    Duet 3 Mini 5+ unable to connect via browser
    Firmware installation
    10
    27
    1.7k
    • pkosundefined
      pkos
      Understood. I'll talk to E3D to get a replacement.
      Thank you 🙂
      Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
      oc_geekundefined 1 Reply Last reply Reply Quote 0
      • oc_geekundefined
        oc_geek @pkos
        @dc42 Hi unfortunately my Mini 5+ appears to have the same problem as Pkos... 😞 earlier today it got stuck and was no more reachable... after many tries of power off finally it came back... but by time to time it does not list the files (system / marco) and does not respond anymore to http... sad ...
          Phaedrux Moderator @oc_geek
          @oc_geek Would you be able to start a new thread so we can do some basic troubleshooting and if required use that thread as your warranty claim? Thanks.
          • pkosundefined
            pkos
            Not to necro the thread too much, but is there anything a person with a hot air soldering station can do?
            It seems like the stock for those minis won't be available again for another month or so.
            dc42undefined 2 Replies Last reply Reply Quote 0
              dc42 administrators @pkos
              @pkos said in Duet 3 Mini 5+ unable to connect via browser:
              Our assemblers are currently building and testing a large batch of Duet 3 Minis. Deliveries to our resellers should be in full flow next week. They have been using our second-generation CAN-based Automatic Test equipment since the start of this week to speed up testing. This is the prototype:
              The lid on the top right holds the Duet 3 Mini under test down to make contact with the pogo pins. The power resistors at the top provide loads for the heater/fan outputs, and the bank of inductors on the left simulate stepper motors without producing noise. The Duet 3 Mini at front centre runs the tests. At the back (not visible) are CAN-connected boards that measure motor currents and I/O voltages. Ignore the MB6HC board at the front, I was using it to adapt the ATE firmware to test MB6HC boards too.
                Yes, all it needs is a no-clean flux pen and hot air equipment. If you were in the UK, I would have volunteered to repair your board already. I have repaired about ten pre-production boards in this way.
                • pkosundefined
                  pkos
                  Well, if it's next week, I'll wait patiently 😉 Don't want to mess the board up even more before I have the replacement. I mean it does turn on once every 10 times or so and even allows me to print something as long as I have cooling fans cooling the board.
                  EDIT: Sweet rig by the way.
                  • lodgerundefined
                    lodger
                    Would this problem still be a issue if your running the board off a SBC. Was just thinking folks waiting for replacement stock may be able to run off a Pi ??
                    Just a idea !
                    pkosundefined 1 Reply Last reply Reply Quote 0
                    • pkosundefined
                      pkos @lodger
                      @lodger That would work 🙂
                      I never think about adding an SBC to the Duet, since the main reason I use a duet is the standalone mode. I like the simplicity of it so much, it would feel weird to tarnish the Duet with a pi 😉
                      But yes, if I won't hear from E3D anytime soon, I will either ask what should be resoldered exactly (I have all I need I believe) or add an SBC.
                      For now, I keep playing with the board when it actually boots up to test 3.3b1 - and I am seeing some issues there (like the 12864 screen doesn't work with 3.2.2 config anymore with an error saying X2 is too low a value).
                      • oc_geekundefined
                        oc_geek @Phaedrux
                        @Phaedrux It happened again -> opened a thread on it
                        https://forum.duet3d.com/topic/22116/duet-mini-5-non-responsive-and-files-missing
                        • incurioundefined incurio referenced this topic
