    [SOLVED] Paneldue firmware compile error
    PanelDue
    848
    • 64bitundefined
      64bit
      Can anyone shed some light on what my machine is telling me the problem is? I've been fighting this for the last few hours. I think this is the last hurdle I have to overcome.
      c:/program files (x86)/gnu arm embedded toolchain/10 2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: cannot find -lRRFLibraries
      collect2.exe: error: ld returned 1 exit status
      make: *** [makefile:82: PanelDueFirmware-v3-4.3.elf] Error 1
      "make -j4 all" terminated with exit code 2. Build might be incomplete.
        jay_s_uk @64bit
        @64bit said in Paneldue firmware compile error:
        I think that gives it away
        https://github.com/Duet3D/PanelDueFirmware/blob/master/BuildInstructions.md#building-standalone
        64bitundefined 1 Reply Last reply Reply Quote 0
        • 64bitundefined
          64bit @jay_s_uk
          @jay_s_uk
          It might, If I hadn't been staring at those instructions for the last 2-3 hours. I am not a programmer.
            jay_s_uk @64bit
            @64bit
            Download or git clone the dev branch of RRFLibraries into C:\Eclipse.
            • 64bitundefined
              64bit @jay_s_uk
              @jay_s_uk
              Already been done.
              Downloaded RRFLibraries-3.3-dev whatever its called.
              Renamed it to RRFLibraries
              Put it in Eclipse and even under the firmware tab.
              It wont come up in Eclipse when I try to "open project" either, so im going to look into that more.
                jay_s_uk @64bit
                @64bit the project explorer should look like this
                • 64bitundefined
                  64bit @jay_s_uk
                  @jay_s_uk
                  Making progress I guess.
                  Now Im stuck with no .bin being output.
                  make --no-print-directory post-build
                  Generating binary
                  "/arm-none-eabi-objcopy" -O binary "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.elf" "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" && cat "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" "C:/Eclipse/PanelDueFirmware/SplashScreens/SplashScreen-Duet3D-480x272.bin" >"C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.bin"
                  c:/windows-build-tools/bin/sh: C:/arm-none-eabi-objcopy: not found
                  jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                    jay_s_uk @64bit
                    @64bit yea, i just got that error. will look into it and report back
                      jay_s_uk @64bit
                      @64bit what have you got in C:\windows-build-tools?
                      I had 2 folders and had to tidy it up. works ok for me now.
                      • 64bitundefined
                        64bit @jay_s_uk
                        @jay_s_uk
                        I found objcopy.exe in my GNU Embedded tools. So I ran the following from the cmd prompt
                        C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin>objcopy.exe -O binary "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.elf" "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin"
                        Output was a no logo bin that I have now flashed to the paneldue. after a reset it opened right up.
                        A bit of ass pain, but it worked.
                        • 64bitundefined
                          64bit @jay_s_uk
                          @jay_s_uk
                            jay_s_uk @64bit
                            @64bit
                            can you try going to Windows -> Preferences -> C/C++ -> Build -> Build Variables and click "Add..."
                            set the name to "ArmGccPath", then change to directory and navigate to C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin
                            Then apply and close eclipse. reopen it and try and build
                            • 64bitundefined
                              64bit @jay_s_uk
                              @jay_s_uk said in Paneldue firmware compile error:
                              Must be an issue in the makefile?
                              "C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin/arm-none-eabi-objcopy" -O binary "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.elf" "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" && cat "C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3-nologo.bin" "C:/Eclipse/PanelDueFirmware/SplashScreens/SplashScreen-Duet3D-480x272.bin" >"C:/Eclipse/PanelDueFirmware/Release-v3-4.3/PanelDueFirmware-v3-4.3.bin"
                              c:/windows-build-tools/bin/sh: C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2020-q4-major\arm-none-eabi\bin/arm-none-eabi-objcopy: not found
                              make[1]: [makefile:94: post-build] Error 127 (ignored)
                                jay_s_uk @64bit
                                @64bit
                                It compiles ok for me here
                                64bitundefined 2 Replies Last reply Reply Quote 0
                                • 64bitundefined
                                  64bit @jay_s_uk
                                  @jay_s_uk
                                  I dont understand where the forward slash is coming from.
                                  I mean, I can keep just using the command line to run objcopy. I just wish it wasnt screwed up.
                                  What version of the GNU Arm Embedded Toolchain are you using?
                                  • 64bitundefined
                                    64bit @jay_s_uk
                                    @jay_s_uk
                                    SOLVED
                                    Generating binary
                                    copied and renamed objcopy.exe to arm-none-eabi-objcopy.exe
                                    File compiles properly now into both w/logo and no-logo files.
                                    R006undefined 1 Reply Last reply Reply Quote 1
                                    • R006undefined
                                      R006 @64bit
                                      @jay_s_uk i got the same error and try as @64bit mentioned in the post but its not working for me.
                                      i an waiting your reply @jay_s_uk
                                      • R006undefined R006 referenced this topic
