    Strange bugs 3.3beta2
    Beta Firmware
    8
    48
    2.4k
    • Depundefined
      Dep
      @dc42 said in Strange bugs 3.3beta2:
      PanelDue
      PanelDue cable does not run near motors. But I will do it differently.
      could you answer my question about the movement along the axes with mesh compensation enabled? Should the bed move?
      I just can't figure it out.
      • Depundefined
        Dep @dc42
        M575
        M575 P1 B57600 S1       						; Comms parameters for PanelDue
          dc42 administrators @Dep
          @Dep said in Strange bugs 3.3beta2:
          Yes, but it's hard to see whether the Z motors are moving a little or not on most printers. For example, with 400 Z steps/mm @ x16 microstepping on 1.8deg motors, the leadscrews will turn only 1/10 turn for 0.4mm movement.
          Depundefined 1 Reply Last reply Reply Quote 0
          • Depundefined
            Dep @dc42
            @dc42 In fact of the matter. I attached a long stick to the pulley. There is no movement and no sound.
            And during printing, the compensation does not work.
              Run M122 and check that it reports "Bed compensation in use: mesh" while it is printing.
              • Depundefined
                Dep @dc42
                I usually do that.
                The size of the table at the printer is 1x1 meter. And the unevenness is about 0.5mm. I usually see the Z motors move.
                Should I try to install an older firmware? Or does everything work for you?
                • Depundefined
                  Dep
                  Another dangerous bug!
                  M558 K0 H5 A5 F120
                  Works as it should
                  M558 K0 H5 A5 F120: 120
                  Also works as it should
                  M558 K0 H5 A5 F120: 60
                  Broke today probe.
                  The bed goes up and breaks the probe. And continue to rise.
                  I checked it several times.
                  Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @Dep
                    Broke today probe.
                    Why would you use F120: 60 at all?
                    To better understand why the mesh isn't moving the Z axis please provide your config.g and homing files so we can see what other commands are taking affect.
                    • Depundefined
                      Dep @Phaedrux
                      @Phaedrux thanks!
                      Below is my config:
                      G90                                             ; send absolute coordinates...
                      M83                                             ; ...but relative extruder moves
                      M550 P"Pr-1100x1100"                               ; set printer name
                      M564 S1 H1              						; Forbid axis movements when not homed
                      M552 P0.0.0.0 S1                                 ; enable network and acquire dynamic address via DHCP
                      M586 P0 S1                                       ; enable HTTP
                      M586 P1 S0                                       ; disable FTP
                      M586 P2 S0                                       ; disable Telnet
                      M569 P0.0 S0                                     ; X drive goes back
                      M569 P0.1 S1                                     ; Z1 drive
                      M569 P0.2 S0                                     ; Z2 drive
                      M569 P0.3 S1                                     ; Z3 drive
                      M569 P0.4 S0                                     ; Z4 drive
                      M569 P0.5 S0                                     ; Y drive
                      G4 P500											; Pause for toolboards init
                      M569 P21.0 S1                                   ; Extruder 1 (T0)
                      M569 P1.1 S0                                    ; Extruder 1 spool driver
                      M569 P22.0 S1                                   ; Extruder 2 (T1)
                      M569 P1.2 S0                                   ; Extruder 2 spool driver
                      M569 P1.0 S1                                   ; Coupler
                      M584 X0.0 Y0.5 Z0.1:0.2:0.3:0.4 C1.0        ; set Move drive mapping
                      M584 E21.0:1.1:22.0:1.2                    ; set Extruder drive mapping
                      M208 Z-4:875 C0:500
                      M208 X-570:570 Y-630:500
                      ; Define the bed mounting coordinates
                      M671 X-473:473:473:-473 Y730:730:-735:-735 S10 ;Snn Maximum correction allowed for each leadscrew in mm (optional, default 1.0)
                      M574 X1 S1 P"!io1.in"                           ; configure active-high endstop for high end on X via pin !io1.in
                      M574 Y2 S1 P"!io2.in"                           ; configure active-high endstop for low end on Y via pin !io2.in
                      M574 Z0 P"nil"									; no endstop on Z
                      M574 C1 S3										; Stall detect coupler at low end of its range
                      ;Steps per mm = (Motor Steps per Revolution * Driver Microstep) / (Belt Pitch * Pully Number of Teeth)
                      ; X: GT2-20 / Y: HTD3-20 * (48/16) / Z: HTD5-20 * 6
                      M92 X80 Y160 Z800 C200 					; set steps per mm
                      M92 E420.00:115.00:420.00:115.00 				; set steps per mm
                      M350 X16 Y16 Z16 E16:16 I1                       ; configure microstepping with interpolation
                      M350 C16 I1
                      M566 X420 Y420 Z8 C2 E200:200:200:200			; Set maximum instantaneous speed changes (mm/min)
                      M203 X9000.00 Y9000.00 Z600.00 C10000 E6000.00 	; set maximum speeds (mm/min)
                      M201 X1200.00 Y1200.00 Z100.00 C500 E2500       	; set accelerations (mm/s^2)
                      M204 P250 T1200										; Travel and print acceleration
                      M906 X1200 Y1600 Z2400 C500 E900:900:900:900	 	; set motor currents (mA) and motor idle factor in per cent
                      M913 C50
                      M906 I30
                      M913 E100:0:100:0									; set Working current to Extruders
                      M84 S120                                       		; Set idle timeout
                      ;Stall Detection
                      M915 C S5 F0 H200 					; Coupler
                      ; Calibrate Nozzle Height probe
                      M558 K1 P8 B0 C"^io8.in" H30 F120 T9000
                      M558 K0 P5 B1 C"^io7.in" H5 A5 F120 T9000			; set Z probe type to switch and the dive height + speeds
                      G31 K0 X0 Y0 Z0 P1000                            	; set Z probe trigger value, offset and trigger height
                      M557 X-500:500 Y-500:500 S100                       ; define mesh grid
                      ; ==== Heaters ====
                      ; Bed
                      M308 S0 P"temp0" Y"thermistor" T100000 B3950     	; configure sensor 0 as thermistor on pin temp0
                      ;M950 H0 C"out0" T0                             	; create bed heater output on out0 and map it to sensor 0
                      M950 H0 C"out0" T0 Q10         						; Heater --> SSD-Steuerung
                      ;M307 H0 B0 S0.80                                 	; disable bang-bang mode for the bed heater and set PWM limit
                      ;M307 H0 R0.425 C261.3 D4.03 S0.80				; Tuned
                      M307 H0 R0.191 C560.9 D3.56 S1.00 V24.1
                      M140 H0                                          ; map heated bed to heater 0
                      M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                      ; Chamber
                      M308 S5 P"temp1" Y"thermistor" T100000 B4138  ; configure sensor 5 as thermistor on pin temp1
                      M950 H5 C"out9" T5 Q10                          ; create chamber heater output on temp1 and map it to sensor 5
                      M307 H5 R1.000 C30.9 D9.18 S1.00 V24.1 		; Tuned
                      M141 H5                                       ; map chamber to heater 5
                      M143 H5 S75                                   ; set temperature limit for heater
                      M950 F5 C"out4" Q500                          ; cooling fan
                      M106 P5 S0 H-1 C"Filament FAN" 					; Control be trigger2
                      ;M106 P5 S1 H5 T22:60                          	; thermistatic control
                      M950 J8 C"0.io6.in"							; Input 8 for filament Fan
                      M581 T2 P8 S1 R0							; Invoke trigger 2 when an inactive-to-active edge is detected on input 8
                      ; Extruder 1
                      M308 S1 P"21.temp0" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin 121.temp0
                      M950 H1 C"21.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
                      M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
                      M143 H1 S285                                    ; set temperature limit for heater 1 to 285C
                      ;M307 H1 R3.214 C42.3 D7.77 S0.75 V23.2 		; Tuned
                      M307 H1 R0.056 C194.7 D8.90 S1.00 V23.9		; small block
                      ;M307 H1 R3.358 C190.6 D7.20 S0.60 V23.6
                      ; Extruder 2
                      M308 S2 P"22.temp0" Y"thermistor" T100000 B4725 ; configure sensor 2 as thermistor on pin 122.temp0
                      M950 H2 C"22.out0" T2                           ; create nozzle heater output on 122.out0 and map it to sensor 2
                      M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
                      M143 H2 S285                                    ; set temperature limit for heater 2 to 285C
                      ;M307 H2 R3.056 C229.5 D7.91 S0.80 V23.3 		; Tuned
                      ;M307 H2 R3.090 C199.8 D7.36 S0.75 V23.3
                      ;M307 H2 R3.202 C234.301:234.301 D7.52 S0.70 V23.3 B0 I0
                      M307 H2 R3.358 C190.6 D7.20 S0.60 V23.6
                      ; *** Fans
                      ; Extruder 1 Fan
                      M950 F0 C"21.out1" Q500                         ; Part cooling fan
                      M106 P0 S0 B0.1 H-1                             ; Default off. booststart for 0.1s (B0.1); thermostatic control off
                      M950 F1 C"21.out2" Q500                         ; Hotend cooling fan
                      M106 P1 S1 H1 T50                            	; Default on. thermistatic control on above 50C
                      ; Extruder 2 Fan
                      M950 F2 C"22.out1" Q500                         ; Part cooling fan
                      M106 P2 S0 B0.1 H-1                             ; Default off. booststart for 0.1s (B0.1); thermostatic control off
                      M950 F3 C"22.out2" Q500                         ; Hotend cooling fan
                      M106 P3 S0 H2 T50                            	; Default on. thermistatic control on above 50C
                      ; Extruder 1 Tool
                      M563 P0 S"Extruder-1" D0:1 H1 F0
                      M567 P0 E1:1									; mixing
                      G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
                      G10 P0 X0 Y76 Z0 								; Reset tool axis offsets
                      ; Extruder 2 Tool
                      M563 P1 S"Extruder-2" D2:3 H2 F2 				; define tool 1
                      M567 P1 E1:1									; mixing
                      G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
                      G10 P1 X0 Y76 Z0 								; Reset tool axis offsets
                      ; Retraction
                      ;M207 S6.5 R0.0 F4800 T4800 Z0.0
                      M207 S4 R0.0 F3000 T2100 Z0.4
                      	; M207: Set retract length
                      	; Parameters
                          ; 	Pn Tool number (optional, supported in RRF 3.01 and later only)
                      	; 	Snnn positive length to retract, in mm
                      	; 	Rnnn positive or negative additional length to un-retract, in mm, default zero
                      	; 	Fnnn retraction feedrate, in mm/min
                      	; 	Tnnn feedrate for un-retraction if different from retraction, mm/min (RepRapFirmware 1.16 and later only)
                      	; 	Znnn additional zlift/hop
                      	; Example: M207 S4.0 F2400 Z0.075
                      ; FEEDRATE CONVERSIONS
                      	; 20mm/s = F1200	; 100mm/s = F6000
                      	; 35mm/s = F2100	; 120mm/s = F7200
                      	; 50mm/s = F3000	; 133mm/s = F8000
                      	; 70mm/s = F4200
                      ; * ======= tool offsets ======== *
                      ; Set in config-override.g
                      ;G10 P0 X0 Y76 Z-21					; T0
                      ;G10 P1 X0 Y76 Z-21					; T1
                      ; Filament monitors
                      ;  ** Rotating
                      M591 P3 C"21.io1.in" D0 R30:160 S1
                      M591 P3 C"22.io1.in" D2 R30:160 S1
                      ;  ** Endstops
                      M950 J4 C"!^1.io1.in"		; Input 4 for filament trigger
                      M950 J5 C"!^1.io2.in"		; Input 5 for filament trigger
                      ; Invoke trigger 1 (M25) when an active-to-inactive edge is detected on input 4 and 5 and a file is being printed from SD card
                      M581 T1 P4 S0 R1
                      M581 T1 P5 S0 R1
                      M572 D0 S0.02 							; pressure advance T0
                      M572 D1 S0.02 							; pressure advance T1
                      ;M572 D2 S0.05 							; pressure advance T2
                      ;M572 D3 S0.05 							; pressure advance T3
                      ; Set up the dock indicator switches on the tools.
                      M950 J0 C"!^io3.in"					; GpIn 3 = tool 0 dock switch
                      M950 J1 C"!^io4.in"					; GpIn 4 = tool 1 dock switch
                      ; Z Motors brake
                      M950 P0 C"0.out1"
                      ; Z Motors brake OFF
                      G92 Z0
                      G91 					; Relative mode
                      M400 					; make sure everything has stopped before we change the motor currents
                      M913 Z100	 			; drop motor currents to 20%
                      G1 Z0.05
                      M400
                      G4 P1000								; Pause
                      M42 P0 S1 								; Brake oFF
                      M911 S23.5 R23.8 P"M42 P0 S0"
                      G90
                      ;M593 F50							; cancel ringing at 50Hz
                      M376 H20							; bed compensation taper
                      M501                                ; load saved parameters from non-volatile memory
                      ;G29 S1 							; Do not use G29 S1 within config.g, because no Z=0 datum has been established at that point
                      G90						; !!! absolute positioning
                      homez:
                      ; homez.g
                      ; called to home the Z axis
                      while iterations < 2
                        if iterations < #sensors.gpIn && sensors.gpIn[iterations] != null && sensors.gpIn[iterations].value = 0
                          M291 S1 T5 P{"Please return tool "^iterations^" to dock before homing"} R"Cannot home"
                          abort
                      ;M290 R0 S0 ; clear babystepping
                      ;M561 ; clear any bed transform
                      G91 					; Relative mode
                      ;M913 Z80	 			; drop motor currents to 20%
                      G1 H2 Z5 F1000			; Lower the bed
                      ;M913 Z100	 			; motor currents to 100%
                      G90						; back to absolute positioning
                      ;G1 X0 Y0 F9000			; Position the endstop above the bed centre
                      G1 X-473 Y500 F9000		; Position the endstop near leadscrew
                      ;G1 X473 Y500 F9000		; Position for test
                      M400
                      ;if move.axes[2].machinePosition > 9
                      ;	M558 K0 F1000 H3
                      ;	G30 Z-9999
                      M558 K0 F600 H5 A1
                      G30 Z-9999
                      M558 K0 F120 H5 A5
                      G30 Z-9999
                      M400
                      ;M558 K0 H30
                      ;G91 				; Relative mode
                      ;G1 Z10 F1000			; Lower the bed
                      ;G90				; back to absolute positioning
                      bed.g (called from homeall.g)
                      ; bed.g
                      ; Called to align the gantry to the bed plane via G32
                          abort
                      M84 E0:1				; Turn off noisy Extruder motor
                      M98 P"homez.g"
                      M558 K0 H10 F120			; F120
                      M98 P"/macros/Move/bed_level_points"
                      ;M98 P"homez.g"
                      ;G28 Z
                      ;G1 X0 Y0 F12000		; Position the endstop above the bed centre
                      ;M558 F120
                      ;G30 Z-9999
                      ;M400
                      M98 P"homez.g"
                      M558 K0 H5
                      mesh.g
                      ; mesh.g
                      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed || !move.axes[3].homed
                      	M291 S1 T5 P{"Please Home before probe"} R"Cannot probe"
                      	abort
                      if state.currentTool != -1
                      	M291 S1 T5 P{"Please return All tools to dock before probing"} R"Cannot probe"
                      	abort "Cannot do mesh probing when a tool is selected"
                      ;G32						; Level the gantry
                      ;M98 P"homez.g"
                      ; Heat the bed to 80C
                      ;M291 P"Heating up the bed..." R"Probing New Bed Mesh" T5
                      ;M190 S80
                      ;M116
                      ;G32						; Level the gantry again while everything is hot
                      M558 K0 H3 T9000 F120 A5
                      G29 S0
                      M558 K0 H5 T9000
                      M140 S0 				; Turn off bed
                      M291 P"Done!" R"Bed Mesh" T5
                      homeall.g (G29 S1 here)
                      ; homeall.g
                      ; called to home all axes
                      M98 P"homex.g"
                      M98 P"homey.g"
                      M98 P"bed.g"
                      G29 S1
                        What's in that macro?
                        M98 P"homex.g" M98 P"homey.g"
                        Can you share these as well?
                        Can you also share the results of sending M98 P"config.g" and share your slicer start gcode.
                        • Depundefined
                          Dep @Phaedrux
                          @Phaedrux оf course
                          bed_level_points :
                          G30 P0 X-473 Y500 Z-99999 ;P0 - Probe point 0 (not drive)
                          G30 P1 X473 Y500 Z-99999
                          G30 P2 X473 Y-500 Z-99999
                          G30 P3 X-473 Y-500 Z-99999 S4 ;set correction
                          homex.g
                          ; homex.g
                          ; called to home the X axis
                              abort
                          G91              	; relative positioning
                          G1 H2 Z5 F6000 		; lift Z relative to current position
                          G1 H1 X-1200 F6000 	; move quickly to X axis endstop and stop there (first pass)
                          G1 H2 X5 F6000  	; go back a few mm
                          G1 H1 X-1200 F360  	; move slowly to X axis endstop once more (second pass)
                          G1 H2 X5 F6000 	; move away from end
                          G1 H2 Z-5 F6000  	; up Z again
                          G90              	; absolute positioning
                          homey.g
                          ; homey.g
                          ; called to home the Y axis
                              abort
                                M98 P"homex.g"
                          G1 H1 Y1205 F6000  ; move quickly to Y axis endstop and stop there (first pass)
                          G1 H2 Y-5 F6000      ; go back a few mm
                          G1 H1 Y1205 F360   ; move slowly to Y axis endstop once more (second pass)
                          G1 H2 Y-50 F6000  	; move away from end
                          Slicer (S3D) start code:
                          ; START code
                          M140 S[bed0_temperature]
                          M106 S0 ;fan off
                          G92 E0; reset extruder distance
                          G28
                          T0 ; Select tool 0
                          M116
                          G10 P0 S[extruder0_temperature] R160
                          M116
                          M98 P"/macros/Purge Filament"
                          ;---  end start gcode ---
                          • Depundefined
                            Dep
                            @Phaedrux said in Strange bugs 3.3beta2:
                            M98 P"config.g"
                            18.03.2021, 22:24:45	M98 P"config.g"
                            HTTP is enabled on port 80
                            FTP is disabled
                            TELNET is disabled
                              With a taper set the amount moved to compensate is diminished over the duration of the print and for small amounts can make it very hard to see.
                              Can you post a screenshot showing your heightmap?
                              How often do you re-create the heightmap?
                              • Depundefined
                                Dep
                                I've done it many times. The print shows that the compensation does not work. I also attach a long stick to the pulley to check if there is movement or not.
                                If necessary, I can shoot a video.
                                • Depundefined
                                  Dep @Phaedrux
                                  I've tried disabling taper. M376 H0
                                  Nothing changes.
                                    jay_s_uk
                                    add G29 S1 after the G28 in your start script
                                    • Depundefined
                                      Dep @jay_s_uk
                                      @jay_s_uk It is added:
                                      ; homeall.g
                                      M98 P"homex.g"
                                      M98 P"homey.g"
                                      M98 P"bed.g"
                                      G29 S1
                                        jay_s_uk @Dep
                                        @Dep ah, missed that
                                          All I can think is that the conditional gcode in your homing files is skipping something.
                                          Can you try adding G29 S1 to your slicer start gcode after the purge filament macro?
                                          Then check if mesh compensation is active in M122 during the print and see if the Z axis is moving.
                                          • OwenDundefined
                                            OwenD
                                            Could it be that you're not homing Z after you run bed.g ?
