    DWC 3.1.1
    Duet Web Control
    6.1k
      Phaedrux Moderator @luca Massimiliano
      @luca-Massimiliano said in DWC 3.1.1:
      M563 P1 S"1" D0 H1 F0 ; define tool 1
      You only have one tool defined, so only one tool will show in the web interface.
      You have the heater configured, but it needs to be associated with a tool to be controlled.
      • luca Massimilianoundefined
        luca Massimiliano
        GRAZIE VERAMENTE PRECISO E PREPARATISSIMO FUNZIONA , (NON HO PROVATO L ESTRUSIONE PER ORA)
        HO UN PROBLEMA INVECIE PanelDue Firmware. CON QUALE Firmware DIVENTA COMPATIBILE?
          What version of firmware is on the PanelDue? Check in the Setup page on the Panel.
          It should be at least 1.24
          https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
          What baud rate is it set to? It should be 57600 to match what you have set in config.g
            luca Massimiliano
              Your baud rate doesn't match. In PanelDue it shows 115200 baud. Press that button until it shows 57600.
                luca Massimiliano
                GRANDIOSO I BAUD GRAZIE MILLE . SONO A BUON PUNTO DIREI COME POSSO RICAMBIARE IL TUO ENORME AIUTO
                  luca Massimiliano
                  NON HO FATTO CON A NUOVA CONFIGURAZIONE SONDAGGIO AUTOMATICO . IO HO UNA DELTA KOSSEL CIRCOLARE E RIPORTA I VALORI APPROSIMATICI E NORMALE CHE USI UNA BASE QUADRATA? SCUSA NON VORREI AVER DIMETICATO DELLE CONFIGURAZIONI.37d73ebb-0588-46af-8e97-7f30d097d871-image.png
                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
                    https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                      luca Massimiliano
                      CIAO
                      non ho mai capito una cosa :
                      perche' se MODIFICO IL VALORE NEL CONFIG .G DI H506.5 NON CAMBIA MAI E DEVO CAMBIARLO SU RepRapFirmware Configuration Tool ?
                      M665 R165.29 L334 B130 H506.5 ; Set delta radius, diagonal rod length, printable radius and homed height
                        I think that would be handled with delta calibration. I'm not very savvy with deltas, but those two links to configure and calibrate should get you going.
                          luca Massimiliano
                          SI HAI RAGIONE POSSO CAMBIARLO SOLO CON Configuration Tool MA LO CALCOLCO PRIMA MEDIANTE I SOLITI SISEMI , MA SOLO Configuration Tool RIESCE A SALVARE IL VALORE ,IL CHE RENDE TUTTO MOLTO PIU' LABORIOSO, GRAZIE
                            Just edit the config.g file in the web interface. It's in the system tab. You do not need to go back to the configuration tool every time.
                              luca Massimiliano
                              I DO NOT UNDERSTAND n the web interface.
                                https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual
                                Specifically
                                https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_System
                                luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
                                  luca Massimiliano
                                  Plugins tab (built-in) HEIGHT MAP = START OK CAMBIA H TOTAL DOPO RIAVVIO MA USANDO M665 H565.85 NON CONFIG.G TUTTO BENE . UNA COSA CHE NON CAPISCO E' PERCHE' L ALTEZZA IMPOSTATA NON E' UGUALE ALLA HOM HO PENSATO AL DISTIAMENTO IMPOSTATO SUI FINE CORSA ALTI . TI RINGRAZIO ANCORA HO RISOLTO UN SACCO DI PROBLEMI GRAZIE A TE
                                    luca Massimiliano
                                    mi da questo errore , ma il comando viene ,fatto dalla macchina ![0_1615802572116_8ce0cdb5-8886-432e-b3d2-c662d0899a24-image.png](Uploading 100%)
                                      luca Massimiliano
                                      g 30 g30
                                      Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
                                        luca Massimiliano @Phaedrux
                                        mi da questo errore Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
                                        Ma la macchina esegue i comandi. dopo il comando g29 e salvato il risultato nel file mi da la seguente foto
                                        ![0_1615807512734_305105ce-bdd8-46fe-8f7d-0c5d74b55292-image.png](Uploading 100%)
                                          luca Massimiliano
                                            luca Massimiliano
                                            non appare il grafico
