Mini5+ 3.3b2 homing woes
the Y moves because of line 14 of your homex file
@carcamerarig said in Mini5+ 3.3b2 homing woes:
but the Y axis still activates even though I only home X??
I can at least help with this bit, after watching your video; you've got this in your config.g:
M564 H0 ; allow unhomed movement
and this in your homex.g (which also explains the X move after it attempts to home):
G1 X125 Y100 F6000 ; centre the head and set a reasonable feed rate
@carcamerarig if you run this code as your homex, does it stall immediately?
M915 P0 S-127 H10 R1 ; Set very sensitive stall detect M574 X1 S3 ; configure endstop for stall detection G1 X200 H1 ; Should stall pretty much immediately
@jay_s_uk said in Mini5+ 3.3b2 homing woes:
it does nothing except I hear the motor engage and the home X button stays blue in DWC
@carcamerarig thats good.
Means its stalling. You can confirm by sending M84 and then rerunning that code.
I would suggest you use the example homing files I have you a link to earlier and rather that using a H value of 400, aim for something around 250. Then start tweaking the S value to suit.
Not much other help I can give you really as its very machine specific.
But at least we know its working. You just need to find that sweet spot -
@droftarts said in Mini5+ 3.3b2 homing woes:
Thanks Ian
so one needs to go, my understanding is M564 H0 allows the movement even though its not un-homed (H1 forbids un-homed)
im telling it to:
G1 H2 X10 Z5 ; Move Z and X up for a running start
then
G1 H1 X-270 F4000Im not sure how that line G1 X125 Y100 F6000 came to be but if I understood correctly why do I even need this command, is then moving to the centre of the bed a common command and if it is the Y parameter shouldn't be here?
No. G1 H1 and G1 H2 moves are p-rmitted even when the axis has not been homed.
im telling it to:
then
G1 H1 X-270 F4000
I assume you also have G91 before those commands so that the movement coordinates you supply are relative. If you are running firmware 3.3beta, try this instead:
G91 G1 H2 Z5 ; Move Z up M17 X ; energise X motor for stealthChop tuning G4 P100 ; pause to allow the driver to establish the motor parameters G1 H1 X-270 F4000 ; home X
If you are running earlier firmware, then instead of M17 X use G1 H2 X0.02.
@carcamerarig Unless your homeall.g calls each individual home[axis].g command, you're far more likely to use homeall.g than the others, once the printer is up and running correctly. So I wouldn't worry too much about what's in homex.g.
I'd remove the M564 H0 from your config.g. This starts the printer in a state where it's possible to crash it.
Note the difference between G1 H1 ... and G1 H2 ... see https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G0_G1_Move
H1 terminate the move when the endstop switch is triggered and set the axis position to the axis limit defined by M208. On delta printers, H1 also selects individual motor mode as for H2. Normally used with relative motor coordinates (see G91).
H2 Individual motor mode. X refers to the X motor, Y refers to the Y motor, and so on. Normally used with relative motor coordinates (see G91).Has this configuration set of files been generated by someone else? It doesn't look like it's come from the configuration tool https://configtool.reprapfirmware.org/Start and as you said you're new to Duet, it's pretty complicated. It's always a bit of a gamble starting with someone else's config!
@dc42 said in Mini5+ 3.3b2 homing woes:
M17
Can you add this to the gcode page as theres currently no information about what it is or what it does, other than its been implemented in the change notes
im telling it to:
then
G1 H1 X-270 F4000
and keep this part of the code?
M561 M400 ; make sure everything has stopped before we make changes M574 X1 S3 ; set endstops to use motor stall M913 X30 ; reduce motor current to 50% to prevent belts slipping
so the file would look like this complete:
; homex.g ; called to home the X axis ; M561 M400 ; make sure everything has stopped before we make changes M574 X1 S3 ; set endstops to use motor stall M913 X30 ; reduce motor current to 50% to prevent belts slipping G91 G1 H2 Z5 ; Move Z up M17 X ; energise X motor for stealthChop tuning G4 P100 ; pause to allow the driver to establish the motor parameters G1 H1 X-270 F4000 ; home X
Yes it was given to me, somebody started to help me out but then ive ended up actually with a number of people chiming in and out with very much welcomed support but I think I got lost in translation. Its ended up as a try this try that situation...
You're the second person to suggest binning the home X Y in favour of home ALL it concerned me as why include it if its not necessary? -
M17
Done. https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M17_Enable_all_stepper_motors
I also added a note about how to use it for stealthChop tuning.Edit: I probably need to add it to these pages, too...
https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
https://duet3d.dozuki.com/Wiki/Tuning_Stepper_Motor_Drivers#Section_stealthChop_tuningIan
Fair enough. We'll try to get it sorted, but once you understand what each part is doing, probably worth going back and tidying it up, and adding notes for yourself. Don't forget to back it up as well, just in case your SD card dies!
Because some people's machines need this functionality. And sometimes you do need to home just one axis.
im telling it to:
then
G1 H1 X-270 F4000
Awesome thank you, so im cooking on gas for X and Y
So using the same code can I configure Z the same? I have tested the sperpinda with a metallic object mid homeALL move and it triggers:
G28 Error: Z probe was not triggered during probing move
my current homeZ
; homez.g ; called to home the Z axis ; M561 G91 ; relative mode G1 Z4 F6000 H2 ; raise head 4mm to ensure it is above the Z probe trigger height G90 ; back to absolute mode G1 X100 Y100 H2 F6000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height
im quite worried about burying the nozzle into the bed lol
Sorry and is it safe to now to increase the motor current back to 100% or is it generally left in the reduced state?; homex.g ; called to home the X axis ; M561 M400 ; make sure everything has stopped before we make changes M574 X1 S3 ; set endstops to use motor stall M913 X40 ; reduce motor current to 50% to prevent belts slipping G91 G1 H2 Z5 ; Move Z up M17 X ; energise X motor for stealthChop tuning G4 P100 ; pause to allow the driver to establish the motor parameters G1 H1 X-270 F4000 ; home X
@carcamerarig Set it back to 100%, or it will have reduced torque, and will skip.
So setting it back to 100% causes it to crash again, 60% causes a triple bounce before stalling.
@carcamerarig Sorry, I misunderstood. You need to leave the setting at 40% while homing, then set it back to 100% after. eg:
; homex.g ; called to home the X axis ; M561 M400 ; make sure everything has stopped before we make changes M574 X1 S3 ; set endstops to use motor stall M913 X40 ; reduce motor current to 50% to prevent belts slipping G91 G1 H2 Z5 ; Move Z up M17 X ; energise X motor for stealthChop tuning G4 P100 ; pause to allow the driver to establish the motor parameters G1 H1 X-270 F4000 ; home X M913 X100
I was asking that very question to myself, did you mean 913 X100. Me being a numpty
just set my probe height and homed Z all good but can I tidy up the code and include M17 or does the probe make it different?
@carcamerarig You can tune stealthChop on Z if you want (with M17 Z and a pause), but realistically you're not using stall detection/sensor less homing on Z, so it's not necessary.
I've gone back to the datasheet (https://www.trinamic.com/fileadmin/assets/Products/ICs_Documents/TMC2209_Datasheet_V103.pdf page 35 '6.1 Automatic Tuning), and I think there's one more change to be made.
In the datasheet it says that the motor has to be idle for greater than 130ms. So you need to change the G4 P100 after M17 to
G4 P150
.stealthChop will continue to be tuned on the fly, on all axes, so long as it pauses for longer than 130ms after being enabled, and then moves the motor at around 60-300RPM; this will be quite common during a print. It's just that the first movement needs to be correct for sensorless homing to work.
