    6 Red flashes in the duet monitor sensor v1.7a. Duet 2 Wifi
    Filament Monitor
    593
    • DomMilanundefined
      DomMilan
      I bought this rotary sensor a while back for my Duet 2 and could not get it to work for the life of me. I keep getting 6 red flashes even after running the trouble shooting steps. I have it on a Tevo Little Monster (Titan Extruder). I do not get any green LEDs when initializing. Printing with it returns the pause code.
      M591 D0 retuns:
      Duet3D magnetic filament monitor on input 3, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 3.0mm, no data received
      Config is as follows:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 30 2020 15:44:36 GMT-0400 (Eastern Daylight Time)
      M550 P"The Fortune Teller" ; set printer name
      M665 R155 L397.19 B155 H520 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M551 P"Turnip123!" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      M92 X80.00 Y80.00 Z80.00 E420 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X40000.00 Y40000.00 Z40000.00 E3000.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1500.00 ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1500 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M915 X Y Z S20 F1 R3
      M208 Z0 S1 ; set minimum Z
      M574 X2 Y2 Z2 S1 ; set active high endstops
      M591 D0 P3 C3 S1 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      M591 D0 ; display filament sensor parameters for extruder drive 0
      M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 R0.2 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y20 Z1.37 ; set Z probe trigger value, offset and trigger height
      M557 R150 S45 ; define mesh grid
      M106 P0 S0 I0 F500 H-1 X0.75 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M501
      Override is as follows:
      ; config-override.g file generated in response to M500 at 2020-09-15 14:08
      ; Delta parameters
      M665 L400.659:400.659:400.659 R157.354 H523.578 B155.0 X0.417 Y0.551 Z0.000
      M666 X0.650 Y-1.210 Z0.560 A-0.25 B-0.21
      ; Heater model parameters
      M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B0
      M307 H1 A286.1 C196.6 D4.9 S0.50 V23.8 B0
      M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      I have gotten the Bigtree Smart sensor to run on Marlin boards without issue, so I am not sure what is going on here. Open to suggestions.
      Thanks,
      Dom
      • alankilianundefined
        alankilian
        I got one working with my Duet2 running RRF 3.2 firmware.
        Here's my config:
        M591 D0 P4 C"e0_stop" S1 R10:200 L27 E20
        I've got P4 since I have a switch also. Your P3 is fine.
        My C"e0_stop" is the same as your C3
        Here's a photos of the wires on my sensor and on my Duet if that helps you.
        • DomMilanundefined
          DomMilan
          I do not have the two pin connector connected to anything. Could that be the issue? I am trying to avoid switching firmwares as it quite a challenge for me the first time.
            alankilian @DomMilan
            I looked it up:
            From THIS link.
            6 flashes: Magnet not detected. Typically this means that the magnet is too far away from the sensor chip.
            Did you buy this with a plastic housing or did you print your own housing?
            • DomMilanundefined
              DomMilan
              This came with the plastic housing. I did see this documentation but they do not go into detail on how to solve this.
                @DomMilan You need to get the magnet closer to the sensor on the PCB.
                Can you send a photo of the magnet attached to the shaft?
                That will help us see that the magnet is placed properly.
                Then you should tighten the two long bolts and see if you can get the six flashes to go away.
                DomMilanundefined 1 Reply Last reply Reply Quote 1
                • DomMilanundefined
                  DomMilan @alankilian
                  Long bolts are as tight as they will go.
                    alankilian
                    Take the PCB off and put the magnet back on the end of the brass part.
                    It's a ring and it fell off when you removed the back-half of the sensor.
                    DomMilanundefined 1 Reply Last reply Reply Quote 0
                    • DomMilanundefined
                      @alankilian That did not resolve the issue
                        alankilian
                        Sorry, can you send a photo of the magnet attached to the brass part with it all assembled into the housing, but with the PCB removed?
                        Here's a photo of the brass part and the ring magnet taken apart.
                        There are some "fingers" on the brass part that hold the ring magnet firmly.
                        Here's an image of them assembled properly:
                        • DomMilanundefined
                          @alankilian Thank you that picture. It seems at one point I reversed the direction of the idler. I am getting an short green flash with a long red flash now. When I move filament thru it it becomes green. I will try to test with it shortly and see if that does it.
                          alankilianundefined 1 Reply Last reply Reply Quote 1
                            @DomMilan Oh MAN, you're getting the correct type of flashes now!
                            I hope it works for you.
                            • DomMilanundefined
                              @alankilian It works when I am printing but whenever I get retractions it goes into a pause state.
                                alankilian
                                @DomMilan Post the result of M591 D0 after it pauses due to retract.
                                What kind of printer is this used on and where is it installed?
                                Mine is on a delta right after the extruder and it's working well.
                                We'll be able to tell better once you post the numbers to see if it's just a little too sensitive or if it's something else.
                                • DomMilanundefined
                                  @alankilian
                                  M591 D0 returns:
                                  Duet3D magnetic filament monitor on input 3, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 3.0mm, version 3, mag 132 agc 108, measured sensitivity 26.31mm/rev, min 53% max 106% over 100.2mm
                                  I am using this on a Tevo Little Monster with a real e3D Titan Extruder.
                                    alankilian
                                    Where do you have your filament monitor installed?
                                    I would recommend installing it as close to the extruder as possible.
                                    Down here in red:
                                    It looks like you got underextrusion.
                                    You've got the lower limit set to 70% and it hit 53% and triggered.
                                    You could first try setting the limits to something like 20% to 150% and see if that's wide enough to stop the false triggering.
                                    • DomMilanundefined
                                      @alankilian I have it right before the extruder, I am trying to avoid placing it in line between the Hotend and Extruder as I have had issues with that with the BTT smart F sensor on my other machines. Changing the sensitivity seemed to do it. I was able to print with it. Sensitivity can be adjusted later should it be too weak. My esteps look good so I have my doubts about that being a root cause. I am happy with the progress made on this now. Took me a year to figure out what we did in these few days. Ill play with the settings but the root issue has been solved.
                                      Thanks so much!
