    Duet 3 Mini 5+ Future Expansion Options
    Future Direction
    14
    34
    2.1k
      The Mini2+ expansion board is now available from some of our resellers.
      Connecting two Mini5+ boards together is implemented to some extent in firmware 3.3beta. Only some functions are implemented: remote drivers (but not some of the driver configuration commands), GpIn pins, GpOut pins, and some types of temperature sensor (thermistors, PT100, and probably thermocouples). Heaters, fans and filament monitors are not yet supported.
      • Niko.Hoghundefined
        Niko.Hogh
        why does the Mini 5 + use micro USB and not USB type C? Micro USB is quite an old connector, so I don't really understand?
          dc42 administrators @Niko.Hogh
          The Mini 5+ is price-sensitive, and last time we looked, USB C connectors and cables were still expensive compared to Micro USB B. We have it on our list to review when the prices fall sufficiently.
          • zaptaundefined
            zapta
            I started recently using these $4 ARM F4 modules which come with a USB C connector and it's definitely an improvement.
            https://github.com/WeActTC/MiniSTM32F4x1
            tenajaundefined 1 Reply Last reply Reply Quote 0
              Niko.Hogh
              does the Laser Filament Monitor V2.0 and the Rotating Magnet Filament Monitor work with the Mini 5+? and which one is best?
                Phaedrux Moderator @Niko.Hogh
                @Niko-Hogh Yes they both work. They each have pros and cons. Would need to do some research and see which may work best for you. The laser sensor can be sensitive to filament type, but there are mod options that use a rotating bearing as the sensed surface rather than the filament directly.
                • razrudyundefined
                  razrudy
                  Anyone know where we can get the expansion board in Uk please? None of the big reseller have this on stock , not even listed.
                    Phaedrux Moderator @razrudy
                    @razrudy From what I understand there is more stock on the way
                    • tenajaundefined
                      tenaja @zapta
                      @zapta said in Duet 3 Mini 5+ Future Expansion Options:
                      $4 is very expensive compared to a micro-USB socket... the prices of those are measured in nickels.
                      • DIY-O-Sphereundefined
                        DIY-O-Sphere @dc42
                        @dc42 said in Duet 3 Mini 5+ Future Expansion Options:
                        we hope to provide the option of using a second Mini 5+ as an expansion board
                        Could it also be an option to use the Mini as an extension for a 6HC?
                        The reason I ask is that I assumed that pairing 2 minis would be the perfect solution for my new printer.
                        But currently I have the impression that the trent is going to larger motors for X and Y axis with a tool changer.
                        If I understand correctly, there will be no reasonable option for connecting external drivers on the Mini.
                        (UTC+1)
                        Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @DIY-O-Sphere
                          @DIY-O-Sphere said in Duet 3 Mini 5+ Future Expansion Options:
                          I think that's been hinted at but I don't think anything has been tested for certain yet.
                            dc42 administrators @DIY-O-Sphere
                            Yes there could be. It should work partially already in the latest source code, however we don't expect to make it fully working until release 3.4 at the earliest.
                            It would be possible to make a daughter board to connect two external drivers instead of the Mini2+ board, step and direction only (no enable signal).
                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                              DIY-O-Sphere @dc42
                              Thank you for the quick reply. I would prefer a spi solution....
                              I will start with 2 minis first. Until I have the machine mechanically ready there will be a solution with the 6HC. And I'll probably only need the large drivers if I want to print extremely fast. That is beyond my competence so far....
                              (UTC+1)
                              • Diamondbackundefined
                                Diamondback
                                @dc42 Any updated timeline for a more complete "Mini 5 as an expansion board" featureset? I'm planning to use a combination of 6HC and Mini in the future to replace my Duet Wifi + Duex 5 combination on a toolchanger. For me, that would be the most space efficient way of doing things since my toolheads are a little too small to nicely fit toolboards and I don't really mind the large-ish cabling loom.
                                  dc42 administrators @Diamondback
                                  @diamondback said in Duet 3 Mini 5+ Future Expansion Options:
                                  Possibly in RRF 3.4, but definitely in RRF 3.5.
                                  I presume you need support for heaters and fans on the Mini5+. Do you also need to support filament monitors?
                                  Diamondbackundefined 1 Reply Last reply Reply Quote 1
                                    Diamondback @dc42
                                    Lovely 🙂
                                    Current plan is to connect XY and all 4 extruders to the 6HC, coupler and 3xZ goes to the Mini. The heaters/thermistors need to be shared across them of course. (pending actual research about whether or not it's smart to split up extruders and heaters across different boards and such)
                                    I'm currently not running filament sensors, however, still undecided how useful a magnetic sensor would be long ways away from the DD extruder (again, not enough space on my toolhead to place it there directly...)
                                    But yea, I will have sensors of some sort in the future again, even if only microswitches.
                                      There is currently a limitation on the connection of Z motors when a Z probe is used. So it would be better to connect the Z motors to the 6HC and the extruders to the 3 Mini.
                                        Diamondback
                                        Is that something that you plan to fix along with the heaters and other missing things? I'm not overly concerned with how long it takes, my upgrade plans are for like in half a year to a full year or so.
                                        But even if not, not really a big problem. 👍
                                          @diamondback yes it's scheduled to be implemented, but probably not until RRF 3.5 now.
                                          peter247undefined Diamondbackundefined 2 Replies Last reply Reply Quote 1
                                          • peter247undefined
                                            peter247 @dc42
                                            @dc42 at this time you just can't get the Mini 2+ in the UK , will you be ever selling them direct .
                                            At this time you can get From Filafarm Germany https://www.filafarm.de/collections/elektronik/products/duet-3-mini-2-dual-stepper-expansion-board
                                            But the postage is as most as the board !!!
                                            Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
