @dc42 I'm trying to load the results of M997 S1 and the subsequent M552's, but it blocking me as spam by Askimet.com
                          • 3dpnutundefined
                            3dpnut @dc42
                            @dc42 I'll try again:
                            This is what I get after successfully running M997 S1:
                            95% complete
                            Upload successful
                            ok
                            M552 s1
                            ok
                            WiFi module started
                            WiFi reported error: no known networks found
                            WiFi module is idle
                            WiFi module is idle
                            WiFi module is idle
                            WiFi module is idle
                            M552 s0
                            ok
                            WiFi module is idle
                            M552 S1
                            ok
                            WiFi module is idle
                            WiFi module is idle
                            WiFi module is idle
                              Ok, the no networks found means that you now need to give it a SSID and password for your wifi network using the M587 command.
                              https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                              You should now be able to complete the getting connected guide
                              https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
                              • 3dpnutundefined
                                3dpnut
                                Thanks all!! Everything is now working with the exception of a Z homing issue, which I think I can (hopefully :)) figure out. Have a great weekend!
                                • 3dpnutundefined
                                  3dpnut
                                  I turned the machine on today, and it seems like I turned back the clock 2 weeks. The same thing is happening, not connecting to Wifi. I've run through the same cycles which fixed it last time, no luck. I ran M997 S1, and it re-installed the firmware fine. Then ran M552 S0, OK. Then M552 S1, OK. Then M587 S"xx" P"xx", and it says OK, then times out and says wifi module is idle. My computer is connected to the same network and is connected no problem. I double-checked the password and it's correct.
                                  What am I doing wrong?
                                    If you send M587 by itself does it list back your network details?
                                    • 3dpnutundefined
                                      3dpnut
                                      Sends back:
                                      6Dh 35h 38h 37h
                                        Are those SSIDs?
                                        • 3dpnutundefined
                                          3dpnut @Phaedrux
                                          @Phaedrux I don't know what they are. I changed my terminal type from binary to text, and it's connected now. Previously I had to change it the other way for it to work...not sure what the correct setting is for that.
                                            I'm not sure what you're talking about, but it sounds like it's working now?
