DWC 3.1.1
I think that would be handled with delta calibration. I'm not very savvy with deltas, but those two links to configure and calibrate should get you going.
SI HAI RAGIONE POSSO CAMBIARLO SOLO CON Configuration Tool MA LO CALCOLCO PRIMA MEDIANTE I SOLITI SISEMI , MA SOLO Configuration Tool RIESCE A SALVARE IL VALORE ,IL CHE RENDE TUTTO MOLTO PIU' LABORIOSO, GRAZIE
Just edit the config.g file in the web interface. It's in the system tab. You do not need to go back to the configuration tool every time.
I DO NOT UNDERSTAND n the web interface.
Plugins tab (built-in) HEIGHT MAP = START OK CAMBIA H TOTAL DOPO RIAVVIO MA USANDO M665 H565.85 NON CONFIG.G TUTTO BENE . UNA COSA CHE NON CAPISCO E' PERCHE' L ALTEZZA IMPOSTATA NON E' UGUALE ALLA HOM HO PENSATO AL DISTIAMENTO IMPOSTATO SUI FINE CORSA ALTI . TI RINGRAZIO ANCORA HO RISOLTO UN SACCO DI PROBLEMI GRAZIE A TE
mi da questo errore , ma il comando viene ,fatto dalla macchina
g 30 g30
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale) -
mi da questo errore Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
Ma la macchina esegue i comandi. dopo il comando g29 e salvato il risultato nel file mi da la seguente foto
non appare il grafico
@luca-Massimiliano said in DWC 3.1.1:
gives me this error Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT + 0100 (Central European Standard Time)
It sounds like you are missing a
to commend out that line? -
H1 NON VA SI BLOCCA NON SI SINTONIZZA
COMADO M307 H 1 ECCO LETTURA
M307 H 1
Heater 1 model: heating rate 2.429, cooling time constant 140.0, dead time 5.50, max PWM 1.00, calibration voltage 0.0, mode PID
Computed PID parameters: setpoint change: P13.4, I0.482, D51.4, load change: P13.4, I0.949, D51.4ESEGUO AUTOMATICO
M303 H1 S
Auto tuning heater 1 using target temperature 0.0°C and PWM 1.00 - do not leave printer unattendedNON SI FERMA IL PROCEDIMENTO HEATER 1 OSCILLA TRA 23,4 23,8
POI M0
I'm not sure what you're saying. The translation was not very good this time.
THE PROCEDURE DOES NOT STOP HEATER 1 SWINGS BETWEEN 23.4 23.8
PID tuning can take a long time.
ESATTO , 20 30 MINUTI PER UN RISCALDATORE , H1 LAVORA PER 60 MINUTI O PIU' . IN TUTTE LE CALIBRAZIONE CHE HO FATTO, LA TEMPERATURA SALIVA AL MASSIMO .
ORA LA TEMPERATURA VA MASSIMO A 24 GRADI MI STUPISCO . ORA STA LAVORANDO -
M303 H1 S
You need to set a temperature after the S
M303 H1 S200
AVEVO CAPITO HE S NON IMPOSTATO ANDAVA ALLA MASSIMA TEMPERATURA .GRAZIE PROVO SUBITO
This post is deleted! -
@Phaedrux PERFETTO
GRAZIE -
NON HO CAPITO . HO FATTO G 29 LA MACCHINA HA LAVORATO MA NIENTE GRAFIGO RAPPRESENTATO COME SI VEDE. UNA VOLTA HA FATTO GRAFICO CON UN G 29 POI NON PIU'
It sounds like you are missing a ; to commend out that line?
NON COMPRENDO SCUSA
