    StepDown 24V-->12V for Noctua Fan
    3.0k
    • mrehorstdmdundefined
      mrehorstdmd @d0minik96
      @d0minik96 This is a lot simpler than you're making it out to be. It's a 12V fan. If it runs properly when you connect it to the DC-DC converter it's fine. A 12V fan will run extra fast and will probably burn up in short order if you connect it to 24V. Is the fan behaving normally? Did it burn up?
      d0minik96undefined 1 Reply Last reply Reply Quote 0
      • d0minik96undefined
        d0minik96 @mrehorstdmd
        @mrehorstdmd
        I dont think this is true. I measue the voltage drop over the Fan with a Multimeter. Its 24V. The Fan can handle 24 v but Not for a lang duration.
        It is Turning fast, but since i have no reference i can Not say if it too fast or Not.
        I will check tomorrow my wiring, mabye there is something wrong with the wires from my artillery, i dont know. But im Sure the stepdown converter works as it should, just Not with the Fan.
        As i tested the with this liste voltage Display for drones that i had flying arround.
        I would say im pretty fit with Electronic but this duet conversation is just a night mare for me so far. Did Not find anybody with the same Issue, so must be wiring or some electrical Circuit issue
        alankilianundefined jens55undefined MarkJohnston09undefined 3 Replies Last reply Reply Quote 0
        • alankilianundefined
          alankilian @d0minik96
          @d0minik96 Maybe add a capacitor across the step-down converter's output terminals.
          Something like 1000 microFarads should be enough to smooth things out if the fan is doing something that gets the converter to fail to control its output voltage.
          • jens55undefined
            jens55 @d0minik96
            @d0minik96 said in StepDown 24V-->12V for Noctua Fan:
            @mrehorstdmd
            You stated that you went from the power supply to the converter to the fan .... are you now saying that other stuff is attached anywhere?
            If so, remove whatever else is hooked up and then see what you get!
              d0minik96
              I did some more testing:
              The buck converter works. I directly solderd my fan to the buck converter and i had 12 V on the fan and the fan was moving quieter than before.
              But after using the cables of my Artillery it is running with 24 V again.
              So there must be a problem with the wiring. I am using the preinstalled
              ribbon cables of my Artillery. There is a small pcb inside of the printer where the cables change from ribbon to normal. Im sure that i have the right pair, as the fan is not moving when disconnect this 2 specific wires. My guess is that on the PCB is something that converts my 12 V to 24 V but i am not sure why. I will check google if this is common Artillery problem....
                dc42 administrators @d0minik96
                Most likely that PCB is using a common positive wire for the hot end heater and the fan.
                  d0minik96 @dc42
                  @dc42 yes i just found out, that the 24V line is shared, so that is where my problem is comming from. I solved it by placing the buck converter between my PCB and the Fan at the hotend.
                  • jens55undefined
                    jens55
                    ... and this is why I am reluctant to help people over the internet. You just can't rely on them to convey the true nature of the situation. It is always tainted by the same mind that can't see the forest for the trees.
                    If we had known that the wiring involved the printer rather than going straight from the power supply to the buck converter and straight from the converter to the fan then instead of 22 posts on this issue it would have been just a hand full.
                    That's a whole lot of people trying to help one person that can't be bothered to fully explain how things are connected.
                      d0minik96
                      I'm sorry that i wasted your lifetime. Ty all for your suggestions. Helped me to find the problem !
                        Hey, you got a working step-down converter and fan, so it's all good.
                        I hope next time when someone says "...just in case you missed something, can you post a photograph of your wiring and maybe a video of your testing?" you can take the time to do that. I could have saved you a lot of time and frustration.
                        • MarkJohnston09undefined
                          MarkJohnston09 @d0minik96
                          I have also checked the converter with my drone DJI Mini, and it worked quite well.
