    Delta mesh leveling not working.
    803
    • darkuncle33undefined
      darkuncle33 @Phaedrux
      @phaedrux ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Apr 04 2021 16:38:36 GMT-0400 (Eastern Daylight Time)
      ; Probe the bed at 3 peripheral and 3 halfway points, and perform 6-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y84.9 H0 Z-99999
      G30 P1 X73.53 Y-42.45 H0 Z-99999
      G30 P2 X-73.53 Y-42.45 H0 Z-99999
      G30 P3 X0 Y42.4 H0 Z-99999
      G30 P4 X36.72 Y-21.2 H0 Z-99999
      G30 P5 X-36.72 Y-21.2 H0 Z-99999
      G30 P6 X0 Y0 H0 Z-99999 S6
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
        @phaedrux ; homedelta.g
        ; called to home all towers on a delta printer
        G91 ; relative positioning
        G1 H1 X305 Y305 Z305 F1800 ; move all towers to the high end stopping at the endstops (first pass)
        G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
        G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
        G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
        G90 ; absolute positioning
        G1 X0 Y0 F6000 ; move X+Y to the centre
        G29 s1
        Start gcode
        G28
        G29 S1
        G1 Z15.0 F6000 ;Move the platform down 15mm
        ;Prime the extruder
        G92 E0
        G1 F200 E3
        G92 E0
          @phaedrux
          I spent all day going through the guides and nothing changed.
          Every time I the bed map it look good. I can see where my bed is uneven a little.
          When I print the nozzle grinds into the bed and within 40 mm is printing in air then back to grinding the bed.
            Phaedrux Moderator @darkuncle33
            @darkuncle33 said in Delta mesh leveling not working.:
            Start gcode
            G28
            G29 S1
            You should be doing a calibration between homing the towers and loading the heightmap. Add G32 between the G28 and G29.
            darkuncle33undefined 2 Replies Last reply Reply Quote 0
              @phaedrux
              I don't see how I can do that. I have a removeable probe. I tried that and it just started printing with the probe attached.
                @phaedrux
                I put a pause "M25" on the start gcode after the g29, so I could take the probe off. That worked, It is printing now, Is that how it should be done? Is there something I am still doing wrong? With the factory firmware you only need to use the probe once or if you change something, not before every print. So taking it of mid print is not an issue.
                  Well when you home the towers you are assuming that the homed height is correct for the distance to the bed, but it might not be. Normally you'd do at least a single G30 at the center of the bed to re-establish an accurate position for the z0 point before loading the heightmap. But with a delta i's even more common to do a quick calibration run before each print just for best results. That is complicated by the removable probe in this case, but still probably the best way to go.
                  darkuncle33undefined 1 Reply Last reply Reply Quote 0
                    @phaedrux
                    I am happy to take the probe off before every print because I am getting really nice first layers that way. Now I am going to see if there is a way to have a message on the paneldue that says "Attach probe" and "Remove probe" with two print pauses in the start gcode. That you make the hole thing look more polished.
                      Check out the M291 command. It can pause and display a prompt for ok/cancel.
                      • sgtconker1rundefined
                        sgtconker1r @darkuncle33
                        @darkuncle33
                        Your M665 H value is way to high for a Q5.
                        with a stock q5 it should be no more than 220.
