    Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning
    Firmware wishlist
    20
    64
    10.9k
    • Argoundefined
      Argo
      Since yesterday I'm testing Klipper at one of our printers. In particular the input shapers and their auto tuning with a ADXL345 accelerometer woke my interest.
      It turns out my bed slinger printer (Bear Frame with Bondtech Extruder) has different resonance frequencies on each axis.
      After the auto calibration /measurement it recommended:
      Recommended shaper_type_x = 3hump_ei, shaper_freq_x = 61.4 Hz
      Recommended shaper_type_y = 2hump_ei, shaper_freq_y = 57.4 Hz
      I see there are input shapers on the way for RRF but I couldn't find exact infos what shaper will be used and if it will be possible to enter a shaper frequency for each axis separately.
      To sum it up, here are my wishes for RRF 3.4+:
      • support for a accelerometer (preferable ADXL345 as it's easy to find and buy) to measure the needed frequency. The input shapers 2HUMP_EI & 3HUMP_EI may need this as it can't be easily measured
      • Input shapers: 2HUMP_EI & 3HUMP_EI
      • separate frequencies and dampening for each axis (at the moment RRFs DAA uses the same frequency for both axis)
      zaptaundefined 1 Reply Last reply Reply Quote 5
      • Frederikundefined
        Frederik
        Tuning the Inputshaper via Accelerometer would be amazing 🙂
        • Egon.Netundefined
          Egon.Net
          And please leave a way to do it for the good old Duet 2 Wifi 😉
          Argoundefined 1 Reply Last reply Reply Quote 1
          • carcamerarigundefined
            carcamerarig
            @Argo said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
            Gets a +1👍🏼 Vote from me.
            • Argoundefined
              Argo @Egon.Net
              @Egon-Net
              it's still a fast 32 bit board but I don't know if the available connections are fast enough for a accelerometer.
              But you could run Klipper with your Duet 2 🙂
              Egon.Netundefined 1 Reply Last reply Reply Quote 0
                The accelerometer we are testing with is the LIS3DH. The Adafruit breakout board for it is widely available.
                Please note, the use of EI input shaping in 3D printers is patent protected. That's why we intend to support ZVDD as well.
                MikeSundefined 1 Reply Last reply Reply Quote 0
                • zaptaundefined
                  zapta @Argo
                  @Argo does Klipper support also backlash compensation? I wonder if the accelerometer can be used to calibrate it as well.
                  • Egon.Netundefined
                    Egon.Net @Argo
                    @Egon-Net
                    At leats be able to measure externally and input the results... (With and arduino, pc, whatever)
                    • MikeSundefined
                      MikeS @dc42
                      @dc42 please consider on supporting also ADXL345. It's the most common and cheapest one. I had one laying around that i used on my previous delta to do probing of the bed. I understand that, as a business, you have to come up with your own implementation and maybe better solution for the resonance problem, but klipper one for now would be great. We have time to improve it and have a better one!
                        LIS3DH boards from well-known suppliers such as Adafruit are half the price (or less) of ADXL345 boards.
                        zaptaundefined MikeSundefined 2 Replies Last reply Reply Quote 1
                        • Argoundefined
                          Argo
                          The ADXL345 cost me 6 EUR and a LIS3DH would cost me 10 EUR.
                          But honestly I don't really care if I had to buy another one for my Duet / RRF.
                          @zapta said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                          It's measurable, so yes.
                          • zaptaundefined
                            zapta @dc42
                            The Adafruit LIS3DH is available in my country on Amazon, $7 Prime shipped.
                            https://www.amazon.com/Adafruit-LIS3DH-Triple-Axis-Accelerometer-ADA2809/dp/B01BU70B64
                            @dc42, will input shaping be supported on stand alone Duet2 Wifi?
                              dc42 administrators @zapta
                              Yes, but perhaps not on the Duet Maestro because it doesn't have floating point hardware.
                              CCS86undefined 1 Reply Last reply Reply Quote 1
                              • MikeSundefined
                                MikeS @dc42
                                @dc42 no problem at all at buying another accelerometer, but just for reference, amazon IT has ADXL345 at €5.99 with prime, LIS3DH €15.46 with prime. Most important is: are there differences on precision of the readings between these 2? 10€ difference is not a problem compared to accuracy of readings
                                • printernoodleundefined
                                  printernoodle
                                  I am looking forward to this feature set...
                                    dc42 administrators @printernoodle
                                    More at https://duet3d.dozuki.com/Wiki/Accelerometers, and sample results at https://forum.e3d-online.com/threads/accelerometer-and-resonance-measurements-of-the-motion-system.3445/#post-38177.
                                    zaptaundefined MikeSundefined 2 Replies Last reply Reply Quote 0
                                    • zaptaundefined
                                      zapta @dc42
                                      @dc42 said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                                      @dc42, Can you post the graphs here? E3D requires registration to view them.
                                        The first two are without input shaping. The second two are with ZVD input shaping at 42Hz. ZVDD didn't give any further improvement, and both EI2 and EI3 were worse.
                                        Argoundefined 1 Reply Last reply Reply Quote 2
                                        • Argoundefined
                                          Argo @dc42
                                          Very nice seeing progress there!
                                          Also as usual it looks very tidy and well thought out so far.
                                          just ordered a Adafruit LIS3DH and plan to experiment with the new feature.
                                          I see (experimental?) input shapers are also already implemented in the 3.3-input-shaper branch.
                                          Is it already worth to try and experiment with the feature also during printing conditions?
                                          Would like to see how the input shapers work with a typical i3 bed slinger as these printers tend to have different ringing frequencies at once. And I also could provide some results/data.
                                            dc42 administrators @Argo
                                            @argo said in Input Shapers: 2HUMP_EI & 3HUMP_EI + Auto Tuning:
                                            Experiment if you like; but the code is by no means complete, so be very careful. Pressure advance is disabled - I haven't even tried extruding. Delta kinematics is not implemented.
                                            Input shaping will only work on moves for which the acceleration time is long enough to apply it, i.e. at least 2 * the shaping time. So you may need to reduce acceleration to get it applied. I believe there is some scope to apply it to shorter acceleration times, down to 1 * the shaping time + one half period, at least when using ZVD or ZVDD, but that isn't implemented yet. Also I will probably implement reducing acceleration (but not below a minimum) where necessary to allow input shaping to be applied.
                                            I don't expect to include the input shaping code in the 3.3 release.
                                            CNCModellerundefined 1 Reply Last reply Reply Quote 1
