Solved Duet3 6HC not deploying BL touch for mesh bed leveling
Can you confirm that your deploy and retract probe macros are in the /sys folder?
@fcwilt in my homeall.g there are quotes around the file names. Home C,X, and Y are all executed correctly. when it gets to home z, the probe still doesn't deploy. I just tried it after removing the M574 command earlier.
Can confirm.
@autopilot-exe said in Duet3 6HC not deploying BL touch for mesh bed leveling:
@fcwilt the duet doesn't spit out any errors. I typed "m401" and I get a green notification, but nothing moves on the machine. I type "m402", same thing happens.
Hmm...
At this point I suppose we should verify the contents of deployprobe.g and retractprobe.g.
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 11:26:03 GMT-0600 (Central Standard Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Mar 06 2021 11:26:03 GMT-0600 (Central Standard Time) M280 P0 S90 ; retract BLTouch
Does the probe run it's self-test routine when you power on the printer?
Did you verify that it is connected to the correct input and output pins?
@fcwilt the self test is working, I have it wired correctly according to the documentation. (3.3v: nothing, io7.in: white, GND: black and brown soldered together going to a single pin, io7.out: orange, 5 volt: red)
Running out of ideas.
I have a Duet 3 setup on my workbench and BLTouch units in inventory.
All boards (6HC, 3HC, 1LC) are running 3.2.2.
I will get a BLTouch out and connect and configure as you have.
@fcwilt A possibility that I just considered: the firmware generator tool that I used as a base is v3.2.3. Could the mismatch be from there? i.e, the RepRapFirmware Configuration tool version not being in line with the firmware version?
@autopilot-exe , what version is your Duet 3 6HC board?
In the tool you can select the firmware version you want it to generate a config for. The exact version of the config tool isn't important really.
Can you post a photo of the wiring?
io7 should be ok unless it's a prototype board.
@dc42 hey, its labeled as V1.0
I installed the most recent version of a BLTouch on my 6HC board (running 3.2.2) at IO7.
I powered it from 3.3 volts.
These were the configuration commands:
M950 S0 C"io7.out"
M558 P9 C"io7.in" H2 F120 T9000 R0.2 A1 S0.01 ; 1 readingM401 worked. M402 worked. G30 worked.
So when I took this photo I panicked after seeing the brown wire. To make sure it was connected I took a meter to it and confirmed continuity from the last extensions to ground on both the black and brown wire. It's ugly but functional.
@fcwilt no ^ before io.7in since you you are using 3.3v?
It would be the yellow wire that carries the servo control signal back to the BLtouch.
I didn't even think about if that was needed or not.
I did not have it as you can see.
@fcwilt Just tried both ways. Now pin up and pin down work. Mesh bed leveling does not.
Does a single G30 work?
@fcwilt confirmed: G30 works
