    Duet 2 wifi not connecting to Paneldue 7i
    1.0k
    • 3dpnutundefined
      3dpnut @Phaedrux
      @Phaedrux This is what I'm getting:
      M552
      WiFi module is being started
      ok
      M552 s1
      Turn off the current WiFi mode before selecting a new one
      ok
      M552 S0
      ok
      M552 S1
      ok
      M552 S0
      ok
      M552
      ok
      M552 S1
      ok
      • 3dpnutundefined
        3dpnut @dc42
        @dc42 Thank you! I made the change and now it's speaking to the Paneldue. Still no luck with the wifi tho
          dc42 administrators @3dpnut
          @3dpnut said in Duet 2 wifi not connecting to Paneldue 7i:
          Please send M997 S1 from either USB or PanelDue to re-install the WiFi firmware. The message "WiFi module is being started" persisting usually means that the WiFi firmware is not running.
          3dpnutundefined 2 Replies Last reply Reply Quote 0
          • 3dpnutundefined
            3dpnut @dc42
            @dc42 I'm trying to load the results of M997 S1 and the subsequent M552's, but it blocking me as spam by Askimet.com
            • 3dpnutundefined
              3dpnut @dc42
              @dc42 I'll try again:
              This is what I get after successfully running M997 S1:
              95% complete
              Upload successful
              ok
              M552 s1
              ok
              WiFi module started
              WiFi reported error: no known networks found
              WiFi module is idle
              WiFi module is idle
              WiFi module is idle
              WiFi module is idle
              M552 s0
              ok
              WiFi module is idle
              M552 S1
              ok
              WiFi module is idle
              WiFi module is idle
              WiFi module is idle
                Ok, the no networks found means that you now need to give it a SSID and password for your wifi network using the M587 command.
                https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
                You should now be able to complete the getting connected guide
                https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s9
                • 3dpnutundefined
                  3dpnut
                  Thanks all!! Everything is now working with the exception of a Z homing issue, which I think I can (hopefully :)) figure out. Have a great weekend!
                  • 3dpnutundefined
                    3dpnut
                    I turned the machine on today, and it seems like I turned back the clock 2 weeks. The same thing is happening, not connecting to Wifi. I've run through the same cycles which fixed it last time, no luck. I ran M997 S1, and it re-installed the firmware fine. Then ran M552 S0, OK. Then M552 S1, OK. Then M587 S"xx" P"xx", and it says OK, then times out and says wifi module is idle. My computer is connected to the same network and is connected no problem. I double-checked the password and it's correct.
                    What am I doing wrong?
                      If you send M587 by itself does it list back your network details?
                      • 3dpnutundefined
                        3dpnut
                        Sends back:
                        6Dh 35h 38h 37h
                          Are those SSIDs?
                          3dpnutundefined 1 Reply Last reply Reply Quote 0
                          • 3dpnutundefined
                            3dpnut @Phaedrux
                            @Phaedrux I don't know what they are. I changed my terminal type from binary to text, and it's connected now. Previously I had to change it the other way for it to work...not sure what the correct setting is for that.
                              I'm not sure what you're talking about, but it sounds like it's working now?
                              • 3dpnutundefined
                                3dpnut @Phaedrux
                                @Phaedrux Sorry, its a setting in YAT. It is connected now, fingers crossed it stays that way!
