    G28 Error: Failed to enable endstops Sensorless Homing Homing
    Using Duet Controllers
    1.4k
    • tkdirpundefined
      tkdirp
      I am trying to make Sensorless Homing work on a core-XY machine but whatever I did so far spits out "G28 Error: Failed to enable endstops"
      M574 X S3 ; configure sensorless homing for low end on X
      M574 Y S3 ; configure sensorless homing for low end on Y
      M915 X Y R0 F0 ; configure stall detection
      M915 X Y S5 R2
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F300 T18000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X16.5 Y-20.2 Z1.89 ; set Z probe trigger value, offset and trigger height
      M557 X50:250 Y50:250 S50 ; define mesh grid
        Can you provide the results of M122 and M98 P"config.g"?
        Also your full config.g and homeall.g files.
        tkdirpundefined 1 Reply Last reply Reply Quote 0
        • tkdirpundefined
          tkdirp @Phaedrux
          @phaedrux said in G28 Error: Failed to enable endstops Sensorless Homing Homing:
          M550 P"Penteract" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P4 S0 ; physical drive 3 goes backwards
          M584 X0 Y1 Z2 E4 ; set drive mapping
          M92 X80.00 Y80.00 Z1600.00 E690.00 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z180.00 E3600.00 ; set maximum speeds (mm/min)
          M201 X2500.00 Y2500.00 Z20.00 E600.00 ; set accelerations (mm/s^2)
          M906 X1500 Y1500 Z400 E750 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-8 Y-8 Z0 S1 ; set axis minima
          M208 X300 Y300 Z300 S0 ; set axis maxima
          M574 X S3 P"xstop" ; configure sensorless homing for low end on X
          M574 Y S3 P"ystop" ; configure sensorless homing for low end on Y
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 A422.1 C597.7 D5.1 V24.2 B0 ; tune of heater 0
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M572 D0 S0.04 ; set tool 0 pressure advance
          ; homeall.g
          ; called to home all axes
          M400
          M913 X70 Y70 ; drop motor current to 70%
          M400 G91; relative positioning
          G1 H2 Z5 F18000 ; lift Z relative to current position
          G1 H1 X-305 Y-305 F6000 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-305 ; home X axis
          G1 H1 Y-305 ; home Y axis
          G1 X5 Y5 F18000 ; go back a few mm
          G1 H1 X-305 F1200 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-305 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          M400
          M913 X100 Y100 ; return current to 100%
          M400
          G1 X133.5 Y170.2 F18000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 Z5 F300 ; lift Z relative to current position
          ;G90 ; absolute positioning
          Phaedruxundefined daimein2007undefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @tkdirp
            @tkdirp said in G28 Error: Failed to enable endstops Sensorless Homing Homing:
            If you're using sensorless you can remove the P"xstop" and P"ystop" parts since you;re not using actual switches you don't need to define pins.
            • daimein2007undefined
              daimein2007 @tkdirp
              @tkdirp I have same issue did you ever find out the resolve?
              tom33undefined 1 Reply Last reply Reply Quote 0
              • tom33undefined
                tom33 @daimein2007
                @daimein2007 Same problem I would to declare an axis without homing process
                  dc42 administrators @tom33
                  @tom33 said in G28 Error: Failed to enable endstops Sensorless Homing Homing:
                  If you have an axis that doesn't need to be homed, use a G92 command to sets its position. For example, if you create a U axis that doesn't need to be homed, put just this command in the homeu.g file:
                  G92 U0
                  Also add that command to homeall.g.
                  tom33undefined daimein2007undefined 2 Replies Last reply Reply Quote 0
                  • tom33undefined
                    tom33 @dc42
                    @dc42 Thanks You answer quicker than me, I have just did it now by adding M92 C0 in my homing file !
                    Thanks !
                      daimein2007 @dc42
                      @dc42 I'm not sure if this is right for me I'm using 2209's I have installed a RepRap board on an skrv1.3 which converts to duet and uses duet firmware I set everything up for sensorless homing and used the https://teamgloomy.github.io/Configurator/Start
                      tool to configure it I just keep getting this even after hours and hours of checking all settings G28 Error: Failed to enable endstops it's almost like homing itself is not enabled if that's even possible. I get it when trying x or y z is setup on bltouch cant do z without x and y i have searched every square inch of config and setup my x y and z but nothing is it possible there could be a bug. I have a duet2 wifi on my delta never had this problem.
                        jay_s_uk @daimein2007
                        @daimein2007 join us on discord https://discord.gg/uS97Qs7 and we'll go through things with you
