    Duet Wifi Wall Split
    444
    • Tommygunzundefined
      Tommygunz
      Hello. A couple months ago, I made a post of a wall split in the x direction that occurred on the perimeters of my prints. After spending a lot of time diagnosing the issue, re-flashing the firmware seemed to fix the problem. About a month ago, the wall split issue re-appeared, but in the y direction. I tried re-flashing the firmware but that did not solve the issue. I'm not to sure what is the cause of this issue. Any help would be greatly appreciated!
      Tommygunzundefined 1 Reply Last reply Reply Quote 0
        Tommygunz @Tommygunz
        Here is my config:
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Feb 24 2021 16:32:46 GMT-0600 (Central Standard Time)
        M550 P"Anet A8" ; set printer name
        M575 P1 B57600 S1 ;Set baud rate Duet Board.
        M575 P0 B57600 S1 ;Set baud rate USB
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P2 S0 ; physical drive 2 goes backwards
        M92 X80.28 Y100.65 Z399.10 E413.72 ; set steps per mm
        M566 X600.00 Y600.00 Z18.00 E1500.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X7200.00 Y7200.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
        M201 X2000.00 Y2000.00 Z100.00 E12000.00 ; set accelerations (mm/s^2)
        M906 X1100 Y500 Z500 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X-13 Y5 Z0 S1 ; set axis minima
        M208 X220 Y220 Z240 S0 ; set axis maxima
        M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
        M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
        M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
        M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-32.1 Y2.919 Z0.614 ; set Z probe trigger value, offset and trigger height
        M556 S81 X0.35 Y-1.0 Z0.35 ; set orthogonal axis compensation parameters
        M557 X20:180 Y20:212 S32 ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
        M307 H0 R0.167 C510.3 D2.06 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
        M143 H0 S130 ; set temperature limit for heater 0 to 130C
        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
        M307 H1 R1.238 C55.7 D9.19 S1.00 ; disable bang-bang mode for heater and set PWM limit
        M143 H1 S290 ; set temperature limit for heater 1 to 275C
        M950 F1 C"fan1" Q100 ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned on
        M950 F2 C"fan2" Q50 ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S150 H-1 ; set fan 2 value. Thermostatic contol is turned off
        M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0
        G29 S1
        T0 ; select first tool
          I can't see why re-flashing would have any impact on that. It seems more like underextrusion keeping the walls from melding completely. Possibly the slicer isn't doing any gap fill since it's too close for infill but the extrusion width isn't enough to just use walls.
          Tommygunzundefined 1 Reply Last reply Reply Quote 1
            Tommygunz @Phaedrux
            @phaedrux I use an extrusion width of 0.4mm. My walls are 2mm thick which the wall should be composed of 5 lines of equal thickness. There should be no infill although Simplify3D thinks that the line between the inner and outer perimeter is a "thin wall". I currently have "allow extrusion fill" checked, and a perimeter overlap of 50%.
              Tommygunz
              Here is a close-up picture of the gap. The two perimeters are not touching at all with the other 3 lines. I also boosted the extrusion multiplier which did nothing at all.
                I don't use Simplify3D myself, so I'm not much help with settings suggestions there, but I know that in PrusaSlicer using thin wall detection and gap fill you'd likely have no problem printing it.
                  Tommygunz @Phaedrux
                  @phaedrux I tried prusa slicer. Same issue but elsewhere in the part.
                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                  • engikeneerundefined
                    engikeneer @Tommygunz
                    @tommygunz FYI for PrusaSlicer at least, two 0.4mm walls does not make a 0.8mm wall (as filament comes out with rounded edges it overlaps them). It should tell you what the wall thickness will be for a given linewidth and number of perimeters. Here's a screengrab from mine (with a 0.35mm nozzle and some non-standard line widths)
                    They have a knowledgebase article on it:
                    https://help.prusa3d.com/en/article/layers-and-perimeters_1748/
                    If you're using a 0.4mm linewidth with a 0.4mm nozzle that might give you some trouble - general advice is to have the linewidth a bit wider (e.g. 0.5mm). You use a thinner linewidth for supports when you want them to be brittle
                    Failing that, maybe you're printing a bit too cold so that the layers/perimeters can't bond together. Or could be you've got some mechanical backlash that means your motion isn't quite perfect (and the lines aren't overlapping enough to still bond).
                    i3 clone with a bunch of mods
