    Designing a PWM to Analog mini board for fans
    139
    12.4k
    • taconiteundefined
      taconite
      haven't heard about the pulsein function aswell. I wanted to get the 24V (or 12V) PWM into an equivalent 5V analog voltage hence the optocoupler. But principle should work, shouldn't it?
      EDIT:
      @Egon-Net said in Designing a PWM to Analog mini board for fans:
      @taconite said in Designing a PWM to Analog mini board for fans:
      @Egon-Net
      mhh thats a bummer πŸ˜• . I wanted to do 12V PWM to 5 V analog.
      But as it seems you are a specialist in electronics. Do you have an idea why this simple optocoupler didn't work for that purpose:
      https://forum.duet3d.com/topic/19325/powering-arduino-nano-and-leds-from-5v-rail/12
      Do you realize you could just use the PWM- from duet and 5V instead of Duet's Fan Vcc? You are not forced to use 24V/12V from Duet.
      Here you have a example just with passive components:
      Since your load is Arduino's analog input, and assuming it has quite a high input impendance (IIRC, 1MOhm) you could just pull-up with your 5V supply with a 1K resistor (5mA current draw) and use VFan- from Duet (which is a PWM open drain). You'll have a little offset from de resistive divisor around A1, but it would be small. According my simulations, 2.3V for 50% PWM, 0V for 0% PWM and 4.54V por 100% PWM. You can play with R2 and C1 values a bit more to achieve even better results (for example 10k-10u).
      Of course you could also use my board, but I think your problem doesn't need it.
      Oh no I didn't know that this would be possible - thanks!
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • Egon.Netundefined
        Egon.Net
        Well, I think I have the final design:
        Besides minor cosmetic changes, I've added a jumper column to select PWM active high or active low with two jumpers. You can put the pins and jumpers or just solder it fixed. The silkscreen guides you about which ones to short por PWM active HIGH or PWM active LOW. PCB now is a bit bigger, but I think is worth it.
        Any comments before I launch the order?
        • gaweyoundefined
          gaweyo
          Nice work! Could you perhaps add a surface mount pad to the diode so the same board can accommodate both the through hole and surface mount part?
          Egon.Netundefined 1 Reply Last reply Reply Quote 0
          • Egon.Netundefined
            Egon.Net @gaweyo
            @gaweyo said in Designing a PWM to Analog mini board for fans:
            Good idea!
            • fcwiltundefined
              fcwilt @Egon.Net
              Are you going to have someone install the parts? Or at least the SMDs?
              • Egon.Netundefined
                Egon.Net @fcwilt
                @fcwilt said in Designing a PWM to Analog mini board for fans:
                I'll do it by myself, I have a hot air soldering station and I've build many smd boards already.
                BTW, @gaweyo, I've just added the smd diode footprint πŸ™‚
                • fcwiltundefined
                  fcwilt @Egon.Net
                  That's a skill I have never tried. I have a hot air soldering station but the project I purchased it for got canceled.
                  So there it sets new and unused.
                  How much are you going to be selling them for - say 25 units.
                  Egon.Netundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                  • Egon.Netundefined
                    Egon.Net @fcwilt
                    I haven't calculated costs yet, but I my plan is just sharing the costs, just not to loose with each board. Once I have the prototype board working, I'll put a price for the DIY kit (board+components), just the bare PCB, and the complete mounted and tested board. And of course, I can send the gerbers for free too.
                    Would kind of kit would you need? Bare, components kit, mounted...?
                    fcwiltundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @Egon.Net
                      As busy as I am I would prefer completely assembled units - ready to install in a printer.
                      And you should price them to make some profit.
                      • zaptaundefined
                        zapta @fcwilt
                        You can try one of those practice kits instead. https://www.aliexpress.com/item/32909277203.html
                        A solder iron, flux paste, and solder are all you need. A cheap Chinese stereoscopic optical microscope makes even easier.
                        • fcwiltundefined
                          fcwilt @zapta
                          @zapta said in Designing a PWM to Analog mini board for fans:
                          Great idea.
                          I actually have all of those.
                          • zaptaundefined
                            zapta @Egon.Net
                            @Egon-Net, one option you have is ordering assembled from vendors such as JLCPCB.
                            https://jlcpcb.com/smt-assembly
                            You may need to make design changes to reduce cost and use their standard parts. https://jlcpcb.com/parts
                            https://www.youtube.com/results?search_query=jlcpcb+assembly
                            Just an idea.
                            • Egon.Netundefined
                              Egon.Net @zapta
                              Just an idea.
                              I don't think we are going to do so many boards to be an advantage. For the time being I will do the boards by myself, but maybe in the future I'm overwhelmed by all the people wanting the boards and I have to look something like that! ☺
                              BTW, I'm already a costumer of JLCPCB πŸ™‚
                                PCB assembly is easier if all the SMD components are on the same side. Then it's easily done using a hotplate, solder paste, and a Mylar solder stencil (available in the UK from Hobbytronics).
                                • Egon.Netundefined
                                  Egon.Net @dc42
                                  @dc42 said in Designing a PWM to Analog mini board for fans:
                                  I know, but for low quantity runs I do it with hot air and without stencil, with very good results. And for this design, size is a constrain. If I were to do a bigger run, I'd rearrange the pcb to be one side only and get it done somewhere lije JLCPCB.
                                  Thanks for the advice anyway πŸ™‚
                                  • marceloriderundefined
                                    marcelorider
                                    It’s getting really nice πŸ‘πŸ»
                                    I’m pumped to get my hands on one!
                                    • Egon.Netundefined
                                      Egon.Net
                                      Please everyone wanting some pcb's PM me with:
                                      • Number of PCB's required
                                      • Bare PCB/DIY kit/assembled
                                      • Where to send in the world
                                      I want to do a small batch first (10 or so), but since I don't know how many boards you all may need, maybe a bit bigger batch could be enough. Once I have this numbers, I'll put a price for every option.
                                      Thanks in advance to everyone!
                                      • Egon.Netundefined
                                        Egon.Net
                                        Just received one query... No one else wants to enter the first batch?
                                        • fcwiltundefined
                                          fcwilt @Egon.Net
                                          You asked for a PM but I don't know what that is.
                                          I do want some as I previously mentioned.
                                          If the price is right I would want 25.
                                          ZipZapundefined 1 Reply Last reply Reply Quote 0
                                          • ZipZapundefined
                                            ZipZap @fcwilt
                                            PM = personal message, so just chat
                                            /Julien
                                            Most important guide -> Triffid Hunter's Calibration Guide
                                            HyperCube EVO (derivate) in 250x250x300 - enclosed for ABS - Duet2WiFi - custom watercooling
