    Diag flashing
    1.0k
      Phaedrux Moderator @anthony1m
      @anthony1m That looks good. No errors anyway.
        @anthony1m said in Diag flashing:
        WiFi firmware version 1.23
        It looks like the wifi server didn't get updated.
        Try uploading the full release zip file again to the system tab in DWC. Just to make sure everything is correct.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
          Will need to see your homing files to say why it's moving the way it's moving during homing. Post homeall.g homex.g homey.g homez.g and bed.g if you've set that up yet.
          anthony1mundefined anthonymundefined 3 Replies Last reply Reply Quote 0
          • anthony1mundefined
            anthony1m @Phaedrux
            @Phaedrux I'm close3/10/2021, 8:10:02 PM m122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
            Board ID: 08DLM-996RU-N85S4-7JTD6-3SJ6R-KA9BR
            Used output buffers: 3 of 24 (10 max)
            Static ram: 23460
            Dynamic ram: 73268 of which 40 recycled
            Never used RAM 15312, free system stack 189 words
            Tasks: NETWORK(blocked,186) HEAT(blocked,308) MAIN(running,457) IDLE(ready,20)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:01:47 ago, cause: software
            Last software reset at 2021-03-10 20:08, reason: User, GCodes spinning, available RAM 15068, slot 2
            Error status: 0x00
            Aux0 errors 0,0,0
            MCU temperature: min 31.3, current 32.0, max 32.4
            Supply voltage: min 21.9, current 22.1, max 22.3, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: position 0, standstill, SG min/max not available
            Driver 1: position 0, standstill, SG min/max not available
            Driver 2: position 0, standstill, SG min/max not available
            Driver 3: position 0, standstill, SG min/max not available
            Driver 4: position 0, standstill, SG min/max not available
            Driver 5: position 0
            Driver 6: position 0
            Driver 7: position 0
            Driver 8: position 0
            Driver 9: position 0
            Driver 10: position 0
            Driver 11: position 0
            Date/time: 2021-03-10 20:10:01
            Cache data hit count 129951247
            Slowest loop: 4.40ms; fastest: 0.21ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 3.2ms, write time 0.0ms, max retries 0
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 15.91ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              WiFi MAC address 48:3f:da:88:d4:72
              WiFi Vcc 3.38, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 22120
              WiFi IP address 192.168.0.197
              WiFi signal strength -36dBm, mode none, reconnections 0, sleep mode modem
              Clock register ffffffff
              anthony1m @Phaedrux
              @Phaedrux I think you can check this as solved . I will work on it and if I run into any issued Ill read the information and ask for help if I need it. You guys are awesome thank you.
              • anthonymundefined
                anthonym @Phaedrux
                @Phaedrux well this happened again except now the diag is on solid and windows disconnected right away. it was fine middle of a print it dropped connection and does nothing.
                • anthonymundefined
                  anthonym @Phaedrux
                  @Phaedrux any ideas Its on a new meanwell ps also , why this board keeps having diag issues it brand new.
                    https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
                    Can you run through this guide and see how far you can get?
                    anthonymundefined 2 Replies Last reply Reply Quote 0
                    • anthonymundefined
                      anthonym @Phaedrux
                      @Phaedrux yes thank you I am working on that now.
                      • anthonymundefined
                        anthonym
                        "Error reading device descriptor" This is as far as I get, I can't get past that. That's the one I was working last night before I came back here. my mac or rpi 4 wont see it either usb not recognized with or with a sd card different ports and cables and restart of the machine.
                        • anthonymundefined
                          anthonym @Phaedrux
                          @Phaedrux Had it dialed in was producing some great prints, Then just in the middle stopped and could not connect again.
                            When and where did you purchase the Duet?
                            What LEDs light up when connected to VIN or USB?
                            anthonymundefined 1 Reply Last reply Reply Quote 0
                            • anthonymundefined
                              anthonym @Phaedrux
                              This post is deleted!
                              • anthonymundefined
                                anthonym
                                diag, usb, 3.3v ,5v. 3 red one green all solid computer just said the devise malfunctioned and windows does not recognize it
                                • anthonymundefined
                                  anthonym
                                  febuary 17 2021 printed solid
                                    Please contact your vendor and initiate a warranty exchange. Please include a link to this thread as authorization.
