    Diag flashing
    1.0k
    • anthony1mundefined
      anthony1m @Phaedrux
      @Phaedrux guess im not fallowing ,
        droftarts administrators @anthony1m
        @anthony1m said in Diag flashing:
        M669 K1 ; select CoreXY mode
        Is your machine CoreXY? Because you have it set as such. This will move both motors for an X or Y move.
        Edit: please post your homing files, as @Phaedrux asked you to.
          Phaedrux Moderator @anthony1m
          In the console tab send this command M98 P"config.g" and copy and paste the response here. It might show some errors or messages.
          anthony1mundefined 1 Reply Last reply Reply Quote 0
            anthony1m
            @Phaedrux said in Diag flashing:
            M98 P"config.g"
            3/10/2021, 7:27:21 PM M98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
              anthony1m @Phaedrux
              This post is deleted!
                @anthony1m That looks good. No errors anyway.
                  WiFi firmware version 1.23
                  It looks like the wifi server didn't get updated.
                  Try uploading the full release zip file again to the system tab in DWC. Just to make sure everything is correct.
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
                    Will need to see your homing files to say why it's moving the way it's moving during homing. Post homeall.g homex.g homey.g homez.g and bed.g if you've set that up yet.
                    anthony1mundefined anthonymundefined 3 Replies Last reply Reply Quote 0
                      anthony1m @Phaedrux
                      @Phaedrux I'm close3/10/2021, 8:10:02 PM m122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
                      Board ID: 08DLM-996RU-N85S4-7JTD6-3SJ6R-KA9BR
                      Used output buffers: 3 of 24 (10 max)
                      Static ram: 23460
                      Dynamic ram: 73268 of which 40 recycled
                      Never used RAM 15312, free system stack 189 words
                      Tasks: NETWORK(blocked,186) HEAT(blocked,308) MAIN(running,457) IDLE(ready,20)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 00:01:47 ago, cause: software
                      Last software reset at 2021-03-10 20:08, reason: User, GCodes spinning, available RAM 15068, slot 2
                      Error status: 0x00
                      Aux0 errors 0,0,0
                      MCU temperature: min 31.3, current 32.0, max 32.4
                      Supply voltage: min 21.9, current 22.1, max 22.3, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: position 0, standstill, SG min/max not available
                      Driver 1: position 0, standstill, SG min/max not available
                      Driver 2: position 0, standstill, SG min/max not available
                      Driver 3: position 0, standstill, SG min/max not available
                      Driver 4: position 0, standstill, SG min/max not available
                      Driver 5: position 0
                      Driver 6: position 0
                      Driver 7: position 0
                      Driver 8: position 0
                      Driver 9: position 0
                      Driver 10: position 0
                      Driver 11: position 0
                      Date/time: 2021-03-10 20:10:01
                      Cache data hit count 129951247
                      Slowest loop: 4.40ms; fastest: 0.21ms
                      === Storage ===
                      Free file entries: 10
                      SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                      === MainDDARing ===
                      === AuxDDARing ===
                      Segments left: 0
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 15.91ms; fastest: 0.00ms
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is active
                        WiFi MAC address 48:3f:da:88:d4:72
                        WiFi Vcc 3.38, reset reason Turned on by main processor
                        WiFi flash size 4194304, free heap 22120
                        WiFi IP address 192.168.0.197
                        WiFi signal strength -36dBm, mode none, reconnections 0, sleep mode modem
                        Clock register ffffffff
                        anthony1m @Phaedrux
                        @Phaedrux I think you can check this as solved . I will work on it and if I run into any issued Ill read the information and ask for help if I need it. You guys are awesome thank you.
                        • anthonymundefined
                          anthonym @Phaedrux
                          @Phaedrux well this happened again except now the diag is on solid and windows disconnected right away. it was fine middle of a print it dropped connection and does nothing.
                          • anthonymundefined
                            anthonym @Phaedrux
                            @Phaedrux any ideas Its on a new meanwell ps also , why this board keeps having diag issues it brand new.
                              https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
                              Can you run through this guide and see how far you can get?
                              anthonymundefined 2 Replies Last reply Reply Quote 0
                              • anthonymundefined
                                anthonym @Phaedrux
                                @Phaedrux yes thank you I am working on that now.
                                • anthonymundefined
                                  anthonym
                                  "Error reading device descriptor" This is as far as I get, I can't get past that. That's the one I was working last night before I came back here. my mac or rpi 4 wont see it either usb not recognized with or with a sd card different ports and cables and restart of the machine.
                                  • anthonymundefined
                                    anthonym @Phaedrux
                                    @Phaedrux Had it dialed in was producing some great prints, Then just in the middle stopped and could not connect again.
                                      When and where did you purchase the Duet?
                                      What LEDs light up when connected to VIN or USB?
                                      anthonymundefined 1 Reply Last reply Reply Quote 0
                                      • anthonymundefined
                                        anthonym @Phaedrux
                                        • anthonymundefined
                                          anthonym
                                          diag, usb, 3.3v ,5v. 3 red one green all solid computer just said the devise malfunctioned and windows does not recognize it
                                          • anthonymundefined
                                            anthonym
                                            febuary 17 2021 printed solid
