    Bed levelling using multiple independent Z motors
    973
      jay_s_uk @CHARLI55
      @charli55 one thing you don't need is M401/M402 in your bed file as thats handled by the firmware.
      Were there any outputs?
      Having S0.5 on M671 limits the adjustment to anything out of whack more than 0.5. I suggest increasing this value above what you expect the maximum out of level to be, e.g. S10
      CHARLI55undefined 2 Replies Last reply Reply Quote 0
      • CHARLI55undefined
        CHARLI55 @jay_s_uk
        I change it, try and comment, thank you.
        • Nuramoriundefined
          Nuramori @CHARLI55
          @charli55 you can’t do a triple z axis solution with just a duet2wifi. You need a duex2 or duex5 expansion board. Your config.g seems to suggest that you haven’t done this. We have a very strong blv community on Facebook and now our own discord server for this; I also am one of the two main people that have done the independent triple z axis redesigns that are used on it. I’m happy to help you through it.
          jay_s_ukundefined CHARLI55undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Nuramori
            @nuramori why does it suggest that? he's mapped drivers 5 and 6 to Z, suggesting 3 drivers being used.
            Nuramoriundefined 1 Reply Last reply Reply Quote 0
            • CHARLI55undefined
              CHARLI55 @Nuramori
              @nuramori M584 X0 Y1 Z2:5:6 E3:4
              I have duet wifi + duex5
              • Nuramoriundefined
                Nuramori @jay_s_uk
                @jay_s_uk just a brain fart. I’ve gotten used to the preceding nomenclature for drivers like 0.1, 1.2 so it looked like there wasn’t an expansion board associated with it. My bad.
                • CHARLI55undefined
                  CHARLI55 @jay_s_uk
                  @jay_s_uk M671 X176:305:46 Y3:285:285 S1.0
                  The engines still do not move
                  Z
                    jay_s_uk @CHARLI55
                    @charli55 is there any output in the console?
                    CHARLI55undefined 1 Reply Last reply Reply Quote 0
                    • CHARLI55undefined
                      CHARLI55 @jay_s_uk
                      @jay_s_uk Error: Compensation or calibration cancelled due to probing errors
                      13/4/2021 20:28:34 g32
                      Error: Z probe was not triggered during probing move
                      • CHARLI55undefined
                        CHARLI55 @CHARLI55
                        @charli55
                        If it is true that it is not activated in the first spindle, the red IR LED does not turn on
                        • o_lampeundefined
                          o_lampe @CHARLI55
                          @charli55
                          Does the z-probe work in the center of the bed? Maybe you have to increase the 'dive height' of the z-probe?
                          • CHARLI55undefined
                            CHARLI55
                            But I don't know what happens if the bed almost touches the IR
                            • CHARLI55undefined
                              CHARLI55
                              Thanks, it's already solved. Spindle adjustments made: -0.287 -0.128 -0.303, points used 3, (mean, deviation) before (-0.238, 0.079) after (0.000, 0.000
                              • CHARLI55undefined
                                CHARLI55 @CHARLI55
                                @charli55 said in Bed levelling using multiple independent Z motors:
                                your dive height isn't high enough to accomodate the bed skew
