Bringing older (new) board up to current FW
    3DPMicro
    Pulled out my backup Duet Ethernet board in the hope that I can bring it up to the later RRF 3 with accelerometers and use it on a new build. I haven't been keeping up with the progression so I'm not sure its doable but if it is what is the sequence for upgrading ?
    The controller is V1.02. I believe it had FW 1.18.1 but I must have erased it at one point because all that is on the SD is the SYS, Macros, WWW and g-codes folders and their contents. Before looking at the SD I connected YAT but got nothing in return after sending M115.
    Duet controlled Lathe, micro mill, 3d printer and 1992 Haas VF2 VMC
    undefined undefined 2 Replies Last reply 26 Apr 2021, 06:13 Reply Quote 0
      o_lampe @3DPMicro
      @3dpmicro
      In your case you might find the 'fallback' strategies useful described here
      Good luck
        dc42 administrators @3DPMicro
        @3dpmicro I suggest you do the following:
        • Use Bossa to install RRF 3.3beta3 directly
        • Then you should be able to communicate with the Duet using YAT
        • Using a PC, create a /firmware folder on the SD card and copy DuetWiFiServer.bin and Duet2_SDiap32_WiFiEth.bin into it. Also rename or delete the existing /www folder, create a new /www folder, and extract DuetWebControl_SD.zip into it.
        • Put the card back in the Duet and restart the Duet. Send M997 S1 from YAT to install the WiFi firmware.
        • Then use M587 to set up the access point parameters (see the Getting Connected guide).
        undefined 1 Reply Last reply 7 May 2021, 04:45 Reply Quote 0
          3DPMicro @dc42
          @dc42 thank you Sir. Its alive and well
