    Independently leveled Z axis Issue
    7.1k
    • martin7404undefined
      martin7404
      Wow.
      As far I see the same problem in X while U is printing.Decided to test withh 2 Y mottors attached to double ZA and ZB connectors on wifi. It seems my board have problem as far ZB mottor is not energised. So it is possible there is something in my Duet wifi board. For now I ordered new board and willtry to move x,y and u to duex and Z mottors to wifi while waiting
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
        Phaedrux Moderator @martin7404
        @martin7404 said in Independently leveled Z axis Issue:
        What does the soldering on the connector look like?
        12v or 24v?
          martin7404
          the ZA works
          This is the connector for the second Z motor to be connected in series .
          My VIN is 24 V
          To check soldering I have to unscrew the board, I will do it tommorow
          • mrenz999undefined
            mrenz999
            I am having this same issue. It used to Level pretty close to perfect. Now it does the same as yours. It lifts the right, rear corner and lowers the left side of the bed. I have checked belt tensions, remeasured my z screw positions. Have had no success figuring it out.
            3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
            • 3DPrintingWorldundefined
              3DPrintingWorld @mrenz999
              @mrenz999 Oh, I wonder if we have the same problem or if its just a coincidence. What printer do you have, or is it a custom build?
              Have you tired physically swapping two motors just to see if the results change?
              mrenz999undefined 1 Reply Last reply Reply Quote 0
                martin7404
                So today I made quite a few experiments chasing my problem with moving of the U carriage during printing with X.
                A few days ago I tried to put both Y motors on ZA and ZB conectors , just to find that one of my Z connectors is not energizing the motor.
                I ordered a new Duet wifi and while waiting today decided to try to move 3 Z motors on wifi and x,y,u on DUEX board.
                So I put 3Z motors on P1,2,3 and the motor on 2 is not energized, then moved the motors to 0,1,2 and it is working , but center motor is inverted (2), So I make it to move in the right direction with inverted motor, but when G32 it is corecting wrong direction, I do not know why
                then tried on 234 and 2 is not working, then defined this:
                M569 P2 S1                                 ; X physical drive 0 goes backwards
                M569 P3 S1; Z
                ;M569 P3 S0
                M569 P4 S0
                ;M569 P1 S0                                     ; Y right physical drive 1 goes backwards
                ;M569 P2 S1                                      ; Y left physical drive 2 goes forwards
                ;M569 P3 S1                                      ; U physical drive 3 goes forwards
                M569 P1 S1                                     ; E1 physical drive 4 goes backwards
                M569 P5 S0 ; X
                M569 P6 S1 ; Y right
                M569 P7 S0 ; Y left
                ;M569 P5 S1                                      ; Z left physical drive 5 goes backwards
                ;M569 P6 S1                                     ; Z center physical drive 6 goes backwards
                ;M569 P7 S0                                      ; Z right physical drive 7 goes forwards
                M569 P8 S1                                      ; E2 physical drive 8 goes forwards
                M569 P9 S1 ; U
                M584 X5 Y6:7  Z0:3:4 U9 E1:8                     ; set drive mapping
                and it is working like a charm . Ther is some kind of short on this board ,period. Now the movement of U with dial indicator when changin gY direction is 0.04 and X is 0.05
                • fcwiltundefined
                  fcwilt @martin7404
                  @martin7404
                  Do you ever turn the steppers or move an axis by hand when the power is off?
                  That can damage the driver chip connected to that stepper or steppers.
                    martin7404
                    I am usually very careful and do hand movements with power on .
                    The thing is now it is working
                    • fcwiltundefined
                      fcwilt @martin7404
                      You mentioned that a driver or two seemed to have failed which is why I made my post.
                      Glad to hear you got things sorted.
                        martin7404
                        It is sorted in wierd way , new board is on the way
                        PS it is not sorted U is moving during printing with X even all the X,Yand U motors are now on DUEX
                        • mrenz999undefined
                          mrenz999 @3DPrintingWorld
                          @3DPrintingWorld I have tried swapping motors. No difference. I have a BLV Mgn. So yes I built it. It's a custom with a 410x410 bed
                            @mrenz999 The BLV is very nice! 👍
                            That's the part that throws me, how is it possible that you can switch the motors but it still corrects to the same plane....
                            I think I'm just going to have to bite the bullet and try a new boards, I'm running out of ideas.
                            fcwiltundefined mrenz999undefined 2 Replies Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @martin7404
                              Well having the Z steppers on the Duex wasn't part of the problem in the first place.
                              • fcwiltundefined
                                fcwilt @3DPrintingWorld
                                @3DPrintingWorld said in Independently leveled Z axis Issue:
                                How about doing G29 with just a 4 point grid covering most of the bed and posting a screen snap of the height map?
                                It's possible to level the bed as far as the 2, 3 or 4 points controlled by the steppers and still have twist to the bed.
                                A 4 point height map will reveal such twist.
                                • mrenz999undefined
                                  @3DPrintingWorld The interesting part is we are both having the same weird twist in the same direction. Very weird to me.
                                  • fcwiltundefined
                                    fcwilt @mrenz999
                                    @mrenz999 said in Independently leveled Z axis Issue:
                                    Can you also create a 4 point height map covering most of the bed and post a screen shot of it here?
                                    • mrenz999undefined
                                      mrenz999 @fcwilt
                                      @fcwilt Sure. I will do that in the next 15 - 20 mins
                                      • mrenz999undefined
                                        mrenz999 @fcwilt
                                        @fcwilt What is the correct procedure for getting a 4 point height map ? 410x410 Bed ? lol
                                        • fcwiltundefined
                                          fcwilt @mrenz999
                                          Great.
                                          I have a MarkForged style printer with 3 Z steppers and even though the leveling appeared to work the 4 point height map still showed a "twist" along the X axis.
                                          It turned out the the Y rails (left and right) were not in the same plane which gave the appearance of the bed being "twisted" - which it wasn't.
                                          • mrenz999undefined
                                            mrenz999
                                            Measuring the bed to nozzle it appears and is without question twisted. But if you tell me how to do a 4 point height map I will do one now.
