    PID Tuning help needed
    2.4k
      jay_s_uk @Reefwarrior
      @Reefwarrior yea, it shouldn't go as high as 320 on a 240 degree tune.
      The M308 line in config sets the thermistor. best finding out what you had in marlin so you can replicate it here
        deckingman @Reefwarrior
        @Reefwarrior It sounds to me like you have a very over powered heater. Might it be 12V heater running in a 24V system? Are you able to measure the resistance of the heater cartridge? If so, post the value here and one of us will work out the wattage.
        Reefwarriorundefined 1 Reply Last reply Reply Quote 1
        • Reefwarriorundefined
          Reefwarrior @deckingman
          @deckingman Hi, I get 4.1ohm. I don't know if this can be correct, as it 'feels' too little?
          jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
            @Reefwarrior typical resistances
            P\V --------------------- 12V---- 24V
            40w (Red Leads) 3.6Ω 14.4Ω
            25w (Blue Leads) 5.76Ω 23.04Ω
              @Reefwarrior said in PID Tuning help needed:
              So, if my maths serves me correctly, V=IR, so I=V/R = 24/4.1 = 5.8536Amps. Wattage = VI = 24 x 5.853 = 140.48 Watts !!
              If the voltage was 12, then the current becomes 2.9 Amps so the wattage would then be 12 x 2.9 = 35 Watts.
              So it looks you have a nominal 40 watt \ 12V cartridge so when you put 24V through it, you get roughly 4 x the heating power.
              Note. A 40 Watt/24V cartridge would have a resistance of about 14.5 Ohms.
              Edit. A 40W/ 24v heater cartridge would draw about 1.65 Amps which is perfectly safe to use with the onboard MOSFETs - no need to use an external one.
                Reefwarrior
                Thank you all for the feedback. Yes seems I am running a 12V then at 24V. I take it I can't just put in a power factor of P0.25 to fix this? Or will it be better to rather just swap it out for a 24V cartridge?
                deckingmanundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                  Running 25% PWM is bad idea IMO. The problem is that, if a MOSFET fails, then you could end up with the full ("permanent" as in non PWM switched) 24V which could be a fire risk.
                    @Reefwarrior swap it. it will be unsafe until you do so
                      Reefwarrior
                      Cool thank you. I will swap it out this afternoon then, and see if it is better.
                      With regards to the temperature measurement. Is it normal for it to jump up and down a few degrees? The graphs show spikes, instead of a normal flat line....
                      deckingmanundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                        I think you'll find it's a lot more stable with a cartridge that is a better match to the hot end. The PID control can only do so much and when you have a heater that is over powered by a factor of 4 then you are likely to get overshoots when it turns on.
                          droftarts administrators @Reefwarrior
                          No, check your wiring. Either it's picking up interference (usually from stepper motor or endstop wiring), or there's a poor joint. It will also cause the PID tuning to fail, as it can't get a consistent reading, and it's probably why it's taking so long to tune.
                          Are you using a thermistor PT1000, PT100 or thermocouple? There are ways to make the last two more reliable, by using four wires rather than just two.
                          Reefwarriorundefined 1 Reply Last reply Reply Quote 0
                            Reefwarrior @droftarts
                            @droftarts Hi Ian,
                            It looks like one of those little glass bead thingies that measures the temperature....
                              @Reefwarrior Sounds like a thermistor. Check your wiring, and make sure the leads of the thermistor aren't grounding on the heater block, and that the thermistor bead is making good contact with the heater block (ie not flapping about in a big hole!). Cartridge thermistors, or PT1000, are generally easier to use and get good contact with. What kind of hot end is this?
                              Reefwarriorundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                                @droftarts E3d v6 clone. I will take a look at the hotend too....
                                  deckingman @droftarts
                                  @droftarts Did you check the earlier posts? It transpires the OP has a 12V cartridge and a 24V system. So around 140 Watt instead of 35. Methinks, that's more likely to cause the oscillations.
                                    droftarts administrators @deckingman
                                    @deckingman Yes, read the whole thread. @Reefwarrior said "The graphs show spikes". While I'm sure the heater can create a spike up in temperature, it probably can't create a drop as quickly! But a dodgy thermistor can, though I guess it could be a power drop across the board when the heater switches on, if the PSU isn't up to it.
                                    @Reefwarrior A screenshot of the temperature graph misbehaving would go some way to disambiguate the cause of the "spikes". Try wiggling the thermistor wires, see if that causes the spikes, too.
                                      @droftarts I guess it depends on the definition of "spike". I read this (quote)
                                      Other strange thing is, there are quite a lot of oscillations with regards to the temperature being sensed. (Up to 3 to 4 degrees up and down)
                                      As you say, we need a picture of the graph......
                                        A picture of the graph would be nice, but don't don't run that 12v heater at 24v just to make a graph for us. You're liable to melt something. Just replace the heater with a 24v version before you do anything else.
                                          Reefwarrior
                                          Hi all,
                                          OK so I swapped the cartridge for a 24V one. Did the PID tuning... results:
                                          Warning: heater behaviour was not consistent during tuning
                                          Auto tuning heater 1 completed after 4 idle and 25 tuning cycles in 1494 seconds. This heater needs the following M307 command:
                                          M307 H1 R3.064 C165.3 D10.06 S1.00 V24.3
                                          Send M500 to save this command in config-override.g
                                          Bothers me a bit with the 'warning'. Also it seems the temperature sensing thing is a PT1000 I think? It's a little silver cylinder that connects directly to the board, no daughterboard. Chinese brand.
                                          https://imgur.com/p5oTiy3
                                          there is the picture that I am referring to. Look at both the blue and the red - the curves are not smooth - it's like jagged. Even the 'MCU Temperature' seems to oscillate by about 1 degree up and down (including the decimals....)
                                          Also got this after PID tuning my bed:
                                          Auto tuning heater 0 completed after 4 idle and 25 tuning cycles in 1536 seconds. This heater needs the following M307 command:
                                          M307 H0 R1.369 C277.3 D5.29 S1.00 V24.2
                                            Phaedrux Moderator @Reefwarrior
                                            Why do you think Pt1000? It could be a plain thermistor.
                                            Photos?
                                            Yeah that graph looks a bit fuzzy which would explain the warning.
                                            The overall curve of the graph looks ok though, so I think the values it provides should be usable.
                                            Perhaps a good time to replace the temp sensor with something better quality.
                                            Reefwarriorundefined 2 Replies Last reply Reply Quote 0
