duet 2 wifi stop in printing
    flyingpig507
    Hi, my DWC reconnect in printing then last progress was lost, the “status” display: No Job running.
    It is DIY Cartesian i3 style. Just stuck in there:
    Here's some information:
    Board: Duet 2 WiFi (2WiFi)
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
    Duet WiFi Server Version: 1.25
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
    Board ID: 0JD0M-9K662-MGPSS-6J9DL-3S86P-18V6Z
    Used output buffers: 3 of 24 (10 max)
    Static ram: 23460
    Dynamic ram: 73228 of which 40 recycled
    Never used RAM 15352, free system stack 193 words
    Tasks: NETWORK(ready,183) HEAT(blocked,308) MAIN(running,449) IDLE(ready,20)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:15 ago, cause: software
    Last software reset at 2021-04-26 21:28, reason: StuckInSpinLoop, GCodes spinning, available RAM 15108, slot 2
    Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200040ac Task MAIN Freestk 772 ok
    Stack: 0041f9c3 00459a3c 610f0200 3f800000 3d7df000 3edb6db7 b61cf800 49742404 3c3fdc9b 440739fd 40e190bc 0000bb9b 00000000 3e4fa932 41ddae4f 4e64e1c0 38533333 3f800000 3f800000 20000011 00000000 00000001 00000000 00000000 20002544 00000001 0041f9c3
    Error status: 0x00
    Aux0 errors 0,0,0
    MCU temperature: min 32.6, current 33.3, max 33.5
    Supply voltage: min 24.8, current 25.0, max 25.2, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: position 0, standstill, SG min/max not available
    Driver 1: position 0, standstill, SG min/max not available
    Driver 2: position 0, standstill, SG min/max not available
    Driver 3: position 0, standstill, SG min/max not available
    Driver 4: position 0, standstill, SG min/max not available
    Driver 5: position 0
    Driver 6: position 0
    Driver 7: position 0
    Driver 8: position 0
    Driver 9: position 0
    Driver 10: position 0
    Driver 11: position 0
    Date/time: 2021-04-26 21:29:14
    Cache data hit count 17227880
    Slowest loop: 6.87ms; fastest: 0.21ms
    === Storage ===
    Free file entries: 10
    SD card longest read time 1.0ms, write time 0.0ms, max retries 0
    === MainDDARing ===
    === AuxDDARing ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    LCD is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 177.94ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.25
      WiFi MAC address 50:02:91🇩🇪aa:53
      WiFi Vcc 3.49, reset reason Power up
      WiFi flash size 4194304, free heap 26568
      WiFi IP address 192.168.0.198
      WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
    config.g
    M550 P"daZhu_i3" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P1 S0 ; physical drive 1 goes forwards
    M92 X100.00 Y100.00 Z800.00 E381.92 ; set steps per mm
    M203 X7200.00 Y7200.00 Z3600.00 E1800.00 ; set maximum speeds (mm/min)
    M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X172 Y200 Z150 S0 ; set axis maxima
    M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
    ; M558 P0 H5 F120 T7200 ; disable Z probe but set dive height, probe speed and travel speed
    ; M557 X15:190 Y15:195 S20 ; define mesh grid
    M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P25 X-42.8 Y-5.5 Z3.011 ; set Z probe trigger value, offset and trigger height
    M557 X10:128 Y10:190 S118:180 ; define mesh grid
    M307 H0 R0.213 C685.2 D3.92 S1.00 V24.0 ; disable bang-bang mode for the bed heater and set PWM limit
    M143 H0 S100 ; set temperature limit for heater 0 to 100C
    M307 H1 R3.569 C137.0 D6.19 S1.00 V24.0 ; disable bang-bang mode for heater and set PWM limit
    Please help me, Thanks.
    undefined 1 Reply Last reply 26 Apr 2021, 15:00 Reply Quote 0
      felek @flyingpig507
      @flyingpig507
      Hi!
      Did you have similar issue before?
      According to stack trace it looks like some sd card issue.
      Let's replace this sd card.
      undefined undefined 2 Replies Last reply 26 Apr 2021, 15:13 Reply Quote 0
        alankilian @felek
        @felek I'm interested in learning more about how you come to this conclusion.
        I see:
        And in RepRapFirmware-3.3beta3/src/Platform/RepRap.cpp" line 734 there is:
        ticksInSpinState = 0;
        spinningModule = moduleGcodes;
        gCodes->Spin();
        Which points me to whatever the method gCodes->Spin() is doing.
        undefined 1 Reply Last reply 26 Apr 2021, 15:20 Reply Quote 0
          felek @alankilian
          @alankilian
          In M122 you have more precise information:
          Next step is download file with map file. You need to do it for your board and firmware version.
          In your case it is this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Symbols-RepRapFirmware-Duet2.zip
          There is .map file which include functions addresses in memory.
          Then you need to compare your stack address and map file function address.
            flyingpig507 @felek
            @felek
            This is my TF
            This duet board I used almost a year ago. It's been good before (Firmware 1.x). Similar problems was happen until I update Firmware.
            I not sure always used this TF, maybe changed it...
            I will chang other TF try again.
            Thanks you.
              flyingpig507
              I changed TF, it is fine. thank felek (。・∀・)ノ゙
              • undefined sgerevini referenced this topic 20 Oct 2024, 18:24
              6 out of 6
