Error: attempting to extrude with no tool selected
Any decent gauge wire should do. I like to do a braid or twist which seems to help with crosstalk without shielding. I hear people mention silicone wire as nice to work with. I've only ever used some cheap spools of 22 gauge wire on amazon for low current DC applications. Nothing special. And for AC wiring some larger gauge stuff from the local auto parts store.
@Phaedrux Well I lied, still getting communication issues. I replaced the SD card with a brand new one, and I moved the stepper motor wire that was near the paneldue wire so there is 4+ inches of separation. The only other wire near it is a mechanical endstop switch. Any other ideas? The paneldue does not have a SD card in it.
How long is the wire run?
@Phaedrux The 4 pin wire is 1000mm long. I bought it from filastruder, who also offers a 3000mm cable, so I figured the 1000mm cable would be fine.
https://www.filastruder.com/products/paneldue-7i?_pos=1&_sid=6b2701afe&_ss=r&variant=2154915528719
@Surgikill Yeah that should be within spec.
I'll try and find out what was ever determined the last time this was reported. It's been found a few times but I don't think there was ever a definitive cause for why it becomes apparent in RRF3.
Can you measure the resistance of the wires in the cable?
@Phaedrux Thanks. I'm still going to rewire this just to tidy it up. Maybe it will help.
@Surgikill "The length of the 4-way cable is not critical, however the resistance per conductor should not exceed 0.1 ohm. "
@Phaedrux I can measure it and see. Definitely still having issues with my tool being de-selected.
@Phaedrux Well, the ground wire read 0.2, but the resolution on my multimeter is only 0.1, so not sure how accurate it is. Length is less than the 1000mm, it's only about 750mm.
Any way I can mitigate this until we find the issue? I can't get a print completed.
@Surgikill said in Error: attempting to extrude with no tool selected:
This may be inconvenient but could try disable or disconnect the paneldue. What version of PanelDue is it? What PCB version of Duet?
Duet 2 wifi PCB V1.04.
Paneldue 7i.I did a print, couldn't see any garbage errors on the paneldue, but I didn't get any tool unselected errors. I cut my wire in half and re-terminated it, so hopefully that mitigates any issues. The wire is running decently close to a stepper motor and a drivers (around 2-3 inches) and there's not much I can do about that. I have some shielded wire coming, so that might help.
A braid for both wires might help. I've got my PanelDue wire running along side a stepper for ~1 meter since it's right next to the CorexY B motor and they run down the frame and back to the Duet box. I think I have a braid in the panelDue wire and pairs of the stepper motor are twisted together. So for interference I think I'm in worst case, but the braid/twist seems to help.
@Phaedrux I believe the stepper wire is braided, not sure. It might just be the paneldue wire. The stuff I got from filastruder is like 30ga. Re-wiring with shielded 22 gauge should hopefully fix it.
@Surgikill The plan going forward is to change from using a checksum to CRC, but that has not been implemented yet.
@Phaedrux Hopefully it happens soon. Even with the shortened 4 pin cable I'm still getting errors. No issues when the paneldue is disconnected. Kind of sucks that it's pretty much unusable.
Seeing what else can be done.
Can you share photos of the cable run? General printer photos? Maybe something will jump out.
The paneldue wire is 2-3 inches from that stepper wire. The only thing I can think of is I might be getting back EMF through the IR sensor wire which is messing with it. Sometimes my IR sensor will throw weird readings during travel moves, it will jump around. I'm going to re-wire this mess when I get the new cable in, but all wires are twisted (cat5 cable) so that should cancel anything out.
Also please excuse the berd air wiring. Still trying to figure out exactly how I want to wire it and mount it.
was not having this issue before the upgrade to RRF V3, which I performed a few days ago.
What firmware version were you using before upgrading to RRF3? And when you updated did you go straight from 2.x to 3.0 and 3.2.2?
Would you be willing to flash back to 2.05.1 to verify that the problem goes away?
Can you also test rolling back the Paneldue firmware to 1.24?
Also, would you be able to try doing a 4 strand braid on that PanelDue cable?
I'd be surprised if being that close to the stepper motor wire for such a short run would cause a problem. As I said I've got a PanelDue running along side a stepper motor for nearly 2 meters.
@Phaedrux I went from 2.03 to 3.0 to 3.2.2. I can try to flash back, I still have my old config but it might be a pain in the ass re-configuring some things in my slicer.
I can try the 4 strand braid, but I have the shielded wire coming here in a few days.
The only changes that were made from 2.03 to 3.2.2 were a berd air pump and the firmware upgrade. Maybe the berd air pump is causing some sort of issue? The wires are nowhere near the paneldue. I printed a good amount on 2.03, and never had any sort of issue with the tool being de-selected. I may have had it display some type of garbage command once or twice, but nothing as bad as this.
@Phaedrux Well the shielded cable I got is pretty shit. Seems like after I crimp the connectors they just break off. Not sure what to do.
