    Delta mesh leveling not working.
    804
    • darkuncle33undefined
      darkuncle33
       I am new to duet, just installed duet 2 wifi on my flsun q5.
      all is working well except when I print there is no bed mesh compensation. so my nozzle is grinding into the bed on the corners.
      I have tried everything I can think of to get it working.
      Ran g32 and g29 then printed and same result.
      put g29 s1 in start gcode. same thing, grinding my bed.
      Every time I home g28 then g29 s1 it tells me "Warning: G29: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset."
      Any help?
        Please post your config.g, homedelta.g, bed.g and your slicer start gcode. It would also help to see the results of M122 and M98 P"config.g".
        Also check out these pages
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
        https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
        https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
        darkuncle33undefined 4 Replies Last reply Reply Quote 0
          darkuncle33 @Phaedrux
          @phaedrux ; Configuration file for Duet WiFi (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 04 2021 16:38:36 GMT-0400 (Eastern Daylight Time)
          M550 P"Flsun_Q5_Duet" ; set printer name
          M665 R107.5 L215 B100 H300 ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z80.00 E413.00 ; set steps per mm
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 Z0 S1 ; set minimum Z
          M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
          M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
          M558 P5 C"^!zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z19.36 ; set Z probe trigger value, offset and trigger height
          M557 R85 S20 ; define mesh grid
          M143 H1 S275 ; set temperature limit for heater 1 to 275C
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
          sgtconker1rundefined 1 Reply Last reply Reply Quote 0
            @phaedrux ; bed.g
            ; called to perform automatic delta calibration via G32
            ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
            ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
            G30 P0 X0 Y84.9 H0 Z-99999
            G30 P1 X73.53 Y-42.45 H0 Z-99999
            G30 P2 X-73.53 Y-42.45 H0 Z-99999
            G30 P3 X0 Y42.4 H0 Z-99999
            G30 P4 X36.72 Y-21.2 H0 Z-99999
            G30 P5 X-36.72 Y-21.2 H0 Z-99999
            G30 P6 X0 Y0 H0 Z-99999 S6
            ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
            ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
              @phaedrux ; homedelta.g
              ; called to home all towers on a delta printer
              G91 ; relative positioning
              G1 H1 X305 Y305 Z305 F1800 ; move all towers to the high end stopping at the endstops (first pass)
              G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
              G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
              G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
              G90 ; absolute positioning
              G1 X0 Y0 F6000 ; move X+Y to the centre
              G29 s1
              Start gcode
              G28
              G29 S1
              G1 Z15.0 F6000 ;Move the platform down 15mm
              ;Prime the extruder
              G92 E0
              G1 F200 E3
              G92 E0
                @phaedrux
                I spent all day going through the guides and nothing changed.
                Every time I the bed map it look good. I can see where my bed is uneven a little.
                When I print the nozzle grinds into the bed and within 40 mm is printing in air then back to grinding the bed.
                  Phaedrux Moderator @darkuncle33
                  @darkuncle33 said in Delta mesh leveling not working.:
                  Start gcode
                  G28
                  G29 S1
                  You should be doing a calibration between homing the towers and loading the heightmap. Add G32 between the G28 and G29.
                  darkuncle33undefined 2 Replies Last reply Reply Quote 0
                    @phaedrux
                    I don't see how I can do that. I have a removeable probe. I tried that and it just started printing with the probe attached.
                      @phaedrux
                      I put a pause "M25" on the start gcode after the g29, so I could take the probe off. That worked, It is printing now, Is that how it should be done? Is there something I am still doing wrong? With the factory firmware you only need to use the probe once or if you change something, not before every print. So taking it of mid print is not an issue.
                        Well when you home the towers you are assuming that the homed height is correct for the distance to the bed, but it might not be. Normally you'd do at least a single G30 at the center of the bed to re-establish an accurate position for the z0 point before loading the heightmap. But with a delta i's even more common to do a quick calibration run before each print just for best results. That is complicated by the removable probe in this case, but still probably the best way to go.
                        darkuncle33undefined 1 Reply Last reply Reply Quote 0
                          @phaedrux
                          I am happy to take the probe off before every print because I am getting really nice first layers that way. Now I am going to see if there is a way to have a message on the paneldue that says "Attach probe" and "Remove probe" with two print pauses in the start gcode. That you make the hole thing look more polished.
                            Check out the M291 command. It can pause and display a prompt for ok/cancel.
                            • sgtconker1rundefined
                              sgtconker1r @darkuncle33
                              @darkuncle33
                              Your M665 H value is way to high for a Q5.
                              with a stock q5 it should be no more than 220.
