    Updating firmware.
    Firmware installation
    1.6k
    • Kwad3dundefined
      Kwad3d
      @phaedrux I'm using a standard Cartridge thermistor from E3D. set to option 5 when configured in Marlin. Here is the section from my config.g
      Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @Kwad3d
        @kwad3d said in Updating firmware.:
        the write up was asking me to update firmware before I was even connected to my network.
        @Phaedrux
        The part about 'getting started' was written long before DWC was official or even standard. In these days it was common sense to configure your 3D printer HW through USB, but that has changed obviously.
        @phaedrux said in Updating firmware.:
        yes to convert between mm/s and mm/min you either divide or multiply by 60
        🎩 KUDOs for your patience 🙂
        • Rushmere3Dundefined
          Rushmere3D @Kwad3d
          @kwad3d
          E3D thermistors are configured like this, T100000 B4725 C7.06e-8
          Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          Kwad3dundefined 1 Reply Last reply Reply Quote 1
          • Kwad3dundefined
            Kwad3d @Rushmere3D
            @rushmere3d Thanks I will try that Thermistor config. Do I just replace everything past Y"thermister" on the M308 line with the info you provided? just double checking before making a change to the config as Im a little rusty on Reprap
            • Dougal1957undefined
              Dougal1957 @Kwad3d
              You change the B parameter and the C parameter (or add it if it is missing)
                M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
                Kwad3dundefined 1 Reply Last reply Reply Quote 0
                • Kwad3dundefined
                  Kwad3d @Phaedrux
                  Ok that seems to have my temps at normal levels. After pid tuning with M303 I enter M500 and get a Warning about no M501 was executed in config.g. Does that mean the tune did not save?
                    The tune saved, but now you have to add M501 to the end of config.g to load those saved results at boot up.
                    • Kwad3dundefined
                      Kwad3d @Phaedrux
                      @phaedrux So I have been tuning for a few days and Im trying to set up pressure advance now. Im following the guide at https://duet3d.dozuki.com/Wiki/Pressure_advance but I don't see any change vertically in the print. However the test print looks great.
                      M550 P"Voron V1.9" ; set printer name
                      M669 K1 ; select CoreXY mode
                      M552 S1 ; enable network
                      M586 P0 S1 ; enable HTTP
                      M586 P1 S0 ; disable FTP
                      M586 P2 S0 ; disable Telnet
                      M569 P1 S0 ; physical drive 1 goes forwards
                      M92 X160.00 Y160.00 Z400.00 E832.0 ; set steps per mm
                      M203 X12000.00 Y12000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                      M906 X800 Y800 Z800 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X-25 Y-25 Z-2 S1 ; set axis minima
                      M208 X325 Y300 Z450 S0 ; set axis maxima
                      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X-26 Y-2 Z2.5 ; set Z probe trigger value, offset and trigger height
                      M557 X15:325 Y05:325 S56 ; define mesh grid
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                      ; Presure Advance
                      M572 D0 S0.1
                      M501
                      And here is my slicer layer change settings using S3D.
                      {if layer_num== 1}M572 D0 S0.0
                      {elsif layer_num== 25}M572 D0 S0.01
                      {elsif layer_num== 50}M572 D0 S0.015
                      {elsif layer_num== 75}M572 D0 S0.02
                      {elsif layer_num== 100}M572 D0 S0.025
                      {elsif layer_num== 125}M572 D0 S0.03
                      {elsif layer_num== 150}M572 D0 S0.035
                      {elsif layer_num== 175}M572 D0 S0.040
                      {elsif layer_num== 200}M572 D0 S0.045
                      {elsif layer_num== 225}M572 D0 S0.05
                      {elsif layer_num== 250}M572 D0 S0.055
                      {elsif layer_num== 275}M572 D0 S0.06
                      {elsif layer_num== 300}M572 D0 S0.065
                      {elsif layer_num== 325}M572 D0 S0.07
                      {elsif layer_num== 350}M572 D0 S0.075
                      {elsif layer_num== 375}M572 D0 S0.08
                      {endif}
                      Im not sure if was on,,, went through the settings. Or just ran the whole print at S0.1
                        Increase the speed, accel, and jerk for the E axis and try again.
                        Try
                        M566 E3000
                        M203 E6000
                        M201 E3000
                        • Kwad3dundefined
                          Kwad3d @Phaedrux
                          @phaedrux Thanks for the input. I will try that tomorrow. So it was on but my settings were holding it back?
                            Most likely yes.
